Sliding door internal Latch
Mateo83
Mateo83 is offline
PostPosted: Mon Dec 06, 2021 3:46 pm    Post subject: Sliding door internal Latch Reply with quote
83 vanagon. I’ve replaced the handle, delrin bushing but still have play / wiggle in the outside handle. I’m pretty sure it’s the internal latch mechanism the handle bolts through. Any suggestions/ rebuilds/ replacement ideas?
83 Air-cooled 2.0 Tin Top
dabaron
dabaron is offline
PostPosted: Tue Dec 07, 2021 12:31 pm    Post subject: Re: Sliding door internal Latch Reply with quote
how much wiggle, they all wiggle to some degree. the tolerance on the square shaft insert into the internal latch might be wallowed from a loose handle. do you have both the inner foam gasket and the exterior door seal?
have you read this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=228788
1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Dec 07, 2021 1:15 pm    Post subject: Re: Sliding door internal Latch Reply with quote
If it is of any comfort, my 84 has had play (axial, not crosswise) for the past 30 years.
The Delrin bush does help it sit horizontal if that is where I leave it.
IMO, annoying but 'mostly harmless'.
vanis13
vanis13 is offline
PostPosted: Tue Dec 07, 2021 4:08 pm    Post subject: Re: Sliding door internal Latch Reply with quote
You sure you guys the correct delrin bushing?
Not much more left to move/wiggle...
Mateo83
Mateo83 is offline
PostPosted: Tue Dec 07, 2021 5:07 pm    Post subject: Re: Sliding door internal Latch Reply with quote
theres a seller on ebay, they fit is good. i'm sure the play is in the mechanisim itself. I can see it.
vanis13
vanis13 is offline
PostPosted: Tue Dec 07, 2021 10:09 pm    Post subject: Re: Sliding door internal Latch Reply with quote
Ok, he does have two versions for early and late doors
Mateo83
Mateo83 is offline
PostPosted: Tue Dec 07, 2021 10:48 pm    Post subject: Re: Sliding door internal Latch Reply with quote
Says my year.
81 82 83 1981 1982 1983 gasket lever
You are buying a black Delrin door handle bushing. It fits Volkswagen Vanagon from 1980 to 1984 with the long handle. No longer available from Volkswagen
vanis13
vanis13 is offline
PostPosted: Wed Dec 08, 2021 8:51 am    Post subject: Re: Sliding door internal Latch Reply with quote
that should be that (unless they shipped the wrong one)
do you have video of movement? Maybe its a expectations issue? Us Sambtistas can chime in on a video.
Also, have you checked with Delrin seller. Likely he's had others buy and did not solve to satisfaction and he may be privy to other problems/solutions that may cause your issue.
Mateo83
Mateo83 is offline
PostPosted: Wed Dec 08, 2021 10:25 am    Post subject: Re: Sliding door internal Latch Reply with quote
I tied to get a video but it says too large or corrupt.
shagginwagon83
shagginwagon83 is offline
PostPosted: Wed Dec 08, 2021 11:41 am    Post subject: Re: Sliding door internal Latch Reply with quote
you will need to upload it to youtube and link us back here
Brandon
Instagram @joannthevan
