dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Wed Dec 08, 2021 8:44 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
Hotdoggin wrote: |
I've had relatively good luck with the Bosch stuff, I'll bench test it before putting it in. |
did you test the one in place? _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Hotdoggin Samba Member
Posted: Wed Dec 08, 2021 9:02 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
dabaron wrote: |
Hotdoggin wrote: |
did you test the one in place? |
Negative, but when I pull it, I'll do a side by side. If it's fine, it becomes a spare, and the new one goes in. I'm also going to replace the connector. I've got tons of them, and this one is quite brittle. |
Posted: Wed Dec 08, 2021 9:30 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
Hotdoggin wrote: |
what is the plan when a parts swap does not resolve the issue? jumping to a conclusion that part x is faulty without testing is not the path with a Vanagon.
just sayin it could be an expensive exercise throwing parts at it. _________________ 1991 Vanagon GL Camper
Posted: Wed Dec 08, 2021 9:56 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
dabaron wrote: |
Hotdoggin wrote: |
just sayin it could be an expensive exercise throwing parts at it. |
Then I continue down the path of diagnosing it. This is an inexpensive (which I didn't previously know existed, and can't find what I originally thought was the part,) option, with the worst case scenario being it now has a component that doesn't have nearly 40 years of heat cycles on it, with a hyper brittle connector and soft, gummy plastic body. I understand your concern about the swapping parts before proper diagnosis, but if I have them side by side on the bench, and they both check out - It's a zero sum. Now I just have a new, working part in the vehicle, and a spare for a rainy day. Considerably easier to bench test it, too, rather than employing my triple jointed arms, and my third leg to do it the testing procedure in van. If it were a more difficult job, I'd be on your side, but after working on new Volvos, there isn't much here to scare me. |
Posted: Wed Dec 08, 2021 10:24 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
Hotdoggin wrote: |
foreshadowing at it's best. _________________ 1991 Vanagon GL Camper
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Wed Dec 08, 2021 10:28 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
I share the reluctance to throw parts at a problem but in this case... I always have a spare, new, tested Temp II sensor on board. So as the OP notes, nothing to lose by trying. |
Posted: Wed Dec 08, 2021 10:54 am Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
dabaron wrote: |
Hotdoggin wrote: |
foreshadowing at it's best. |
Lol, they're pretty simple creatures. Nuts and bolts. I'm done with it after this, this was the last issue to tackle. |
Posted: Wed Dec 08, 2021 12:25 pm Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
Hotdoggin wrote: |
dabaron wrote: |
Hotdoggin wrote: |
I'm done with this one***
I'm actually looking at a no-runner that's been sitting for several years... |
jlrftype7 Samba Member
Posted: Wed Dec 08, 2021 1:02 pm Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
Hotdoggin wrote: |
Hotdoggin wrote: |
dabaron wrote: |
Hotdoggin wrote: |
Let us know if the Sensor was the issue. In the Future, with similar Bosch Systems, I find that buying a Decade Box with its built-in resistors[ there are different style versions, you want the Resistor Version], is invaluable as a quick plug in resistor of the value of my choosing since you only need to flick a switch on the box to get a single, or several resistors to create a test value that you need for a given circuit.
I bought one years ago for Fuel Gauge testing on Clusters, but it's handy anytime you need to plug in a test value on a circuit that's just looking for a low amperage, resistance value[ Most of the Decade Boxes are only rated for a 1/2 Watt on any of their resistors, so no powering up large loads with them...] _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Wed Dec 08, 2021 2:02 pm Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
jlrftype7 wrote: |
Hotdoggin wrote: |
Hotdoggin wrote: |
dabaron wrote: |
Hotdoggin wrote: |
I bought one years ago for Fuel Gauge testing on Clusters, but it's handy anytime you need to plug in a test value on a circuit that's just looking for a low amperage, resistance value[ Most of the Decade Boxes are only rated for a 1/2 Watt on any of their resistors, so no powering up large loads with them...] |
I absolutely will update soon as it gets here, The decade box is an incredible tool, and I'm certain my co-worker has one next door to try. I'll report back once I get back on this and do that test. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Dec 08, 2021 3:16 pm Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
Hotdoggin wrote: |
Dude.... Welcome to my world..
https://www.thesamba.com/vw/forum/viewtopic.php?t=699642&highlight=
Fight it. It will sit there looking at you saying "pamper me" "love me" "drive me"
Then keep digging deeper in your pocket, and find less than two bits
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Dec 14, 2021 2:36 pm Post subject: Re: Vanagon Hot Starting issue driving Volvo Mech insane |
UPDATE:
Lucky guess.
Hot start issue fixed, Temp II sensor was the cause. A 19mm-3/4 Crowsfoot is the right tool for the job, total time elapsed - 3 minutes. |
