RCP Phx Samba Member
Joined: November 20, 2021 Posts: 496 Location: Phoenix,AZ
Posted: Thu Dec 16, 2021 12:54 pm Post subject: Got almost everything for my 2110 |
Just about ready to start the full assembly.
Danwvw Samba Member
Posted: Thu Dec 16, 2021 1:04 pm Post subject: Re: Got almost everything for my 2110 |
You should read about how to grind piston skirts! Those look tapered next to the cylinders and I read here on the samba that's a NoNo. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Thu Dec 16, 2021 1:53 pm Post subject: Re: Got almost everything for my 2110 |
They don't concern me at all, they are forged Mahles! |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Thu Dec 16, 2021 1:58 pm Post subject: Re: Got almost everything for my 2110 |
Are those by chance the CB 1082 Mahle kit? Have you weighed the pistons, pins and clips yet and if so how much weight difference did you see?
I purchased the 1082 kit from CB and mine had a difference of like, 4.5 grams from heaviest to lightest. I have that down to 1g now, but am still not satisfied.
Ted |
Posted: Thu Dec 16, 2021 2:01 pm Post subject: Re: Got almost everything for my 2110 |
Also, that #2 rod appears to not be moving freely. Maybe its just the photo, but ideally the rods should drop to perpendicular when the crank is horizontal.
Ted |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Thu Dec 16, 2021 2:23 pm Post subject: Re: Got almost everything for my 2110 |
If you're using a deep sump, test fit it now! I had to grind off one of the fat casting flanges at the bottom during engine install to get my sump to fit.
Also, check oil passages compared to crank bearings. I opened them up on my case a little to get them to line up. Other than a few other common engine building tasks the CB/Autoline case was good to go. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Posted: Thu Dec 16, 2021 3:18 pm Post subject: Re: Got almost everything for my 2110 |
No the Mahle's are from Moore and they weighed out perfectly.
The rod is sticking out there because it is cold and the assembly lube is stiff when cold.
No sump(baja bug) but all the oil passages have been checked along with all the other intricacies that have been reported with Rhino cases. |
Danwvw Samba Member
Posted: Thu Dec 16, 2021 3:52 pm Post subject: Re: Got almost everything for my 2110 |
Looks like the crank has some set screws in it, I wonder if its passages need cleaning and some threadlocker used on the plugs? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1059 Location: St. Louis
Posted: Thu Dec 16, 2021 6:10 pm Post subject: Re: Got almost everything for my 2110 |
I have that same crank in 78.4mm from CB and the plugs do need to be pulled and get my most favoritest Loctite 565 on them. So sweet. So smooth. Loctite 565.
The crank measured out insanely well with my Mitutoyo .00001" mic and it was so straight when I spun it on v-blocks I thought my dial indicator was broken. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Thu Dec 16, 2021 9:41 pm Post subject: Re: Got almost everything for my 2110 |
jimmyhoffa wrote: |
The crank measured out insanely well with my Mitutoyo .00001" mic and it was so straight when I spun it on v-blocks I thought my dial indicator was broken. |
.00001 mic? Are you a rocket surgeon? |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Thu Dec 16, 2021 11:39 pm Post subject: Re: Got almost everything for my 2110 |
If you've got the main bearings already test fit the crank n bearings in the case and torque it down. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Fri Dec 17, 2021 8:16 am Post subject: Re: Got almost everything for my 2110 |
jealous of the aluminum case, building a 2110 myself, but it will be a budget, use what ya got situation, looks like you got some bitchin stuff . what cam are you going to use? |
Posted: Fri Dec 17, 2021 10:15 am Post subject: Re: Got almost everything for my 2110 |
VWporscheGT3 wrote: |
Engle FK-7 and I'm using the Pauter 1.3 rockers on CB 044 heads.
Posted: Fri Dec 17, 2021 3:16 pm Post subject: Re: Got almost everything for my 2110 |
fl59bug wrote: |
Are those by chance the CB 1082 Mahle kit? Have you weighed the pistons, pins and clips yet and if so how much weight difference did you see? I purchased the 1082 kit from CB and mine had a difference of like, 4.5 grams from heaviest to lightest. I have that down to 1g now, but am still not satisfied. Ted |
I found my notes they came in at 457.6g |
Posted: Sat Dec 18, 2021 5:32 pm Post subject: Re: Got almost everything for my 2110 |
I did some more pre-fitting before I paint the case and my billet distributor clamp would not fit properly (besides needing a longer stud). I had to die-grinder some more of the casting away and also a little filing on the clamp itself. I still need to check my sump cover but it should ready to paint otherwise. I also finished any de-burring of the case (inside/outside) before the final cleaning. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat Dec 18, 2021 6:51 pm Post subject: Re: Got almost everything for my 2110 |
Lingwendil wrote: |
Painting the case? Why?
I've never seen a painted case look good long term if the car actually gets driven a bunch. |
When I see a painted case, i think... GEX. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Dec 18, 2021 7:39 pm Post subject: Re: Got almost everything for my 2110 |
No dirty motors here, 50yrs ago I started by washing the cases in bath tub!!! |
