New interior panel installation
malcolm2
malcolm2 is offline
PostPosted: Sat Dec 25, 2021 3:26 pm    Post subject: New interior panel installation Reply with quote
I have brand new "door cards" for every where.
I have been working for 2 days to figure out how they actually install.
The clips of course slide into the holes on the back of the panel. Those large holes seem to purposely NOT line up with the small holes in the door.
That is because when the clips are inserted into the panel, they have to be offset from the large panel hole..... BUT WHICH WAY??
And the black plastic sleeves don't fit into the holes in the door.
And the part of the clip that goes into the door is WAY TOO WIDE. I had to mash the clip closed.
If not the clip will not go into the plastic sleeve.
Am I dealing with normal stuff here?
My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing)
busdaddy
busdaddy is offline
PostPosted: Sat Dec 25, 2021 4:06 pm    Post subject: Re: New interior panel installation Reply with quote
The OG cards had the direction the clips pointed to printed on the backs, I guess you'll have to make a paper pattern of the panel holes and overlay it on the door, then mark the holes in the door on the pattern and transfer it back onto the back of the new panel.
As for the clips you'll have to get creative, sadly we have to bend over and use what we got https://www.thesamba.com/vw/forum/viewtopic.php?p=9760722#9760722 , although having looked at CIP's selection a few weeks ago the ones they say fit Beetles may be closer to the bus ones.
Слава Україні!
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sat Dec 25, 2021 4:41 pm    Post subject: Re: New interior panel installation Reply with quote
The new clips are the WORST! Reuse any old clips you have that are in good shape.
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
busdaddy
busdaddy is offline
PostPosted: Sat Dec 25, 2021 4:47 pm    Post subject: Re: New interior panel installation Reply with quote
EZ Gruv wrote:
The new PARTS are the WORST! Reuse any old PARTS you have that are in good shape.
There, fixed it for you. Wink
Слава Україні!
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sat Dec 25, 2021 5:25 pm    Post subject: Re: New interior panel installation Reply with quote
Well...yeah.
Eric
germansupplyscott
germansupplyscott is offline
PostPosted: Sat Dec 25, 2021 9:18 pm    Post subject: Re: New interior panel installation Reply with quote
Make sure you are using Bus door panel clips and rubber boots. The Beetle ones looks the same but are quite a bit wider.
SL
malcolm2
malcolm2 is offline
PostPosted: Sun Dec 26, 2021 6:19 am    Post subject: Re: New interior panel installation Reply with quote
I guess i should double check the part #s on the bags. It has been months since i bought all that.
The “boots” in the pic above will only go about 1/2 way in.
I had the idea to make a paper pattern. Guess that is the way to go. There are like 18 clips for the sliding door. No way to get them all lined up.
Thanks for confirming.
The Volkswagen Ranch
The Volkswagen Ranch is offline
PostPosted: Sun Dec 26, 2021 7:58 am    Post subject: Re: New interior panel installation Reply with quote
If you have the beetle clips and rubber grommets , no way are they going to work, as they are too big. Where did you get them? WW and WCM have the correct clips for a bus, and I have purchased from them in the past. If the door cards are TMI , I’ve installed lots of them over the years, and never had an issue with the holes being “ off” . The idea of the large hole punched in the panel is to so you can “rotate” the clip to the right position to push into the plug. I install all of the rubber grommets first (AFTER installing the plastic moisture barrier) then install the metal clips on the panel and “ pre” line them up with the grommets, and then push the panel on one clip at a time so I can “ fine tune” the clip positions. It takes a while , but has always come out right for me doing this way. Google “ how to install door panels in VW bus” and you will find lots of videos of how to do this. Bob
1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie)
andrewtf
andrewtf is offline
PostPosted: Sun Dec 26, 2021 8:21 am    Post subject: Re: New interior panel installation Reply with quote
Malcolm,
I have a Tupperware full of old clips.
If you want some, PM me.
Andrew
'75 Riviera - 'BIG EMMA' (Pan American highway trip paused for a make over)
'77 Riviera - Murphy' (being reborn.... slowly)
'63 Austin Healey
malcolm2
malcolm2 is offline
PostPosted: Sun Dec 26, 2021 8:47 am    Post subject: Re: New interior panel installation Reply with quote
you might be right.... purchased from JBugs
I believe the clips can be adjusted for for smaller holes. I really don't see a difference the ones I bought and ones with a proper part# on another site.
But the seals I bought just will not go. It seems that I bought the wrong everything.
PostPosted: Sun Dec 26, 2021 8:54 am    Post subject: Re: New interior panel installation Reply with quote
Nope. Can’t “adjust” them . The PO of my bus got the plugs and clips from J Bugs, and I have had to replace all of them. Get the right ones. OEM would be best.
malcolm2
malcolm2 is offline
PostPosted: Mon Dec 27, 2021 7:04 am    Post subject: Re: New interior panel installation Reply with quote
Can't adjust the clips?
How are the clips different? I put in 2 panels yesterday. I did one side with the paper to figure out which way the clips point and the other side I just fiddled with each clip.
As in the 1st pic i posted, I just had to squeeze the spring portion in. with the exception of the "condoms" being missing and on order, the panels fit nicely.
PostPosted: Mon Dec 27, 2021 8:17 am    Post subject: Re: New interior panel installation Reply with quote
I found that if I did “squeeze them” smaller, they would not be reusable. Maybe what you have is different . I had to replace all of them in both doors. Most of them that I removed did hold the panels , but without the rubber grommets. The correct ones fit nicely, and panels are tight, but easily removed for access to internals in the doors.
busdaddy
busdaddy is offline
PostPosted: Mon Dec 27, 2021 8:19 am    Post subject: Re: New interior panel installation Reply with quote
Only the cab doors use (or need) the condoms, the rest just go straight into the metal, no water runs down the inside of any of the cargo area panels.
Слава Україні!
malcolm2
malcolm2 is offline
PostPosted: Mon Dec 27, 2021 9:47 am    Post subject: Re: New interior panel installation Reply with quote
that will be true, now that I have welded up the window sills.
I maybe over doing it, but I added a vaper barrier to the panel opening too. I have already used the B-Quiet sound deadening material, but doing some reading it seemed that folks felt like the vaper barrier helped to quiet things down.
Just as a test, I found a hole that was a bit larger than the ones used to hold the panels..... I inserted a seal and then a clip. The seal made the clip nice and firm.
malcolm2
malcolm2 is offline
PostPosted: Mon Dec 27, 2021 11:22 am    Post subject: Re: New interior panel installation Reply with quote
Jersey looker Early bay has 42 condoms and 42 clips. shows the condom on the non-sliding door side.
busdaddy
busdaddy is offline
PostPosted: Mon Dec 27, 2021 11:47 am    Post subject: Re: New interior panel installation Reply with quote
Interesting, there's no need for them, maybe it's another of those 68 only things?
Слава Україні!
malcolm2
malcolm2 is offline
PostPosted: Tue Dec 28, 2021 7:10 am    Post subject: Re: New interior panel installation Reply with quote
Andrew
Thanks for the offer. I think i can modify these. I have installed the 2 small cards in the rear and everything seems fine.
Clark
malcolm2
malcolm2 is offline
PostPosted: Sun Jan 02, 2022 7:43 am    Post subject: Re: New interior panel installation Reply with quote
I used the paper template idea and it seemed to work pretty well. But it was taking a very long time to tape the paper to the walls. So I up the paper on the back of the panel while on saw horses. Then taped that template to the wall.
anyway, so damn clips ripped out of the holes, so i had to touch up with some strong double stick tape strips. the corner hole location seems to be the most fragile.
Time-wise it took about 8 hours to do adjust all the clips, mark and install these 4 panels and clean up the armrests and bolt them in.
malcolm2
malcolm2 is offline
PostPosted: Sun Jan 02, 2022 7:46 am    Post subject: Re: New interior panel installation Reply with quote
Moving on to the bulk-heads and the storage area....
The card kit did not come with the cards for the storage area. I can't seem to find them for sale in the US.
So I am making cardboard templates.
I have a 4'x4' corrugated plastic slip sheet that I will cut to fit.
Any other ideas on what do do here?
