MikeyM73 Samba Member
Joined: December 06, 2016 Posts: 506 Location: Napa Valley, CA
Posted: Mon Dec 27, 2021 1:49 pm Post subject: Alternator Charging Voltage question |
Hi all,
Happy Holidays. My charging voltage is around 14.1/14.2ish volts with engine running. When I apply a series of loads - headlights, voltage drops a bit to 13.5ish; windshield wipers drops it to 12.9. Auxiliary heater fan drops it even more to around 12.1-12.3.
I don't have any indications of undercharging going on but I guess my question is should the alternator maintain around 14V at idle? Or is it normal for the charging voltage to decrease as more load is added even though the alternator is charging? I ask because I notice the engine speed being affected as the voltage drops and am wondering if my alternator may not be outputting as much as it should. The charging voltage will be higher as engine RPMs increase but I guess I'm used to my 98 Jeep that pretty much stays at 14-14.5V all the time with normal load.
Thanks,
Mikey _________________ '73 Pop-top Westy, found sitting in a field for 10+ years, cleaned up, rebuilt furniture, reloved. Original 1.7 block/fully polished crank, 93mm 1.8L balanced AA pistons & cylinders, new 1.8L balanced rods, HAM 42/36 heads, Scat C25 cam & lubalobe lifters, Dual HPMX40s, R2C filters w/ Outerwears pre-filters, functioning thermostat & flaps, Pertronix Flamethrower III, 4-1 exhaust w/ Cherry Bomb 2" turbo muffler & OEM heater boxes, averages about 19-22ish on the highway. |
74 Thing Samba Member
Posted: Mon Dec 27, 2021 2:05 pm Post subject: Re: Alternator Charging Voltage question |
What are the readings at approx 3k rpm at idle and with the various power loads? |
SGKent Samba Member
Posted: Mon Dec 27, 2021 2:58 pm Post subject: Re: Alternator Charging Voltage question |
where are you making the measurements? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Dec 27, 2021 3:55 pm Post subject: Re: Alternator Charging Voltage question |
74 - I will do that and report back.
Steve - I'm taking that measurement from a VDO voltmeter wired into the fuse box and grounded to a screw connected to one of the air ducts.
Thanks,
Posted: Mon Dec 27, 2021 4:26 pm Post subject: Re: Alternator Charging Voltage question |
Use a multimeter and take the reading at the battery terminals. |
SGKent Samba Member
Posted: Mon Dec 27, 2021 4:51 pm Post subject: Re: Alternator Charging Voltage question |
74 Thing wrote: |
X2
You are actually measuring resistance in the wiring loom between the back of the bus and the front, not alternator voltage. The more current it pulls, the more voltage is lost to resistance. Think of it like water in a hose. At low flow there is a lot of pressure, but as you increase the flow, the resistance in the hose drops the pressure. That is why when you put your thumb on the end of the hose to slow the flow, the water might spray 10' but when the hose end is totally open the flow might only go 3 or 4 inches past the end of the hose - but there is a lot more water. A volt meter measures the electrical pressure between two points, (differential) whereas an amp meter measures the number of electrons flowing. One amp is one coulomb per second (6.242 x 10 18^ electrons per second). You want to know what the voltage is close to the battery, not all the way up front. That is a different question, namely "how much voltage am I losing between the back of the bus and the front at different current loads." Then the next questions are "why," and "is that normal." If yes then Ok. If no, then where is the corrosion... _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Mon Dec 27, 2021 4:53 pm Post subject: Re: Alternator Charging Voltage question |
Will do. Part of this is trying to confirm if my voltmeter is accurate. Currently, at idle with no load i’m seeing between 14.1 and 14.3. However, with lights on, windshield wipers on, and turn signal on, at idle, it drops to 12.1. At speed, around 3000 to 4000 RPM, with the same load and accessories turned on the voltage drops to about 13.1 maybe 12.9. Just wondering if that shouldn’t be a little higher.
When we first got this bus, five years ago, one of the diode’s was loose from the back plate in the alternator so I JB welded it in and it has been running and charging, seemingly fine, ever since.
Thanks,
SGKent Samba Member
Posted: Mon Dec 27, 2021 9:07 pm Post subject: Re: Alternator Charging Voltage question |
you are saying that you want to know what the pressure is at the water well head pump but you are reading the pressure 1000' way at the hose end while you are running the bathtub. If you want to measure what is going on at the pump you will have to install a gauge at the pump. If you want a more accurate accounting of what the pressure is at the well head but you want to read it 1000' away, you will have to run a dedicated line that has no loss at the gauge end. Meaning you will have to run a dedicated line from the alternator / battery connection at the starter, and FUSE it to be safe. It will tell you what is going on back there but next you will ask why is it 12.5 V up front and 14.3 V in the back. Turn off the bathtub or improve the plumbing in between. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Dec 27, 2021 10:01 pm Post subject: Re: Alternator Charging Voltage question |
MikeyM73 wrote: |
When we first got this bus, five years ago, one of the diode’s was loose from the back plate in the alternator so I JB welded it in and it has been running and charging, seemingly fine, ever since... |
Uh, no - not a good fix. JB Weld is great at many things, but fixing electrical isn't one of them. It's an insulator. An alternator diode is a high current device, and any added resistance is going to make a big difference in alternator output. The diode should be a press fit into its mounting plate. If it's loose, the proper fix is to shrink the hole a little, then press it back in.
Not saying that this is your only problem, but it's surely not helping... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Mon Dec 27, 2021 11:55 pm Post subject: Re: Alternator Charging Voltage question |
If you have 14volts at the battery and 12.9 at the fuse box with everything "ON" then that would be normal. Though at idle you might not be able to maintain 14v at the battery under full load, especially if the one diode is not making good contact. |
Posted: Tue Dec 28, 2021 9:47 am Post subject: Re: Alternator Charging Voltage question |
Thanks all. Telford, I dug through some old posts and turns out I posted up a couple years back about having a loose diode that you guys helped me out with (https://www.thesamba.com/vw/forum/viewtopic.php?t=728659&postdays=0&postorder=asc&start=0) - forgot about that until now. Apparently, the metal of the "lip" of the hole in the B+ plate that secures the diode in place somehow cracked just enough to loosen it and let it jiggle around. These days, as we're getting more accessories working, fixed, added, etc. I had a concern about voltage levels.
My JB Weld fix was actually a thin epoxy bead but at the time I pushed the diode back through the hole, squished that metal back together as much as possible and when I pressed the diode back in from the back, the fit was tight but I wasn't sure if it would come loose again so my epoxy application was a very thin bead on the backside only around the edge of the diode just for insurance. I did not slather it across the back because I figured there would need to be some kind of heat dissipation. If you think I should correct this, I will.
Other than that, I'll compare the voltages from front to rear but if it's considered normal to idle at 12.5V + with headlights, wipers, and turn signal on, I can live with that.
Thanks for all your help
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Tue Dec 28, 2021 10:41 am Post subject: Re: Alternator Charging Voltage question |
A word about JB Weld. it is a conductor and not an insulator. JB weld has ground metal in it. As a result it will conduct electricity.
This is why you can use it like bondo on something then powder coat it. Someting you cannot do with actual bondo. |
Posted: Tue Dec 28, 2021 1:04 pm Post subject: Re: Alternator Charging Voltage question |
MikeyM73 wrote: |
If you think I should correct this, I will. |
From your description, you're probably OK, but keep an eye on it... _________________ '71 panel, now with FI
Posted: Wed Dec 29, 2021 10:47 am Post subject: Re: Alternator Charging Voltage question |
Thanks Telford. So what kind of issues might I see related to that?
Thanks,
Posted: Wed Dec 29, 2021 11:48 am Post subject: Re: Alternator Charging Voltage question |
MikeyM73 wrote: |
So what kind of issues might I see related to that? |
If the diode has poor contact, it will likely get hot and possibly fail. If the failure is a short, the alternator output will likely stop, and the indicator light will come on. If the failure is an open circuit, the alternator output will drop, and the battery may not charge fully. Either way, you'll know it if it happens. _________________ '71 panel, now with FI
Posted: Wed Dec 29, 2021 12:00 pm Post subject: Re: Alternator Charging Voltage question |
Fair enough. Thanks Telford,
Have a happy NY, all.
Posted: Thu Dec 30, 2021 9:39 pm Post subject: Re: Alternator Charging Voltage question |
sodbuster wrote: |
There are conductors, and then there are conductors. JB Weld is likely a high resistance conductor (probably in the thousands of ohms per inch category - next time I use some, I'll measure it). This is good enough for powder coating (which has current flows in the milliamp or microamp range), but likely useless for high current apps like 35 amp alternator diodes... _________________ '71 panel, now with FI
SGKent Samba Member
Posted: Thu Dec 30, 2021 10:34 pm Post subject: Re: Alternator Charging Voltage question |
from JB Weld FAQ, manufacturer's web site.
Q. Will J-B Weld conduct electricity?
A. No. J-B Weld is not considered to be a conductor. It is an insulator. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 13, 2022 5:34 pm Post subject: Re: Alternator Charging Voltage question |
So let's say for the sake of the conversation that all wiring is good, no electrical draws, etc. What should the minimum charging voltage be? I'm starting to see the volt meter creep to 15.1 and I believe the max should be no more than 14.5, correct? I have a couple spare voltage regulators that I will install to see if I can bring that down to around 14.5V but it's the minimum voltage I'm concerned with. I presume VW rated their alternators to run all accessories the bus came with in rainy weather so I'm curious as to what you all see with everything (or almost everything turned on) at idle. Wipers, radio at low volume, lights, aux heater fan, and let's throw in a turn signal for good measure.
My Jeep is modern day and with all of the above it charges at idle right about 13.5V, maybe a bit more. I presume this would be true of most alternators in a 12V system but I guess that's the bottom line question... what is the minimum voltage one should see under those conditions?
Damn.. 74 Thing, I haven't gotten to checking on your question but I will do that tomorrow and let you know. Thanks.
Thanks for the continued advice,
busdaddy Samba Member
Posted: Thu Jan 13, 2022 6:01 pm Post subject: Re: Alternator Charging Voltage question |
15.1 is getting up there, 14.5 is the common max voltage. If your's is going higher the VR is to blame, it may not be sensing voltage properly (bad terminal or broken wire, or terminal pushing out of the plug, bad ground), or it may have internal issues. The mechanical ones can be tweaked to limit max volts, the solid state ones can not.
A properly functioning VR keeps the volts at a set limit, if you turn on a light or some other draw it signals the alternator to work a little harder to maintain the volts it's trying to see. If it can't properly sense voltage, or the battery isn't soaking up what the alternator is putting out voltage may exceed what you hope to see. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
