jlrftype7 Samba Member
Posted: Tue Jan 04, 2022 8:12 am Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
dhaavers wrote: |
I keep checking this thread and all I see is battery stuff. Where's the 4:20 content...???
- Dave |
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Tue Jan 04, 2022 8:17 am Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
That’s a total non-starter for me. That cabinet is where the scotch and tequila go. The expense of buying good scotch and tequila, and the subsequent lack of beer space/cooling needs, makes purchase/complications of solar etc. unreasonable and unnecessary for my wife and I.
We’re completely happy with a Coleman cooler and a little planning. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
gtinseth Samba Member
Joined: July 25, 2019 Posts: 76 Location: NW California
Posted: Tue Jan 04, 2022 4:44 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
Howesight wrote: |
Gtinseth: My 4 cells are each 3.2 volts nominal, and 12 volts nominal as wired in series. The actual voltage is 2.5v per cell and 10 V at the lowest State of Charge, and 3.65 V per cell/ 14.6V at the highest SOC. |
You add the cell nominals to get the pack nominal of 12.8 volts. Also, I'd never run down below 12.3 or 12.4 volts if you want max cycles out of it. And max for me is around 13.8-14.0 volts for the same reason. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
BrownLoaf Samba Member
Joined: January 21, 2021 Posts: 94 Location: Bellingham, WA
Posted: Tue Jan 04, 2022 6:24 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
With our Riviera, I find myself on the fence between sticking with the current "keep it simple" setup versus a compressor fridge and everything it takes to run it for 3+ days off grid.
For me, and likely for others, much of the fun and joy with these vans is designing upgrades, solving problems, and enjoying the process as much as the result. Because of this, it's hard to resist the urge to upgrade to a compressor fridge, LifePo, and solar. All that stuff is fun and technical!
However, there isn't much to complain about with the "keep it simple" current setup. Our Riviera included a built in icebox that has an ice tray which drains below the van. It has generous capacity for beer plus other stuff, is relatively efficient, and stays relatively dry. Rebuilding it with modern insulation, hinge pivots, and door gasket was a fun project on its own.
Because there is no compressor fridge, battery needs are minimal. We use a portable battery bank that powers the van lights, cig lighter outlets, radio, and sink pump. We've camped for 5 days without needing a charge. And because the unit is portable, it can be moved between vehicles and used for tent camping when we do that.
All of those benefits of "keeping it simple" said, it's still hard to resist the feeling of missing out on the fun tech. I've even recently purchased a cheap used 12v Norcold fridge with plans to retrofit the Danfoss BD35 compressor refrigeration into the Riviera icebox. To be determined if I will go that route with this van or keep it simple instead. _________________ 83.5 Vanagon Riviera WBX 2.2 "Brown Loaf"
87 Vanagon Syncro Tin Top WBX 2.1 "Bubbles" |
jimf909 Samba Member
Posted: Tue Jan 04, 2022 7:56 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
Oh goodness, I love this thread and all the different ideas but this is the antithesis of KISS to me. I've got a food-safe fridge that runs indefinitely on solar and alternator charges and keeps food and beer from the dusty grocery store cold when I'm traveling and leftovers cold when I'm wfh in my van.
Here's my version of KISS:
Fridge #1 is for whatever needs to be kept cold or frozen. Open the door, toss it in or remove what's needed.
As said, to each their own.
pdm777 wrote: |
Sharing Alternative Solutions for
Cooling Food in the Westy.
Sorry to hear about your 1960's ice chest traumas.
I totally agree with you re: downsides of conventional ice chests.
Things Have Changed in the last 50 years in cooler technology.
We’ve all been there (soggy Petri dish ice chests) but you are
clearly damaged goods at this point, You have turned to the Dark Side,
dependent on electrons for sustaining your camping experience…
and when (not if) the electrics fail- your food is toast and you go home.
Here’s what I have done to mitigate the situation and travel light.
Note that my usual camp experience is 5-7 days.
This Solution will provide Safe Temperatures for at least 7 days.
I can extend the trip a few more days, with Dry Ice.
End the Floating Food Slimy Food Mess
with the ‘Two Cooler’ Method.
Buy Two Coolers:
- #1 Cooler: High-Quality YETI style cooler.
- #2 Cooler: a cheap Coleman type ice chest.
Never Use Bagged Ice chips or Block Ice , NEVER!!!
Ditch commercial ice! Questionable water quality in a thin leaky bag.
Instead, Freeze 16oz water bottles at home, 3 days so they are rock solid.
* by using individual water bottles instead of commercial ice products,
you have extended the life of your precious ice CONSIDERABLY.
BONUS, you have clean cold drinking water as a by-product.
(as opposed to throwing out tainted ice water, losing all those cold BTUs!)
You can NEVER have enough clean pure water when camping!
Line both coolers with Frozen Water Bottles, as many as you can.
Dedicate the #1 YETI clone cooler to limited use!
Plan on opening it no more than two times in day.
Contents: Frozen Steaks, Fresh Seafood, Frozen Spaghetti.
Main Meals. Fresh Bacon, Cheese, Lunch Meats in sealed Rubbermaid
containers. A thermometer in the Cooler with Meats/Seafood is essential.
I like these Rubbermaid containers, Clear, Unbreakable &Waterproof.
You can use Dry Ice to extend cooling a few more days.
#2 Cooler is for Beverages, Fruits & Vegetables/perishables/cheese/
-all food items go into clear plastic bins with locking lids (waterproof).
Beer, Wine, take up the other half of the cooler.
This cooler will be accessed many times per day.
Three Days is typical, keeping the cooler outside,
your consumption of beverages is linear to the longevity of your ice.
Don’t sweat it, the Good Food is in #1 Cooler, safe and sound.
_________________ - Jim
Abscate wrote: |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Wed Jan 05, 2022 9:57 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
Son provides Westy electrical 'upgrades' to his dad's Westy.
But the Luddite in me rejects it. End of an Era :
-Coleman White Gas 'Double Mantle' Lanterns. often spewed flames.
-Coleman White Gas cook stove. Pump it Up! often spewed flames.
https://youtu.be/mTmhqrCKjTU _________________ 1990 Westy Full Camper |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
DuncanS Samba Member
Posted: Wed Jan 05, 2022 11:37 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
djkeev wrote: |
Just thinking out loud…….. I haven’t any desire for a large house power grid at all.
Dave |
That's called KISS. Combiners, DC to DC, monitors, solar and so on are not keeping it simple.
Duncan |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Thu Jan 06, 2022 4:35 am Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
You always start with the loads. Once you decided you have to have active cooling, you have signed up for a not KISS solution in short.
Most others are best served by one large deep cycle battery and a jump pack.
We would often run both house batteries down on anchor over a week and then hand start the engine to get off anchor and out of harbor _________________ .ssS! |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3800 Location: VA/TN
Posted: Thu Jan 06, 2022 5:56 am Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
Really most peoples needs here are just a lifepo4, shore charger, and a fuse panel.
I built a 100aH lifepo4 pack for $250. $50 for a shore charger. 100aH will get someone through 3 days of camping with a small fridge, interior led lighting, and charging usb devices.
If you have the battery built and have a westy with AC power - one could install the battery, fuse panel, and run an outlet in 4 hours (or less).
Think of space savings too. If you camp more than 3 days straight then yeah you could look into solar, alternator charging, etc. or pull out the frozen water bottles and use the coolers for the longer trips. _________________ Brandon
Instagram @joannthevan |
Posted: Thu Jan 06, 2022 12:07 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
Back in the Jurassic, my father had a 42' old and wooden schooner (sailboat) with a single small 6 volt start battery for a small gas engine. The battery could also run two lights in the main cabin, but using them was a class 1 Federal felony. There was an ice box and a compass. No depth sounder, just a lead line, no speedometer, but there was a taffrail log--a device that towed a spinning propeller which recorded distance--if it got used, which was seldom. That's it. We cruised 1000 miles a year coastally. That may not seem like much, but the average sailboat probably is lucky to get 200 miles a year.
Radar--eyeballs and a mouth blown fog horn with a lookout on the bow. No winches for lines/ropes, nor anchor windlass. Bilge pump was a manually operated item with a long stick you pulled up. Radio non existent. Requests for a bridge to open or for launch service to get to shore was done with the fog horn using certain calls. Cabin, running or anchor lights were kerosene with wicks which needed trimming and glass chimneys to be cleaned.
Once we sailed 45 miles in open ocean with high winds, seas, currents and pea soup fog heading for the Brenton Reef Lightship. Older brother on the bow watching. At the estimated time from my navigating and helmsman father it appeared as a ghost dead ahead, just where he had anticipated. It was the first thing we saw since we hoisted anchor 7 hours earlier. He was good.
Ice was bought in 50 pound blocks which were readily available in most ports because local fisherman needed ice to preserve their catch.
THAT was KISS and pretty close to how the Mrs and I camp now.
Duncan |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 951 Location: Northern California
Posted: Thu Jan 06, 2022 5:14 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
pdm777 wrote: |
By using individual water bottles instead of commercial ice products,
Line both coolers with Frozen Water Bottles, as many as you can. |
This advice was totally worth the price of admission. Thanks! _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Posted: Thu Jan 06, 2022 5:25 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
Red Ryder wrote: |
pdm777 wrote: |
This advice was totally worth the price of admission. Thanks! |
Hmmmm...... I don't see a star by your name....... your admission has been absolutely free! _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu Jan 06, 2022 5:36 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
^^^^ And keep the empties and refill next trip. Too much single-use plastic around as it is. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Thu Jan 06, 2022 8:36 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
pdm777 wrote: |
Ditch commercial ice! |
In the privilege offered by the "each to his own" program.
%$%$%$ (This is an emoticon? for sarcasm as I don't know if there is one or how to find it. Ed.) Dry Ice. Don't you know it sublimates into the global warming gas and is therefore taboo for green camping in our unspoiled wildernesseses? It's OK for overnights at a Walmart parking lot, but really........
"Bagged Ice or Block Ice, NEVER" Really? How do you make a G & T with ice in a plastic bottle? And how do you get your boutique beer half melted into a block of ice if there is NEVER a block? Blocks last much longer than cubes.
But seriously, having two ice coolers for drinks and food makes sense........... except it takes up more room and because of exposed thermal conducting envelopes being doubled means more ice turns to water faster than in a single one. Use one and have shelves and plastic tubs and the slime problem goes away as he said.
Duncan |
pdm777 Samba Member
Posted: Thu Jan 06, 2022 9:56 pm Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
There is a Method to My Madness. Puff.
I question whether 1 cooler is more efficient than two.
Arguing that the combined surface area is a detriment to efficiency,
compared to if two coolers were combined into one more-efficient unit.
Some of my fellow campers have a habit of dipping into the cooler
every 30 minutes or so. Snacks, Beers, Beverages, adding to the
heat load/cooling loss.
That's why I have cooler #2, and don't care how inefficient it is.
It's large, so it's outside.
A big block of ice/ 20# bag o ice is CHEAP and does well for beverage cooling.
For Maximum Efficiency, you want your #1 cooler
to remain sealed as much as possible.
My Main Meals are in the smaller YETI clone, safely frozen
or near frozen. Temperature swings are minimal (due to not opening).
I stagger meals
Most perishable gets cooked first.
I'm learning that Many savory meals can
be prepared and Frozen at home, making meal prep easy,
and contributing icy temps to the cooler.
Heck, you don't need frozen water bottles
when you have Frozen lasagna, Steak, Lobster tails!
Surprising how long these will remain frozen rock hard
when inside a YETI clone. I'd guess 10 days. _________________ 1990 Westy Full Camper |
Posted: Fri Jan 07, 2022 2:53 am Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
We put our drink cooler in the cockpit and use it as a seat , the food cooler stays in a locker below.
The Vanagon Cruiser Forum . Nice tales of the Sea, Duncan. The first time we lost sight of land my partner was a little concerned.
How do you know you are on course ?
Compass
Chart
Dead reckoning
Sun position
Wind waves.
( GPS active but in the helm locker where I can’t see it because I want to master the above. ) _________________ .ssS! |
Posted: Fri Jan 07, 2022 7:14 am Post subject: Re: 4:20 Ramblings About Batteries, Solar, and keeping it Simple. |
djkeev wrote: |
Lifetime warranty by an old successful company.
It snowed last night, more time to think during cleanup .........
Dave |
An old successful company. Maytag? Various hardware companies which have drunk the Kool Aid by lusting after bigger markets and everything is made in China?
Not saying that Stanley is one of these, but it's sooooooo disheartening to buy something we have relied on for years only to discover the Kool Aid effect.
I had a Coleman for years and had the cushion on top which gave more insulation and made for a great seat. Then another came along somewhere--sure I didn't buy it--and not so good. 1" Foam and ice that really wanted to do a phase change as fast as possible.
The Stanley you're thinking about, Dave.
https://www.stanley1913.com/products/adventure-cooler-30-qt?
I'd want to see a picture taken directly above the open cooler to get an idea about how thick the insulation is. Looks a little thin, but the oblique photo angle doesn't give much help. Also the height is right up there making it less comfortable as a seat, but then it takes up less floor space too. A problem with all hard coolers is the case tapers/draft so they can get it out of the mold. Perforce this means less insulation at the bottom. Beware of coolers with significant tapering. A case--pun--for the soft incased ones. Except they don't have urethan insulation and you can't sit on them. All the more reason to make your own.
For the boat, I built an on-deck cooler for the beverage of choice and easy access for ice for the cocktails. The same plastic grating that shows in the instrument locker was in the bottom of the cooler as well.
3" of urethane foam was hot glue gunned together and two layers of polyester resin and mat on the outside. Inside was two layers of epoxy cloth and epoxy white pigment added. It would hold a full case of cans plus ice. The bottom drain had a wood plug that could go in it with a tube that stuck up 4". Any melt water higher that the 4" would drain directly overboard. In full hot sun a block of ice would last almost 3 full days. Cubes less.
For years have thought about doing this again as a portable for the car and having a cushion with OG upholstery velcroed to the top. Bottom, not side drain with cedar grating in the bottom as the main ice box in the boat had. Battery LEDs in the lid with a contact switch so it would go on when opened.
If you make it with a cloth/vinyl exterior, all that needed is the foam box and then line the interior with resin and mat/cloth which is easy as you can get to it all. I'd go with a loose hard top top as it's easier and no zipper. This way you can get exactly the size you want and with far better insulation than is commercially available.
Or take a commercial one and build a thick urethan foam exterior around the existing liner. A ply box for the outside and hand it in.
Duncan |
