Greaser2 Samba Member
Posted: Thu Jan 06, 2022 1:06 pm Post subject: Engine run on |
1967 Squareback. My Square has lots of nice upgrades like internally regulated alternator, external oil cooler, and MSD ignition. I do have engine run on for about 1 second when key is switched off and I'm too anal to just live with it. The fix is to install a diode on the blue wire from the alternator to the ignition dummy light. I'm in the process of testing the diode to see if it fixes the problem and I completely disconnected the blue wire from the alternator. No dummy light of-course but still have run-on?? Maybe its not the dummy light? I also have a positive feed wire connected to the alternator feeding the external oil cooler but when I disconnect it no oil cooler fan but still have engine run-on. So with no positive feed from the alternator I have engine run on. Where can the extra voltage be coming from? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Thu Jan 06, 2022 1:37 pm Post subject: Re: Engine run on |
Is it running indefinitely, or is it just "dieseling" as it ingests fuel and the hot engine can still ignite it? |
Posted: Thu Jan 06, 2022 1:47 pm Post subject: Re: Engine run on |
Runs perfectly for that one second and shuts right off. I've had dieseling on other vehicles on occasion and its completely different. I did alot of idol and timing adjustments tuning the dual carbs but the engine run on was unimpacted and consistant. |
Posted: Fri Jan 07, 2022 8:00 am Post subject: Re: Engine run on |
The diode in-line with the blue wire from alternator to ignition light did not solve the problem. Next will add a ballast resistor on the MSD small red wire. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Fri Jan 07, 2022 4:37 pm Post subject: Re: Engine run on |
what carbs are you running? |
Posted: Mon Jan 10, 2022 9:31 am Post subject: Re: Engine run on |
Weber 40 |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5360 Location: Lefty, CA
Posted: Tue Jan 11, 2022 11:21 am Post subject: Re: Engine run on |
Multi69s wrote: |
Does it run on when the engine is cold, or only when its hot? |
Both |
Posted: Fri Jan 14, 2022 8:06 am Post subject: Re: Engine run on |
Added a ballast resistor on the ignition feed to the MSD box. Problem fixed.
