Westy46 Samba Member
Joined: June 27, 2015 Posts: 92 Location: South Dakota
Posted: Thu Jan 06, 2022 2:47 pm Post subject: Automatic shifter light replacement-LED SOLVED |
I am attempting to replace the shifter lights with new GW LED's. I am having difficulty in figuring out what appears to be parallel wiring. According to the instructions I need parallel connections.
I am hoping someone has photos on how to actually complete this set up. I also need new end connectors.
Thank you for the help.
atarasi Samba Member
Joined: October 19, 2004 Posts: 320 Location: Seattle, WA
Posted: Thu Jan 06, 2022 2:53 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
Did you watch their installation video? Looks easy enough. |
Posted: Thu Jan 06, 2022 3:29 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
Yes I viewed the video and it looks like I need 4 wires. Probably making it more complex than it really is. |
Timwhy Samba Member
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
Posted: Tue Jan 11, 2022 1:43 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
I was trying to wire in parallel and there was a small spark on one of my LED lights. The LED lights I am trying to hook up no longer work, and the ignition does not work. I have attached photos of my main battery under passenger seat and the back up battery. Is there a fuse that may have blown with these battery areas? All of my lights work except these shifter lights and the ignition. It won't even turn over.
Any ideas?
Timwhy Samba Member
Posted: Tue Jan 11, 2022 2:10 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
I am going to get a 12v tester and check each fuse peg to find out for sure. I do think fuse#3 was missing in fact. What does it mean if a fuse was missing and I installed? |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 951 Location: Northern California
Posted: Tue Jan 11, 2022 2:52 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
Westy46 wrote: |
A missing fuse can mean:
1. The slot is intentionally vacant because an optional factory feature was not installed.
2. Fuse kept blowing and PO could not fix.
Determine what the circuit is for and install a proper sized fuse. Worst that happens is fuse might blow. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Timwhy Samba Member
Posted: Tue Jan 11, 2022 3:06 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
Westy46 wrote: |
Lots of folks take out the #3 and tap into the wiring to run off the Aux battery. It would depend on the wiring if they disabled the starter battery from being hooked up. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Tue Jan 11, 2022 3:19 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
My fuses light up. I tried to plug in my battery back up to replenish the batteries, but that doesn't work either. Would there be something with the battery connections? Fuse link? |
Timwhy Samba Member
Posted: Tue Jan 11, 2022 5:53 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
The fuse on aux battery works. There is no clicking when turn ignition, no sound, but all lights work interior, blinkers, headlights, and flashers all work. Is there a fuse of some sort on main battery under the passenger side seat. I see a red wire with a fuse link connection maybe. Would that be something? |
Posted: Thu Jan 13, 2022 11:13 am Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
I figured out why would not turn over. My batttery and back up battery were both dead. This is interesting because I had headlights, blinkers, flashers, and interior lights. It was when I saw a dimming of lights that I decided to check the battery(should have been first to check). I re-charged and starts great.
Ok, on to the diagram I have added. This is showing the auto center console wiring diagram for the console lights. I am not sure how to read the diagram as far as determining which fuse handles these console lights. Does anyone know? I thought it was #3, but not so sure.
Thanks for the help as I am not that mechanical or electrical in abilities. |
Posted: Thu Jan 13, 2022 11:14 am Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
Posted: Sun Jan 16, 2022 5:58 pm Post subject: Re: 87 Weekender - Automatic shifter light replacement-LED |
After much needed help from a fellow Samba member I have completed the LED install on the auto shifter console. The correct Bentley page-diagram is 97.223 which shows the correct fuse #15 and 10 amp. My fuse 15 was blown which is now replaced. I completed some splicing and crimping to complete the parallel wiring and I now have bright console lights.
Thanks for all the help.
