froootlooops Samba Member
Joined: September 27, 2013 Posts: 5 Location: Philippines
Posted: Sat Jan 08, 2022 4:31 am Post subject: which pea shooter tail pipes make the fweem sound? |
Anyone know which specific tail pipes make the fweem?
I have a 1500 SP with a NOS Ernst muffler and installed new stainless steel pea shooters from Wolfsburg West and I do not get any of the whistle.
I searched the forums and read that Brazilian tail pipes make these even when new. Can anyone link to the specific product that produces the sound? |
klroger Samba Member
Joined: September 22, 2017 Posts: 150 Location: deep river, Ottawa Valley
Posted: Sat Jan 08, 2022 8:59 am Post subject: Re: which pea shooter tail pipes make the fweem sound? |
I have the cheep muffler & the cheep tailpipes from CIP1 & I do get that sound when the engine is under a bit of a load. There is a spec for how far the tail pipes go into the muffler, But I think that's more for preheat operation, but it may effect the sound as well. _________________ I Didn't know what to do, So I Didn't do anything!!!! |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sat Jan 08, 2022 12:03 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
part of the fweem has to do with how far in the tail pipes are installed. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
toxicavenger70 Samba Member
Posted: Mon Jan 10, 2022 2:29 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
When my tips were new they did not make this sound. Once the inner metal liner (sleeve??) start to break/wear in it started to make the fween sound. Also make sure you don't have your idle to high. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33999 Location: Conejo Valley, CA
Posted: Mon Jan 10, 2022 3:00 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
GOD SAVE THE FWEEM! |
Posted: Fri Jan 14, 2022 11:28 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
Okay, I guess I will just try to get the cheap chrome tailpipes and hope for the best |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Jan 15, 2022 5:47 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
I believe what toxicavenger70 said.
The inner metal baffles are wrapped in fiberglass or something of that nature.
In my experience when the pipes are new you only get a faint sound and as the pipes age and the fibers break down the fweem increases. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
72alpinewhitebus Samba Member
Joined: July 04, 2016 Posts: 77 Location: Eugene, Oregon
Posted: Thu Feb 02, 2023 4:04 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
KTPhil wrote: |
I haven't laughed that hard since I was a little girl...
I remember reading somewhere you'd get 5 more hp if you inset your tweeters (fweemers?) a certain amount further back from factory. Anyone else remember hearing that? _________________ "What's the difference between a pro and an amateur? A pro doesn't think they're an amateur."
72 Westy
60 Sedan
79 Vert |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Thu Feb 02, 2023 4:39 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
72alpinewhitebus wrote: |
KTPhil wrote: |
I remember reading somewhere you'd get 5 more hp if you inset your tweeters (fweemers?) a certain amount further back from factory. Anyone else remember hearing that? |
I laughed pretty good too! I want the bumper sticker! I'm thinking that I set my tail pipes at 1.5" or 1.75", and got FWEEM instantly. _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
Posted: Thu Feb 02, 2023 4:58 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
I copied this from another thread. From Rob of Rob and Dave's VW Page.
Quote: |
Rob responded - Do your tail pipes have the inner perforated pipe with stuffing behind the inner wall, or are they plain pipes?
The whistley part of the fweem comes mainly from the inner perforated pipe inside the peashooter tail pipes - it's smallish in diameter, which speeds up the speed of the exhaust gases - it's like blowing through a concertina tube which tends to make a whistling sound.
You should push the tailpipes all the way in and then pull them back out about 1/2-3/4 inch (12-19mm). That gets them right inside the muffler but not blocking the inner end against the inside of the muffler.
Another thing - is the muffler a quality South African or German/Danish muffler? I think some of the cheap stuff these days doesn't come with the internal piping of the original design, and that WOULD change the sound since the internal piping of the originals means all cylinders have equal length header pipes. The two rear cylinders should have headers INSIDE the muffler which cross over inside - this provides a large part of the "beat" of the fweem as it means the peashooter tail pipes get pulses of gases 'left left right right' instead of 'left right left right'. |
crukab
Feb. 11, 2021
zerotofifty
May 16, 2023 |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Thu Feb 02, 2023 8:57 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
I have two cars that make this sound. On both of the I installed Leistritz muffler along with these: https://www.thesamba.com/vw/classifieds/detail.php?id=2411418
Those pea shooters have the baffle in them.
When I drive next to wall I can hear the classic sound.
_________________ www.vwnos.com [email protected]
Posted: Fri Feb 03, 2023 2:55 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
I need some new ones. So I will hit your site tonight. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Fri Feb 03, 2023 7:39 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
61SNRF wrote: |
In my experience when the pipes are new you only get a faint sound and as the pipes age and the fibers break down the fweem increases. |
Oddly enough, my experience has always been the opposite. Every set of stock tailpipes I've run over the past thirty years started off with a fweem and progressively lost their characteristic chirp over the course of a few thousand miles. _________________ 1960 Ragtop w/Semaphores "Inga" |
heimlich VWNOS.com
Posted: Fri Feb 03, 2023 8:23 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
mukluk wrote: |
Every set of stock tailpipes I've run over the past thirty years started off with a fweem and progressively lost their characteristic chirp over the course of a few thousand miles. |
Is it carbon deposits?
I know most the time I can't hear the sound unless I am driving on an onramp on the freeway or somewhere that echos it. That way the sound ricochet from the walls. _________________ www.vwnos.com [email protected]
mukluk Samba Member
Posted: Sat Feb 04, 2023 3:13 pm Post subject: Re: which pea shooter tail pipes make the fweem sound? |
heimlich wrote: |
Is it carbon deposits? |
I don't believe so, they don't soot up much at all. _________________ 1960 Ragtop w/Semaphores "Inga" |
