andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Tue Jan 11, 2022 9:02 am Post subject: Autostick vacuum canister band clamp source? |
I bought a couple replacement diaphragms, but screwed uo and didnt get the kits with the band clamp. Any suggestions on what you use? I did search. _________________ D-Dubya Manx clone - 63 Short pan,1914.
sb001 Samba Member
Posted: Tue Jan 11, 2022 11:38 am Post subject: Re: Autostick vacuum canister band clamp source? |
I doubt you're going to find the actual clamp that comes with the replacement servo kits by itself, but it's just a regular band clamp, albeit fairly large- measure the diameter of the canister and see if you can find an appropriate match, some parts place has to be selling something that will work. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1606 Location: Central Pennsylvania
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Tom K. Samba Member
Cusser Samba Member
Posted: Tue Jan 11, 2022 2:40 pm Post subject: Re: Autostick vacuum canister band clamp source? |
Tom K. wrote: |
Cusser, you taking too many nips on the bottle hidden in the bottom shelf if your tool box today? |
Had to - used up the bottle in the top shelf hoping that the Raiders and Chargers would not tie !!!
Read that Steelers had 8% chance of getting into postseason when Sunday started, then when Colts lost and Steelers beat Baltimore, the odds increased to over 99% because only way to be excluded would be if Raiders-Chargers tied. I figured when Raiders were ahead by 15 that there would be no tie, but when game went into overtime.......and then was tied in overtime.....
Wonder how my hair turned gray....
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Tom K. Samba Member
sb001 Samba Member
Posted: Tue Jan 11, 2022 5:13 pm Post subject: Re: Autostick vacuum canister band clamp source? |
Tom K. wrote: |
Did not know you could purchase diaphragms alone and not in the kit. I wonder if those diaphragms are of higher quality? Where did you get them? And maybe that place also sells the clamps? If not, then the kits are not that expensive at all of the usual places. |
evwparts sells the diaphragm individually, I ordered just the diaphragm last year when the one that came in my first kit I ordered failed after two years.
https://www.evwparts.com/vwparts/113142055A-Diaphragm.html
Nice that the replacement kits have that removable band clamp, but I also went ahead and ordered a good used OEM canister (with the permanent band) sometime after so when this one fails I'll install the OEM and probably not have to worry about it again for a good long while. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Tue Jan 11, 2022 6:03 pm Post subject: Re: Autostick vacuum canister band clamp source? |
Got the diaphragms on Ebay. But it looks like the clamp pinches the 2 halves together, so it need to have a U profile. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Tom K. Samba Member
volkenstein Samba Member
Joined: June 26, 2005 Posts: 858 Location: The Land of Oz
Posted: Tue Jan 11, 2022 7:50 pm Post subject: Re: Autostick vacuum canister band clamp source? |
Fellas,
Truck air brake canister clamps could substitute. MANN or somesuch from memory. The more metric the better. Anybody gone down that path?
HTH
Volkenstein _________________ 71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age... |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3331 Location: 802 The Pointless Forrest
Posted: Wed Jan 12, 2022 4:10 am Post subject: Re: Autostick vacuum canister band clamp source? |
How about a band clamp from a metalbestos chimne pipe? _________________ "Albatross"! |
mukluk Samba Member
Posted: Wed Jan 12, 2022 11:08 am Post subject: Re: Autostick vacuum canister band clamp source? |
What you want is called a V-band clamp. Once you measure the diameter of the housing, an internet search for that appropriate size should help you find the clamp you need. In the long run though, you may find it easier and more cost effective to just order another diaphragm kit that actually includes the clamp. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Jan 18, 2022 8:57 am Post subject: Re: Autostick vacuum canister band clamp source? |
I just ordered a Walker clamp from my FLAPS. Will let you know if it works and the part number. I can't believe that nobody has ever dealt with this before since the original clamp gets destroyed when its removed..... _________________ D-Dubya Manx clone - 63 Short pan,1914.
sb001 Samba Member
Posted: Tue Jan 18, 2022 9:21 am Post subject: Re: Autostick vacuum canister band clamp source? |
andk5591 wrote: |
I just ordered a Walker clamp from my FLAPS. Will let you know if it works and the part number. I can't believe that nobody has ever dealt with this before since the original clamp gets destroyed when its removed..... |
Understand what you're saying, but most folks buy the kit the first time with the reusable clamp. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Fri Jan 21, 2022 7:53 am Post subject: Re: Autostick vacuum canister band clamp source? |
The Walker clamp was too wide...Still looking and yeah, should have looked at the original clamp closer. Cant see how it could be removed without destroying it. Oh well. _________________ D-Dubya Manx clone - 63 Short pan,1914.
sb001 Samba Member
Posted: Fri Jan 21, 2022 9:59 am Post subject: Re: Autostick vacuum canister band clamp source? |
andk5591 wrote: |
The Walker clamp was too wide...Still looking and yeah, should have looked at the original clamp closer. Cant see how it could be removed without destroying it. Oh well. |
You do have to destroy the OEM clamp getting it off.
The replacement kits come with a new reusable clamp. I really think at this point your best bet is to just buy the kit. The extra diaphragm will probably come in handy anyway a few years down the road when your current replacement gives out, they are nowhere near the original VW OEM quality. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Sun Jan 23, 2022 5:30 pm Post subject: Re: Autostick vacuum canister band clamp source? |
sb001 wrote: |
andk5591 wrote: |
The replacement kits come with a new reusable clamp. I really think at this point your best bet is to just buy the kit. The extra diaphragm will probably come in handy anyway a few years down the road when your current replacement gives out, they are nowhere near the original VW OEM quality. |
Problem is that these are customer cars....not my own. But I guess it is what it is.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Jan 23, 2022 11:00 pm Post subject: Re: Autostick vacuum canister band clamp source? |
Hmmm,
A lot of searching elsewhere has revealed it is a M.A.N (or other) "Type 16" air brake canister. Either US/Euro Truck versions are made. Closing a 155 mm diameter IIRC. 6 1/4". Maybe worth a shot.
That info is from about 15 years perhaps...
HTH
Tom K. Samba Member
