Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Sat Jan 15, 2022 11:51 am Post subject: Tricks? Plug Smallcar bellhousing hydraulic connection? |
If you disconnect this from the slave unit, the fluid reservoir will drain out of it.
So you wanna plug it.
Who has a method to plug this connection?
This slave actuator/bearing unit is used in some 300+ VW models for more than 20 years.
SOMEBODY must have a decent trick to plug this (by now). ?? _________________
....KTMs, GasGas, SPOT mtb |
Sodo Samba Member
Posted: Sat Jan 15, 2022 8:42 pm Post subject: Re: Tricks? Plug Smallcar bellhousing hydraulic connection? |
OK the solution made itself known.
Good thing I didn't throw that old slave/throwout bearing away!
seeeeee..... this is what enables a hoarder.....
So here's a pic to help find a way to plug it.
This pic should help.
I cut the business end off the old slave/bearing, threaded the hole and plugged it with an M5 bolt.
Next I'm gonna section-cut that slave actuator to understand what's going on inside that mysterious device when it's over-extended.
(thread referring to Smallcar Bellhousing problem Smallcar bellhousing clutch options)
.....which Smallcar added a spacer (a limiter) on the master cylinder.
The spacer prevents damage to the slave/release/bearing unit but retains the clutch abruptness/feathering issue (that off-road drivers dislike).
Moving the clevis pivot hole restores butter-smooth clutch actuation. _________________
