Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 506 Location: Macktown, CA
Posted: Tue Jan 18, 2022 3:46 pm Post subject: should there be a washer on temp II? |
With hopes of combatting a cold start issue, I ordered a couple Bosch Temp II sensors to replace the 30+ year old one I used to replace the original. Seems like it's the right move. which is great, however, I've got a leak coming from the T-stat housing at the sensor. Is this guy supposed to have a washer on there to seal properly? The salvaged oldie I was running did not, but I'm looking at photos and it seems that some do and some do not. I'm really trying to not crank down so hard that I crack the housing.
thanks. _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Sat Jan 22, 2022 5:32 pm Post subject: Re: should there be a washer on temp II? |
Yes there should be an aluminum crush washer on it. I don't remember the size off hand but just take it to your local parts store and grab one that fits. |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Sat Jan 22, 2022 8:15 pm Post subject: Re: should there be a washer on temp II? SOLVED |
thank you. I found one in my bucket of nuts and bolts and what not.
went to 4 FLAPS and hardware stores and none had the proper washer... _________________ so many roads i know
4Gears4Tires Samba Member
Posted: Sun Jan 23, 2022 10:38 am Post subject: Re: should there be a washer on temp II? |
ooh. nice. just made that purchase. thanks for looking out _________________ so many roads i know
Posted: Sun Jan 23, 2022 3:48 pm Post subject: Re: should there be a washer on temp II? |
You can often get crush washers from the fastener section of a hardware store. You will need to spend a few minutes walking the aisles and perusing all the little boxes to find them. |
