Geof136 Samba Member
Posted: Wed Jan 19, 2022 3:34 pm Post subject: Relays switch |
Lately, there have been stolen Vw Vanagons and I would like to see if someone can please help me identify this relays switch in my fuse box. By removing one of this relay switch, thieves won’t be able to start the engine and deter from stealing my beloved Vanagon. Your help would be greatly appreciated. Thanks for reading my topic. Here is my fuse box compartment.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Wed Jan 19, 2022 3:52 pm Post subject: Re: Relays switch |
Sorry, there nothing in the front of that fuse/relay panel that is needed for the engine to start and/or run.
You could pull every relay and fuse from it and it wouldn't keep the van from being driven.
Mark |
riceye Samba Member
Joined: March 09, 2006 Posts: 1661 Location: Caledonia, WI
Posted: Wed Jan 19, 2022 3:59 pm Post subject: Re: Relays switch |
The relay(s) you are looking for are in the engine compartment.
_________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Posted: Fri Jan 21, 2022 7:13 am Post subject: Re: Relays switch |
Thank you very much for your feedbacks. |
Posted: Fri Jan 21, 2022 7:19 am Post subject: Re: Relays switch |
By the way, I forgot to ask you this. Will it cause any damage if I accidentally start the engine if I forgot to reinstall the relay? |
Posted: Fri Jan 21, 2022 8:27 pm Post subject: Re: Relays switch |
If either the fuel injection or fuel pump relay are removed the engine isn't going to start. |
Posted: Fri Jan 21, 2022 9:20 pm Post subject: Re: Relays switch |
Thanks but which relay in the engine compartment? |
Posted: Fri Jan 21, 2022 10:12 pm Post subject: Re: Relays switch |
Geof136 wrote: |
Both the Fuel Injection and the Fuel Pump relays are in the black box mounted on the left wall of the engine compartment.
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sat Jan 22, 2022 8:05 am Post subject: Re: Relays switch |
That's my patented tool for relay removal... but I no longer carry the spares in there. I found that in really hot weather (110*+) the relays benefit from the extra air space inside the box (or so it seems). |
kamzcab86 Samba Moderator
Posted: Sat Jan 22, 2022 8:10 am Post subject: Re: Relays switch |
Geof136 wrote: |
_________________ ~Kamz
2016 Golf GTI S
