Install kill switch on positive or negative? |
POSITIVE (with precautions) |
15% |
[ 4 ] |
NEGATIVE (TrashPanda, you dangerous idiot) |
84% |
[ 22 ] |
Total Votes : 26 |
TrashPanda Samba Member
Joined: December 25, 2021 Posts: 119 Location: Oakland, CA
Posted: Fri Jan 21, 2022 2:28 pm Post subject: Battery kill switch: POS+ or NEG- |
I plan to install a battery cut-off switch, mainly for extra security.
Oakland is currently rife with car theft, and I'd like a little more deterrent than my pedal lock provides.
I already have a marine grade switch like this one:
https://www.amazon.com/BATTERY-CUTOFF-SWITCH-BOAT-RACECAR/dp/B003BQLZ36
But I may spring for this one, for even more security:
https://www.summitracing.com/parts/sum-g1442
Both are rated 1000amp burst, 200amp continuous.
Just for ease of install, I intended to use the ground (negative) side. But it occurs to me that any patient, enterprising thief with cables and maybe a drill handy could just cut, crimp and fasten a new ground cable to the body, bypassing my security.
The thief would only have to know the battery location on the Vanagon. Given the number of stolen Vanagons in the area lately, I presume the secret is out.
So my plan is to use the positive side, interrupting the cable below the van, just before it passes through the grommet and into the battery compartment. Of course, I will cover the terminals to protect against the elements, as well as add a fused jumper to keep the dashboard clock running. I'll also be sure my connections are secure enough to keep the cable from grounding.
What do you all think? Am I an idiot?
Do I go ahead with my positive plans, or will an outpouring of negative nancys talk me out of it? |
DuncanS Samba Member
Posted: Fri Jan 21, 2022 3:20 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
I think you are over thinking it. Do a hidden switch which triggers a latching relay for the fuel pump and hand it in. Make sure you read the entire 7 pages of the topic as there are some quirky things that could happen depending on the wiring your car has. https://www.thesamba.com/vw/forum/viewtopic.php?t=706950 . Or a hidden switch grounding the green tach wire feed. It's right at the dash and easy to get to.
Duncan |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Fri Jan 21, 2022 4:06 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
And don't use the first one - we have one of those (in the neg feed, natch) and it can go intermittent. We've wondered once or twice why the van wouldn't start, and this was the culprit each time. _________________ Jim Crowther
Vespa GTS 300 |
tjet Samba Member
Posted: Fri Jan 21, 2022 4:32 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
The Neg side is where BMW installs the disconnect switches when they ship new cars from Germany. |
Posted: Fri Jan 21, 2022 4:50 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
Once upon a time, I used the rear defrost switch in my old '75 BMW 2002 as a starter cut-off switch. Not sure whether anybody tried, but it was never stolen.
I made that choice at the time, instead of a fuel pump cut-off, because I didn't like the idea of the battery being run down / the starter getting overheated and worn out. I may do something similar, here.
But, if early responses are any indication, I should stick to the ground side for any full-on battery cut-off.
And I should continue to ignore my reckless instincts. |
the joker Samba Member
Posted: Sat Jan 22, 2022 6:44 am Post subject: Re: Battery kill switch: POS+ or NEG- |
Bet you wish you had that BMW 2002 , I also had one 1972 2002 silver/blue
use the summitt switch, neg side it's easy to install ,hidden make it accessible while in the drivers side be, creative.
There made for racing, shutting down the electrical systems fast.
Find the model with plastic red key, also handy to shut down for long term storage, or electrical work |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Sat Jan 22, 2022 9:18 am Post subject: Re: Battery kill switch: POS+ or NEG- |
TrashPanda,
Do you have a manual or automatic transmission? _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Vanagon Nut Samba Member
Posted: Sat Jan 22, 2022 10:09 am Post subject: Re: Battery kill switch: POS+ or NEG- |
A proper easy access switch on starter battery negative post might also help slow down damage due to an electrical short.
@ OP: did your BMW starter disable set up use a relay on 50 circuit to starter solenoid?
Thinking like a thief, if I couldn't even get the starter to turn, I'd bail. However, if I lived in a higher crime area, I'd likely install a fuel relay cut off and starter disable.
1988 West DIY 50º ABA
VE7TBN |
Zeitgeist 13 Samba Member
Posted: Sat Jan 22, 2022 12:54 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
I owned a '76 2002
Just like my general outlook on life, I'd opt for negative. |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat Jan 22, 2022 1:07 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
We've been installing proper "HELLA" switches on the negative side. If you mount the cutoff switch at the front of the seat base you can just use 2 off the shelf straps and the install is straight forward, and when installed it that position it is easy to get to when needed in an emergency.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Sat Jan 22, 2022 1:19 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
Don't forget to put in an AirTag and bring a gun when you retrieve it.
I would probably not get a battery disconnect since I hate resetting all the clocks, radio stations, etc. Maybe rethink this. Something that does not allow the engine to start. You know, where the engine cranks, but will not start.
With all the cat converter thefts around here, they are already carrying the tool that can disable any pedal lock. Battery switches are difficult to hide so not much deterrent. I'm pretty lazy so it would have to be something simple to engage/disengage. |
fxr Samba Member
Posted: Sat Jan 22, 2022 1:23 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
Butcher wrote: |
Simple - bypass the cut-off switch with a 5A fuse. That keeps the radio etc alive, but will blow at the slightest hint of a heavy current (starter, short to chassis, whatever). _________________ Jim Crowther
Vespa GTS 300 |
Posted: Sat Jan 22, 2022 1:27 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
fxr wrote: |
Butcher wrote: |
Simple - bypass the cut-off switch with a 5A fuse. That keeps the radio etc alive, but will blow at the slightest hint of a heavy current (starter, short to chassis, whatever). |
Bingo! _________________ Dave O
The Western Syncro build
Posted: Sat Jan 22, 2022 1:49 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
I have an unfused negative from the cut off switch which feeds the radio, in/out temp gauge and my windows only. They are separate grounds and do not connect to the body tin. Clock is AA battery quartz analog.
Duncan |
Posted: Sat Jan 22, 2022 1:54 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
Thanks to all of you for your thoughtful responses.
I'll stick with the negative side, and I'll spring for the Summit lockout switch.
To assuage my concerns over a thief just running their own ground strap, I'm thinking now I'll just try to keep them out of the battery compartment with something like a hasp lock.
I appreciate the linked thread. I particularly like the idea of using a 3.5mm headphone jack (and relay) as a starter cut off, with a matching plug wired POS to NEG. I forget who suggested that. Genious. I built some Grado style headphones a while back, and still have spare jacks and plugs around. So I might do that one too.
As for the off-topic: my van is a manual; I sometimes miss my '75 2002 and the '72 I had before that one. But I wouldn't trade my Vanagon for either. They were a hell of a lot of fun for a few hours of twisty roads. But my Vanagon can offer straight days, or weeks, of fun.
Thanks, again, to all of you for sharing your wisdom and keeping me out of trouble. This forum is an invaluable resource. |
Posted: Sat Jan 22, 2022 5:18 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
dobryan wrote: |
fxr wrote: |
Butcher wrote: |
Bingo! |
Which means you set the clock/radio again.
Maybe you have a better memory than me, but I will remember the kill switch is on when I turn on the key. |
Posted: Sat Jan 22, 2022 5:22 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
A separate ground to the radio and you don't have to reset the presets. Clock ground can be isolated as well. No fuse needed. |
fxr Samba Member
Posted: Sat Jan 22, 2022 5:44 pm Post subject: Re: Battery kill switch: POS+ or NEG- |
DuncanS wrote: |
Isolating the ground on many (not all, granted) radios is NOT trivial. _________________ Jim Crowther
Vespa GTS 300 |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
