Sir Sam Samba Member
Joined: July 19, 2009 Posts: 1689 Location: Fort Collins Colorado!
Posted: Fri Jan 21, 2022 4:40 pm Post subject: What's the latest on in-dash HVAC? Tired of the Smallcar setup. |
I have a smallcar AC setup, I used to link it was the best thing you could do to a van. But the lack of a proper heater in the smallcar setup has gotten me to the point where I am ready to ditch it.
Is there anything else out there these days thats better than the smallcar kit for a replacement HVAC system?
TIA _________________ '91 Carat Westy
87' Syncro + '87 Westy conversion coming soon |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Fri Jan 21, 2022 5:03 pm Post subject: Re: Whats the latest on in Dash HVAC? Tired of the smallcar setup. |
Sir Sam wrote: |
TIA |
Out of curiosity, do you still have the rear heater? If not, perhaps adding it back into the mix would be the thing? _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Fri Jan 21, 2022 9:53 pm Post subject: Re: Whats the latest on in Dash HVAC? Tired of the smallcar setup. |
djkeev wrote: |
Find an old Behr unit or retrofit your own system.
Making modifications for in dash A/C has been done.
I started to once but never finished the idea.
But it would have worked.
Look in the FAQ under the HVAC section for links.
Dave |
Somebody needs to do this. There must be some other make heater/ evaporator/blower box that could be retro-fitted.
In dash a/c and ABS brakes are the two worst aspects of the T3. Weak transaxles next. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
Posted: Fri Jan 21, 2022 10:32 pm Post subject: Re: Whats the latest on in Dash HVAC? Tired of the smallcar setup. |
ledogboy wrote: |
Sir Sam wrote: |
TIA |
Out of curiosity, do you still have the rear heater? If not, perhaps adding it back into the mix would be the thing? |
Propex heater took the place of the rear heater. I've considered redoing the propex setup to get the rear heater installed again. _________________ '91 Carat Westy
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Sat Jan 22, 2022 9:45 am Post subject: Re: Whats the latest on in Dash HVAC? Tired of the smallcar setup. |
Sir Sam wrote: |
ledogboy wrote: |
Sir Sam wrote: |
TIA |
Propex heater took the place of the rear heater. I've considered redoing the propex setup to get the rear heater installed again. |
You can run the propex while driving. That may help, or not. YMMV. _________________ Dave O
The Western Syncro build
Posted: Sat Jan 22, 2022 9:54 am Post subject: Re: Whats the latest on in Dash HVAC? Tired of the smallcar setup. |
dobryan wrote: |
You can run the propex while driving. That may help, or not. YMMV. |
Though it would be nice to get all of that heat for “free”, rather than needing to burn propane. _________________ 1986 Westy Weekender
Now a full camper
Posted: Sat Jan 22, 2022 9:57 am Post subject: Re: Whats the latest on in Dash HVAC? Tired of the smallcar setup. |
ledogboy wrote: |
dobryan wrote: |
Though it would be nice to get all of that heat for “free”, rather than needing to burn propane. |
Definitely.
But it may be easier to stay filled up on propane for those those really cold days than go thru the cost and effort of doing something different with the in dash unit? _________________ Dave O
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Sun Jan 23, 2022 1:54 pm Post subject: Re: What's the latest on in-dash HVAC? Tired of the Smallcar setup. |
Sir Sam wrote: |
TIA |
My DIY front AC system is better than the Smallcar unit. Mine keeps the stock heater box with some modifications and the AC output is vastly superior to the performance of the smallcar system, so far as many have described the Smallcar system’s performance. As it turns out, I have to pull my dash as part of prep for a paint job. When in there, I will have to remove my DIY evaporator box. I am going to then make a “plug” that can be used for ABS plastic vacuum molding copies. The shape, size and location of the evaporator was the single most time-consuming part of designing my system. Whether I go further with a “kit” is doubtful since I already work 60 or more hours a week, but the evaporator enclosure with B5 Audi evaporator installed would get many DIY folks a good jump start. Hmmmm . . . _________________ '86 Syncro Westy SVX |
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Sun Jan 23, 2022 8:09 pm Post subject: Re: What's the latest on in-dash HVAC? Tired of the Smallcar setup. |
I have vague memories of your build Howesight, you do amazing things.
Would the modern version of a plug be a 3D scan converted to gerpix (I made that up) and 3D printed in the privacy of ones own garage? _________________ 84 westie 2.2 w/ digijet, AT |
Posted: Mon Jan 24, 2022 6:36 am Post subject: Re: What's the latest on in-dash HVAC? Tired of the Smallcar setup. |
Howesight wrote: |
Sir Sam wrote: |
TIA |
My DIY front AC system is better than the Smallcar unit. Mine keeps the stock heater box with some modifications and the AC output is vastly superior to the performance of the smallcar system, so far as many have described the Smallcar system’s performance. As it turns out, I have to pull my dash as part of prep for a paint job. When in there, I will have to remove my DIY evaporator box. I am going to then make a “plug” that can be used for ABS plastic vacuum molding copies. The shape, size and location of the evaporator was the single most time-consuming part of designing my system. Whether I go further with a “kit” is doubtful since I already work 60 or more hours a week, but the evaporator enclosure with B5 Audi evaporator installed would get many DIY folks a good jump start. Hmmmm . . . |
You should contact 10c about your design.
This seems right up his alley.
People will be (are) clamoring for A/C, especially in dash A/C.
A kit of this type that uses the existing heater box seems like a perfect answer to meet a growing need (want).
Creating a Vanagon A/C kit would be largely comprised of common off the shelf components.
The engine compressor mount and adjustment system and the Evaporator are the two exceptions.
Someday, someone is going to step in and satisfy this wide spread desire. I watched desire for A/C grow just last Summer.
Sell a complete kit, or just sell the speciality components ala carte and let folk assemble their own system from local sources.
Ghia
Vanagon
Beetle
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Mon Jan 24, 2022 7:26 am Post subject: Re: What's the latest on in-dash HVAC? Tired of the Smallcar setup. |
I added a pump to the heater circuit per this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=534812
I didn't spend a lot of time in stop and go traffic last winter so I never really used it, but this year I have and I'm surprised by how effective it is. When I'm idling and flip the manual switch to spin the pump, the different in heat output is immediate.
That plus the rear heater keeps it toasty. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
GaryW Samba Member
Posted: Wed Jan 26, 2022 7:54 am Post subject: Re: What's the latest on in-dash HVAC? Tired of the Smallcar setup. |
Howesight wrote: |
I'd definitely be interested in your evap box and a parts list.
Gary |
