66uno Samba Member
Joined: December 05, 2006 Posts: 603 Location: maryland
Posted: Sat Jan 22, 2022 2:09 pm Post subject: Improving ride of a lowered bus |
I lowered my bus 2 1/2 inches using drop spindles in the front and an IRS trans in the rear. The ride is pretty good overall. But the front does not damp as well as I would like. I put Koni’s in the front but not adjustable ones. It also does not track as well as I would like. I am considering lowering my tire pressure in the front. I have heard that may improve the tracking. Now, I must be keenly alert at all times. Also thinking of adding castor shims.
I am open to all suggestions. |
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Posted: Sat Jan 22, 2022 6:17 pm Post subject: Re: Improving ride of a lowered bus |
Have you had it in for an alignment after the spindle install ? _________________ My '65-Subaru EJ20 Turbo conversion |
sled Samba Member
Posted: Sat Jan 22, 2022 7:09 pm Post subject: Re: Improving ride of a lowered bus |
66uno wrote: |
proper shocks make all the difference in the world for a split bus.
you can not add caster shims unless it is a Barndoor (1950-1955). for "regular" split buses the caster has to be added into the construction of the beam.
what tires do you have in front, and what pressure are you running? _________________ drive your split. |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 558 Location: I don't recognize it anymore
Posted: Sat Jan 22, 2022 7:25 pm Post subject: Re: Improving ride of a lowered bus |
I'm dropped 3.5" w IRS, stock beam on 15" , but customized wheels (offset) I would think IF you used adjustable Koni's (and your front end is in good order)you may find that sweet spot. I remember taking the Koni's off 3X to get my ride, once in the back. I tightened-up the Koni's slowly to get there. Check your toe-in and try to wiggle the tires in the air. Any bearing movement will make the ride wacky and throw off everything. _________________ kaiser kills kids.com |
