Feral Samba Member
Joined: August 02, 2021 Posts: 38 Location: Newcastle
Posted: Sun Jan 23, 2022 12:21 am Post subject: front wider than rear |
OK, I changed the front drum of mu 1970 bug to discs. Now it is about 20mm 3/4" wider than the rear. Anyon have any ideas? |
Feral Samba Member
Posted: Sun Jan 23, 2022 12:29 am Post subject: Re: front wider than rear |
Dan the workingstiff Samba Member
Joined: July 03, 2006 Posts: 824 Location: Downriver, MI
Posted: Sun Jan 23, 2022 4:26 am Post subject: Re: front wider than rear |
That is exactly what happens. There is a sticky about this at the top. _________________ '69 Beetle
'66 FG buggy
My other air-cooled's
'76 IH 1200
'75 IH 1200 |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Sun Jan 23, 2022 8:13 am Post subject: Re: front wider than rear |
Yeah, what he said. On the plus side, this extra width will give you better stability, both in the curves and on the straights. The down side is that the extra width is all in the scrub radius, which can make the steering feel a bit heavy. It can also make it difficult to stuff the front tires under the fenders.
But the better braking performance of the discs and the increased stability are well worth it, in my opinion. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Sun Jan 23, 2022 11:33 am Post subject: Re: front wider than rear |
An idea that may be of interest , I would have to do a little research to confirm but I think the type 3 rear brake drums may add about that much back to the rear width. As I remember they add about 3/4 on each side. Changing from standard to type 3 rear drums really helped the equalize the braking on my baja with disc front brakes. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9879 Location: Huntington Beach, CA
Posted: Sun Jan 23, 2022 12:13 pm Post subject: Re: front wider than rear |
When I have installed front disc brakes on standard Bugs, I always narrow the beam by 2 inches. That allows for the extra width and wider tires! I love 175 or 185 up front! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
viiking Samba Member
Joined: May 10, 2013 Posts: 2666 Location: Sydney Australia
Posted: Sun Jan 23, 2022 1:57 pm Post subject: Re: front wider than rear |
Newcastle NSW or UK?
My RHD Euro 68 came with standard VW discs on a standard width front beam. Why would it be an issue? VW designed the car for discs. I wouldn’t worry. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Sun Jan 23, 2022 1:59 pm Post subject: Re: front wider than rear |
Maybe the palm tree and the paling fence tells me NSW? _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Posted: Sun Jan 23, 2022 2:35 pm Post subject: Re: front wider than rear |
I just checked my Bentley and the difference between the drum and disc brake track is 6mm with the disc brake front end widerAT MAX WEIGHT. It only goes up to 69, but I don't think the 70 was any different.
If you are trying to measure the pan without any weight in it, then understand the track WILL change as you add mass to the back end. That is, the rear camber will become more positive and INCREASE your back end track.
I don't think you need to worry. Put the body back on with the engine and remeasure. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Feral Samba Member
Posted: Sun Jan 23, 2022 4:07 pm Post subject: Re: front wider than rear |
thanks for the replies. Yes Newcastle NSW.
I wont worry about it then. It is just me pedantic.
I will drop the body on and see how it all fits.
I have to run the brake lines next.
Cheers |
Rome Samba Member
Joined: June 02, 2004 Posts: 9602 Location: Pearl River, NY
Posted: Tue Jan 25, 2022 8:47 pm Post subject: Re: front wider than rear |
Dog reminds me of the one in the original early 1930's "The Little Rascals" where "Breezy" Brisbane pulls the curved tail of his dog and says "now Pointer, I want you to hold your tail straight!".
Tvättbjörn Samba Member
Posted: Tue Jan 25, 2022 10:14 pm Post subject: Re: front wider than rear |
Not sure how and where you measured, but it looks like your alignment is way off. You can rum 185 tires under stock fender with the correct off-set. |
