Jjones659 Samba Member
Posted: Sun Jan 23, 2022 8:27 am Post subject: Shift tube hits top adjuster |
Hey guys,
I have a adjustable beam on my bus. I changed my mind on how low I wanted it so I got the front jacked back up. Problem is that my shift tube is hitting the top adjuster nut so it's causing problems. Is there anything I can do to fix this besides lowering the front back down? I'm assuming both top and adjusters should be set at about the amount of teeth? Just wondering if I can lower just the top adjuster. Or find a different smaller nut to put on it |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sun Jan 23, 2022 10:37 am Post subject: Re: Shift tube hits top adjuster |
you can try the nut first but i am thinking you may have to cut the rod and box it in for clearance _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sun Jan 23, 2022 11:26 am Post subject: Re: Shift tube hits top adjuster |
Is this thread for real?
To me it is the same as hey - I piled boxes in front of the garage because I wanted to but now my car is blocked and I can't get it out of the garage. Can I get the car out or do I need to move the boxes back to where they were before and unblock the car?
Look at the freaking bend in the shifter rod. Put in a stock beam if you want stock height, or like Skills said, box the shift rod. There could be other answers in the lowering sticky. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jan 23, 2022 12:51 pm Post subject: Re: Shift tube hits top adjuster |
SGKent wrote: |
Look at the freaking bend in the shifter rod. Put in a stock beam if you want stock height, or like Skills said, box the shift rod. There could be other answers in the lowering sticky. |
Thanks sgkent. Can't believe I never thought of that. I mean for the price of a new beam and all the work it would take to replace the beam, this is the obvious answer to my problems. Not cranking the adjusters up and trying to make the one I have work. |
Posted: Sun Jan 23, 2022 3:27 pm Post subject: Re: Shift tube hits top adjuster |
You might be able to put a zig zag in the shift rod so it runs to the side enough to clear the nut, or just deepen the existing bend. Either way your shift rod will end up about 1/8" shorter which shouldn't hurt much. |
SGKent Samba Member
Posted: Sun Jan 23, 2022 3:37 pm Post subject: Re: Shift tube hits top adjuster |
Jjones659 wrote: |
SGKent wrote: |
If you go over to the lowering thread and search it, you may find others who have gone thru it and come up with solutions. Those people could be long gone now and never come here anymore so they won't read your post, but they may have left a thread on how they solved it. You can also talk to the manufacturer of the beam and see if they have suggestions. Good luck. I've never had much luck putting square pegs into round holes without some fabrication involved. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
kaiisons Samba Member
Joined: January 07, 2012 Posts: 77 Location: Sydney, Australia
Posted: Sun Jan 23, 2022 6:14 pm Post subject: Re: Shift tube hits top adjuster |
mark the range of the rod where the nut touches the rod (lol) and just hammer it flat - doesnt look like its touching by much. |
Elibomrod Samba Member
Posted: Mon Jan 24, 2022 9:56 am Post subject: Re: Shift tube hits top adjuster |
Yep mine did that when I changed the beam
Here in the uk they do a special shift Rod with extra big kink for clearance
See www.justkampers.com
Gear Rod for Adjustable Front Beam VW T2 Bay 1967-1973
JK PART NUMBER: J42805
OEM PART NUMBER: 211-711-155/D
Sorted it for me… |
SGKent Samba Member
Posted: Mon Jan 24, 2022 10:04 am Post subject: Re: Shift tube hits top adjuster |
Elibomrod wrote: |
Sorted it for me… |
There you go, 2 left. Lots of that odd stuff is fabricated in Lithuania, Ukraine, Estonia. etc and reboxed in the UK or DE so best get it soon.....
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Jan 24, 2022 11:09 am Post subject: Re: Shift tube hits top adjuster |
Looks like some Ebrake cable clearence issues too. |
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
Posted: Mon Jan 24, 2022 11:58 am Post subject: Re: Shift tube hits top adjuster |
I had this same issue with my beam. I first clearanced the stock shift rod to clear the adjuster, but did not box it in for support. I figured the force on the rod was minimal, but I ended up snapping the shift rod in half shifting normally. I then purchased the CSP shift rod made for this issue:
https://www.csp-shop.com/en/brand-shops/front-shift-rod-bus-711-155-211v-27632c.html
It's a great piece and well worth the money unless you are going to fabricate your own. Highly recommended. |
Posted: Mon Jan 24, 2022 1:54 pm Post subject: Re: Shift tube hits top adjuster |
Thanks guys. I didn't know they made a shift rod for this problem. I'm going to get one ordered! |
