lizs5150 Samba Member
Posted: Sun Jan 23, 2022 12:58 pm Post subject: 74 VW Steering wheel replacement to older models |
After years of searching to find my 74 VW Ghia and the years being spent on getting to rebuild it, one problem exists that I would like to get some feedback upon. That is, how can I go about and replace the plastic steering wheel to an older style OEM? Has anyone done this? Since the whole shaft is out all the way to the steering box, I am starting from scratch.
Welcome your feedback! |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Sun Jan 23, 2022 11:55 pm Post subject: Re: 74 VW Steering wheel replacement to older models |
If you want a 59-71 one (the one with the half ring), theoretically you can bolt it up, the problem is the wiper stalk (it collides with the wheel spokes).
So either you shorten the stalk, or go aftermarket. I did this to a bug and it worked, but you could see on the stalk that it was modified. Maybe welding it and grinding away the excess works better.
It seems that some company (I forgot, maybe Flat4?) specifically makes an old-style wheel for the newer cars after 72 but don't have any experience with that.
I mounted a 55-57 steering wheel on mine, but only with major modifications so a wheel hub (and 3D printed cover), to make it fit.
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Posted: Mon Jan 24, 2022 6:51 am Post subject: Re: 74 VW Steering wheel replacement to older models |
Vlad, first off, GEORGEOUS! Well done. I'll take your suggestions and see what I can do to get an aftermarket wheel here. As this design is exactly what I am looking for. Again, great work and keep the suggestions coming! |
