How long has your gas water heater lasted you |
0-5 years |
4% |
[ 2 ] |
5-10 years |
12% |
[ 5 ] |
10-15 years |
9% |
[ 4 ] |
15-20 years |
24% |
[ 10 ] |
20+ |
48% |
[ 20 ] |
Total Votes : 41 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Wed Jan 26, 2022 2:03 pm Post subject: Re: how long has your gas water heater lasted? |
I just replaced a cheepo 1985 water heater last year. I bet the new Rheem doesn't last 10 years |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Tue Feb 01, 2022 3:13 am Post subject: Re: how long has your gas water heater lasted? |
Replaced a Water Heater in every house I ever owned.
Thinking 15 years is a long life for a water heater and Hard Water. _________________ Good Luck
Al |
Abscate Samba Member
Posted: Tue Feb 01, 2022 4:21 am Post subject: Re: how long has your gas water heater lasted? |
You should run it twice a year out the tap in the bottom , for about 10 minutes , to remove sediment. _________________ .ssS! |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Tue Feb 01, 2022 7:31 pm Post subject: Re: how long has your gas water heater lasted? |
Our gas water heater was in our house when we bought it in 1989. SoCal "hard" water but still going strong. |
Randall Samba Member
Joined: October 03, 2004 Posts: 1403 Location: Orange County, Alta California, El Norte
Posted: Fri Feb 04, 2022 5:46 pm Post subject: Re: how long has your gas water heater lasted? |
Mine has a date of 1996 on it, making it 26 years. It's a 40 gallon Reliance brand. The only part I had to replace was the thermocouple next to the flame, costing less than $10 plus my own labor.
The heater is located in the garage near the washing machine. If I'm washing whites in hot water the heater makes gurgling cracking sounds as it reheats after the washer fills. I don't know if that's a bad sign. |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Feb 04, 2022 6:11 pm Post subject: Re: how long has your gas water heater lasted? |
Calseeum/Lime build up _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Feb 04, 2022 6:52 pm Post subject: Re: how long has your gas water heater lasted? |
Cusser wrote: |
madmike wrote: |
Calseeum/Lime build up |
Calcium. You used the Mark Tucker spelling. |
Posted: Fri Feb 04, 2022 7:47 pm Post subject: Re: how long has your gas water heater lasted? |
Jon Schmid wrote: |
Cusser wrote: |
madmike wrote: |
Cusser fell into the Sar-chasm _________________ .ssS! |
typ914 Samba Member
Joined: October 19, 2012 Posts: 231 Location: Atlanta, Ga
Posted: Sat Feb 05, 2022 5:21 am Post subject: Re: how long has your gas water heater lasted? |
I have a commercial grade hot water heater. I believe it is an 80gal model. It was 5 years old when I got it and it’s about 12 years old now. We never run out of her water and the gas bill has not gone up on bit. Despite being twice the size is it is a lot more efficient than a residential model and we are well below its rated use. Down side these run about $4 grand new. I did not pay no where that much. |
Posted: Sat Feb 05, 2022 5:28 am Post subject: Re: how long has your gas water heater lasted? |
I did But lets talk water heaters ,I have two one is just a 'Pre-eater' I have it flowing out of the bottom tap where u would normally drain it from to a circulating pump,into a 50" copper coil (mounted in plaster of Paris)on top of the woodstove re-turn to the top of the waterheater then to the gas waterheater,,,clear as mud right?(got the plans from Mother earth news years ago) so we have like 80 gallons on tap my Gas (propane) tank hardly kicks on _________________ 'Black Ice'Drag Buggy 'Turbo'
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Sat Feb 05, 2022 11:08 am Post subject: Re: how long has your gas water heater lasted? |
madmike wrote: |
I did :lol: But lets talk water heaters ,I have two one is just a 'Pre-eater' I have it flowing out of the bottom tap where u would normally drain it from to a circulating pump,into a 50" copper coil (mounted in plaster of Paris)on top of the woodstove re-turn to the top of the waterheater then to the gas waterheater,,,clear as mud right?(got the plans from Mother earth news years ago) so we have like 80 gallons on tap :lol: my Gas (propane) tank hardly kicks on :wink: |
2 tanks and woodstove, nice.
Friend did a copper coil around the 2.5" hot water return line from the old school hot water radiator system in Brooklyn NY. Water out of boiler was 180, water back in was 100. Thus the water supply line to the gas hot water heater was preheated.
The hot water supply/return pipes were large enough that the system naturally circulated, and the pump only ran on the coldest days. Whoever installed it in the early 20th century has their shit together. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Posted: Sat Feb 05, 2022 2:57 pm Post subject: Re: how long has your gas water heater lasted? |
I ackully have another copper coil in the roof of the wood furness ,, to heat my floors (pex tubing) bathroom,sunroom and kitchen _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Sat Feb 05, 2022 4:23 pm Post subject: Re: how long has your gas water heater lasted? |
my59 wrote: |
madmike wrote: |
I did But lets talk water heaters ,I have two one is just a 'Pre-eater' I have it flowing out of the bottom tap where u would normally drain it from to a circulating pump,into a 50" copper coil (mounted in plaster of Paris)on top of the woodstove re-turn to the top of the waterheater then to the gas waterheater,,,clear as mud right?(got the plans from Mother earth news years ago) so we have like 80 gallons on tap my Gas (propane) tank hardly kicks on |
The hot water supply/return pipes were large enough that the system naturally circulated, and the pump only ran on the coldest days. Whoever installed it in the early 20th century has their shit together. |
And people now know why they are called hot water heater _________________ .ssS! |
Posted: Fri Mar 11, 2022 5:52 am Post subject: Re: how long has your gas water heater lasted? |
I'm going to eliminate my Propane Bill altogether,,,, The plan is to add a 'Water Jacket' to my cook stove to Thermosiphon to a short 40 gal. tank 'no pump'
Problem is the Factory made Jacket is almost a $1000 so looking at a welded up stainless steel Jacket made by a Local 'Welder',, I have a Nice sheet of stainless in my stash,,Cheers,Mike _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Fri Mar 11, 2022 6:30 am Post subject: Re: how long has your gas water heater lasted? |
I had an apartment in a buffalo with hot water included , not heat
You guessed it. I got a car radiator from a junkyard and on cold snaps ran hot water through it to heat the place
I was a total savage back then. Horrible. Do better by not being me _________________ .ssS! |
tcmia Samba Member
Joined: April 30, 2019 Posts: 212 Location: Cleveland TN
Posted: Fri Mar 11, 2022 6:44 am Post subject: Re: how long has your gas water heater lasted? |
Our gas water heater is over 20 years old. It came with the house when we bought it 20 years ago and still works fine. I do take the sediment out every so often when I remember.
At work we have replaced the gas water heater 3 times in the last 10 years. They all started leaking realy bad. Some on the bottom area, or the top. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Fri Mar 11, 2022 1:25 pm Post subject: Re: how long has your gas water heater lasted? |
propane gas, heater was $1600, installed- hope it lasts another 22 years - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sun Mar 13, 2022 4:51 am Post subject: Re: how long has your gas water heater lasted? |
$1600 Gold plated Stainless Steel? So glad I can do 'Plumbing' myself
I did my whole House,,,Electrical Wired it too _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Mon May 02, 2022 4:52 am Post subject: Re: how long has your gas water heater lasted? |
I'm having my "Welder' make us a 'Water Jacket' for our stove , I picked up a newish Electric H.W. Tank for $150, and another $150 in 'Plumbing' .I'm just waiting on the welder I'm in the middle of 'Mock up" This will be a Themosyphom system ,no electric pump needed, I'm boxing in the tank with some nice Tongue & Groove Pine, Hoping this system will eliminate our 'Gas' Bill Here's a Photo with a few VW Toys,
