77Campmobile Samba Member
Joined: June 18, 2006 Posts: 102 Location: New Hampshire
Posted: Tue Jan 25, 2022 5:33 pm Post subject: A-Pillar Repair/Replacement Help Needed |
My pillar and everything surrounding it was completely rusted out. I probably should have been more strategic in my repair and left more of it intact as I went but I'm beyond that now. The entire a-pillar was removed from just below the lower hinge down.
I purchsed Schofield's 3-piece A-pillar repair panels but they don't line up correctly with the remaining body metal. The flanges come up short and or the bends are off, it's a nice looking 3-piece set but it just isn't fitting.
Anyone do a complete a-pillar rebuild that could shed some light on the process? Pictures and dimensions would be helpful too. I have my new dog log test fit in pretty well so I just need to get the a-pillar sorted now so I can finish it.
I'll get some pictures tomorrow showing the issues. |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Wed Jan 26, 2022 10:59 am Post subject: Re: A-Pillar Repair/Replacement Help Needed |
here, right?
i only had to replace the inner-most piece, so i bent up some pieces to fit and welded them in. sounds like your up against multiple layers of rot. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Jan 26, 2022 11:19 am Post subject: Re: A-Pillar Repair/Replacement Help Needed |
This is how you need to support the nose before cutting it off. But maybe it's too late in your case. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Wed Jan 26, 2022 11:52 am Post subject: Re: A-Pillar Repair/Replacement Help Needed |
The Schofields pieces arent perfect, but that is the price you pay for thicker metal - it cannot curve round such tight bends.
I minimised the amount I had to chop off the A pillar..
This shows my chopping en-route to fitting Schofields replacements.
And after - the fit is not perfect but better than a rusty hole.
_________________ Ancient vehicles and vessels
Posted: Wed Jan 26, 2022 2:40 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
Globespotter wrote: |
Hinges? An A-pillar is the roof support to the left or right of the windshield.
Are you talking about the door frame?
EDIT: I think you mean A-Post |
Yes, A-Pillar/A-Post whichever you prefer, it is all one continuous piece from the bottom to the top from the factory. I am only looking at the bottom 6 inches or so which rusted out. |
Posted: Wed Jan 26, 2022 2:41 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
Jetfxr69 wrote: |
here, right?
i only had to replace the inner-most piece, so i bent up some pieces to fit and welded them in. sounds like your up against multiple layers of rot. |
Yes exactly. Is yours still exposed like this or have you repaired further? I could use the two measurements shown. From the bottom edge of the hinge to the bottom of the post and the width of the bottom post from the flange to the back face.
EDIT: Just realized you have a different hinge than I do so the height may not measure the same. From what I can tell so far it is somewhere between 5 and 5.5 inches just trying to narrow it down. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Wed Jan 26, 2022 6:01 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
jtauxe wrote: |
This is how you need to support the nose before cutting it off. But maybe it's too late in your case. |
I didn’t support mine when I removed my ‘79’s nose and it all went back together with no problems.
https://www.thesamba.com/vw/forum/viewtopic.php?t=194787 _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Wed Jan 26, 2022 6:20 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
Joey wrote: |
jtauxe wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=194787 |
I'm not removing the nose or the a-pillars/posts. I am only repairing the post below the bottom hinge and all other panels that join it. Thanks |
Posted: Wed Jan 26, 2022 6:41 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
I think I made a little progress today but so far I have had to cut up and reshape/size these schofield repair panels a bit. Everything is only getting tacked in or cleco'd until I can fit all of the panels together including the wheel arch and bumper parts. If I have to I will remove pieces again once aligned in order to finish welding.
Here is the outer a-pillar section fit up. This needs to be co-planer with the whole a-pillar so check well with a straight edge. Also the bottom section of the pillar sweeps backwards aprox. 4 degrees just above the bottom of the hinge. There is a black sharpie mark right about where this bend starts.
I had to cut off the front flange on the outer pillar section as it did not align with the existing metal. I sectioned about an 1/8 out of it and tacked it back on as shown by the three tack welds here. The bottom plate is test fitted with clamps but I think it is too far towards the bumper maybe?
Should this bottom plate mate up with the front lip of the bumper as shown in this pic? It seems to leave the outer pillar section overhanging the flange quite a bit.
The inner pillar panel doesn't line up well at all, it seems the bends in the panel are not quite right maybe, I'm not sure yet as it still needs some trimming. This was just a quick fit as the last thing I did today. In order to line up with the outer edge of the nose skin there is a large gap to the outer pillar at the flange.
Couple additional pics:
Posted: Wed Jan 26, 2022 9:20 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
looks like you got it figured out. mine is off an early ‘76 and you noticed they have different hinges, but the length to the bottom of your post should be the same. im home from work tomorrow late and can measure up anything you need before you final weld if needed. i would assume that even if the hinges are slightly different, that the measurement from a reference point higher up would work too.
i could clamp a straight edge off the bumper frame and measure down from there. mine is still doorless, so easy-peasy. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
Tvättbjörn Samba Member
Posted: Wed Jan 26, 2022 10:13 pm Post subject: Re: A-Pillar Repair/Replacement Help Needed |
are the Schofields replacement panel the same thickness like the factory or thicker? |
Posted: Fri Jan 28, 2022 10:31 am Post subject: Re: A-Pillar Repair/Replacement Help Needed |
Tvättbjörn wrote: |
They seem to be thicker than the stock metal. |
