richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Thu Jan 27, 2022 8:21 pm Post subject: Who is kind enough to tell me about this radio? |
I’ve had this radio in my stash for at least 10 years. I don’t know where is came from or why I kept it. I think it came with my old ‘68 tin top, although it wasn’t in the bus and was probably in a box of parts. So my guess is that it’s a old bus radio. I guess I kept it because I figured for the minimal amount of money I could get for it I should just keep it.
Fast forward to today and I remembered I had it and thought it might be a good fit in the ‘65 Beetle I built or am building, which ever way you want to look at it. The car is running, driving, registered and insured. The car has been changed to 12 V and I’d like to install this radio and run a RediRad system with it.
My guess is it’s a 12V radio and uses one speaker. What do the symbols mean next to the wires and how do I go about bench testing it?
Thanks,
Rich P
https://redirad.com/ _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Jan 27, 2022 8:29 pm Post subject: Re: Who is kind enough to tell me about this radio? |
From the left
Antenna
Ground stud
Power spade
Speaker
I’d throw 12v to it and hook up the rest of the connections. But I’m a thrill seeker and you’re on your own _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy Samba Member
Posted: Thu Jan 27, 2022 8:31 pm Post subject: Re: Who is kind enough to tell me about this radio? |
This'll decode what the terminals do: https://www.thesamba.com/vw/archives/manuals/blaupunkt_wolfsburg_iii.php
Edit: As for the radio itself I run the single band version in my 71, it's an excellent unit, super simple and robust with great reception, and the red light in the dial reminds me to turn it off when I leave. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 27, 2022 8:47 pm Post subject: Re: Who is kind enough to tell me about this radio? |
Thanks guys!
Busdaddy, that link has a lot of German in it. Is the post the ground and the upper wire the ground, or negative for the speaker? I’m reading that diagram as the upper wire is the battery negative.
Is that a AM/FM radio? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
olorin67 Samba Member
Joined: October 20, 2021 Posts: 79 Location: Milwaukee, WI
Posted: Thu Jan 27, 2022 8:48 pm Post subject: Re: Who is kind enough to tell me about this radio? |
. It’s a European radio, with medium wave band. No FM |
Posted: Thu Jan 27, 2022 9:31 pm Post subject: Re: Who is kind enough to tell me about this radio? |
Rich,
Without making you read a wiring diagram I’m going to give it to you again
Plug in the co-ax antenna connection into the hole
Those two wires that are cutoff short go to one speaker. Doesn’t matter how you connect them since this radio isn’t stereo.
The post with the nut serves two purposes, one is to secure the radio to structure via a (plumbers tape) type bracket and the second is to serve as the negative return to chassis (battery) ground.
The male spade connection is for + 12V from power (fused)
Car radios really don’t get any simpler _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Jan 28, 2022 7:16 am Post subject: Re: Who is kind enough to tell me about this radio? |
Thanks guys.
RediRad sells two systems for AM only radios. One is for an AM-band radio that works with a POSITIVE ground electrical system and one is for a an AM-band radio that works with a NEGATIVE ground electrical system. I’m guessing this car being 12V, it’s a positive ground electrical system. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Fri Jan 28, 2022 8:22 am Post subject: Re: Who is kind enough to tell me about this radio? |
Nope, VW's (and most German things) are negative ground, positive ground is only found on British cars and some super early Japanese stuff. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Xevin Samba Member
Posted: Fri Jan 28, 2022 10:01 am Post subject: Re: Who is kind enough to tell me about this radio? |
richparker wrote: |
Thanks guys.
RediRad sells two systems for AM only radios. One is for an AM-band radio that works with a POSITIVE ground electrical system and one is for a an AM-band radio that works with a NEGATIVE ground electrical system. I’m guessing this car being 12V, it’s a positive ground electrical system. |
That RediRad is cool. My friends 1941 Chrysler is Positive ground. Would be nice to have. I just sent him the link. Cool radio Rich. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
KTPhil Samba Member
Posted: Fri Jan 28, 2022 12:33 pm Post subject: Re: Who is kind enough to tell me about this radio? |
That will pick up normal AM, but the other band is only used now for beacons (naval, air), and will be useless. |
raygreenwood Samba Member
Posted: Fri Jan 28, 2022 2:16 pm Post subject: Re: Who is kind enough to tell me about this radio? |
I have one of those. It was origibal in my 412....installed in Frankfurt on delivery.
As others have stated.....its listed as medium wave and longwave.
In the 60s and 70s in central Europe and Eastern Europe there was plenty of broadcast on longwave. Pretty much an equivalent to am broadcasting.
Longwave is below medium wave the ITU (international telecommunications union) used it at 30 to 300 khz....and medium wave (which is technically am) starts at 520 khz. and runs to 1700 in North America.
For the year or so I had this in the car I listened to am....which is picks up well.
The long wave.....well.....I could get some interesting pieces of sound here and there depending on weather and time of year. There is a segment or band in the US that is open to radio experimenters. Also i got a few crusty snippets of foreign language especially in the mountain top areas on trips from Atlanta to Chatanooga.
If you want to play to see what it can get on the long wave.... check this out
Info on long wave transmitters in North America
https://nofars.net/jacksonville_radio_collection/long_wave_radio
European amd other world wide long wave transmitters
https://www.chemeurope.com/en/encyclopedia/Longwave.html#List_of_longwave_broadcasting_transmitters
More about the radio you have
https://www.radiomuseum.org/r/blaupunkt_wolfsburg_iii_7638060_ser.html
When you shine up that chrome face plate and the knobs.....its almost an art deco style very pretty radio.
Ray |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Fri Jan 28, 2022 4:43 pm Post subject: Re: Who is kind enough to tell me about this radio? |
I've often wondered. What do the letters on the buttons stand for? _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Posted: Fri Jan 28, 2022 5:04 pm Post subject: Re: Who is kind enough to tell me about this radio? |
L & M buttons switch bands and the musical note symbol changes the tone from tinny to bass like (voice VS: music), the last one turns it on and off (symbol worn off on that one).
As Ray mentions they are a sharp looking unit when clean, almost out of place in a bus, more suited to a fancy Mercedes or some other higher end car. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KTPhil Samba Member
Posted: Sat Jan 29, 2022 11:36 am Post subject: Re: Who is kind enough to tell me about this radio? |
Interesting that this (usually) non-USA radio has the Conelrad (civil defense) markers on the AM band (640 and 1240).
I am not sure what the black dots on the AM band are for.
The red triangles are movable markers to guide you to your favorites, helpful since there are no "pre-selection" buttons on this radio. |
Mberglo Samba Member
Joined: January 13, 2020 Posts: 383 Location: Huntsville, AL
Posted: Tue Feb 01, 2022 7:42 am Post subject: Re: Who is kind enough to tell me about this radio? |
Thats a cool radio to fill the hole in the dash. Then go get a Bluetooth Amplifier and just play tunes through your iphone.
Frederik Samba Member
Posted: Tue Feb 01, 2022 7:47 pm Post subject: Re: Who is kind enough to tell me about this radio? |
As to the information I have from vw (workshop manual) and Bosch (news letter), from August 1966 (model year -67) radio was an option from factory (Europe, non-US?). At the same time they got the pre-drilled hole for antenna.
From Aug. 1966 you could choose from vw-radio modell:
"Wolfsburg"
M (mid wave="AM"): 519-1640 kHz
L (long wave): 150-290 kHz
"Emden"
M (mid wave): 519-1640 kHz
U (Ultra Short wave="FM"): 88-108 MHz
The fine fuse (2A) was not installed in the radio inline fuse holder at the production line and was at delivery in the glove box and should be installed on delivery inspection as well as antenna trimming should be done.
[Interestingly the U/FM band went up to 108. European sold radios at the time, at least from blaupunkt that was the manufacture of the vw-radio, usually only went to 104. I guess they planned on selling the same radio through dealers in the US.]
From Aug. 1967:
"Emden"
got the addition of L (long wave): 150-290 kHz and built in electronic fine tuning on U/"FM"
"Wolfsburg"
got one more "tone" button [like yours, the two left buttons are a note and a "up side down" note, previous only had 3 buttons: "note", "M" and "L"]
M (mid wave) was now: 515-1620 kHz, U (Ultra Short wave="FM"): 87.6-108 MHz. Both got the 2 manual "favorite station" red markers, was rated as 4W and were now only availible in 12V (not the selectable 6V/12V)
From Aug. 1968
The new "Braunschweig" was an option.
It had L, M and U band, the "omnimat" (pre-select "favorites") L, M, M, U, U push buttons, tape deck input (DIN-socket) and tone was controlled with pull/push function in the left turn knob.
By the way the "III", Z in the serial and blaupunkt part number 7 638.. on your radio makes me to belive it's from 1968. They were used on all models I think.
Posted: Tue Feb 01, 2022 8:14 pm Post subject: Re: Who is kind enough to tell me about this radio? |
If you look in non-US drivers manuals under archive you find some info on the the functions:
Posted: Mon Feb 07, 2022 9:08 am Post subject: Re: Who is kind enough to tell me about this radio? |
Funny, I kept thinking that radio looked too familiar, so I went to the bins and found these.
73 Thing
72 Baja |
