Brake pedal moving side to side
cln60ragfk
cln60ragfk is offline
PostPosted: Fri Jan 28, 2022 5:29 pm    Post subject: Brake pedal moving side to side Reply with quote
Just bought a 63 single cab and without looking underneath, the brake pedal moves side to without pressing it to engage the brakes.
What could the pedal assembly be missing to cause this?
Appreciate the help
FOLKS
busdaddy
busdaddy is offline
PostPosted: Fri Jan 28, 2022 5:38 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
Important bolts?, non worn bushings?, regular lubrication maintenance?
I'd be looking into that ASAP myself, sounds potentially scary.
Слава Україні!
cln60ragfk
PostPosted: Fri Jan 28, 2022 5:50 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
Good start. Bus was supposed to have new brakes which means new shoes etc but something isn’t right with the pedal assembly
FOLKS
Eric&Barb
Eric&Barb is offline
PostPosted: Fri Jan 28, 2022 8:46 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
If that pedal is a problem, what else is suspect? Only two ways to tell:
1. Wait till a succession of things fall apart leaving you in a lurch, crashed, or running thru a red light when the brakes do not work.
2. Get under the bus and start going thru everything. That way you avoid being one of those owners that is always waxing about how unreliable their VW is/was.
Once met a fella who had pulled about two weeks previous out a bus from where it had sat for many many years in a back yard. We told him to go thru the brakes, change the transaxle gear oil, inspect front wheel bearings and repack with new grease. He told us we were full of it, a week later he called because the passenger front spindle had sheared off at highway speed. Probably because the old grease could not lubricate the bearings anymore, and so the one or both of the bearings on that side welded themselves to the spindle and tore it off. Good times......
In Stereo, Where Available!
cln60ragfk
PostPosted: Fri Jan 28, 2022 10:09 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
Thank you
FOLKS
Eric&Barb
PostPosted: Sat Jan 29, 2022 12:11 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
If you do not yet have a copy of the transporter workshop manual that was back in the day supposed to be used only by the VW dealer mechanics, then get a copy ASAP. Yes it is more expensive than any other bus repair manual, but it has four or five times more info. Good used copies do show up in the classifieds now and then, so best to search at least daily there.
You can access thru the link below the parts manuals with lots of fantastic exploded diagrams, and a lot more other need to know info:
http://www.oacdp.org/
That will show what parts are supposed to be there, and you can use the parts numbers to search online for them.
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jan 29, 2022 6:47 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
Is the movement the whole pedal assembly going on through the floor sliding side to side or is it just the foot pad part tipping side to side or some other description?
cln60ragfk
PostPosted: Sat Jan 29, 2022 7:18 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
It’s the whole pedal assembly coming through the floor
FOLKS
campingbox Premium Member
campingbox is offline
PostPosted: Sat Jan 29, 2022 10:45 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
It sounds like something is loose or a part is missing.
I would suggest review the online parts list and compare it to what is installed.
62DoKaGuy
62DoKaGuy is offline
PostPosted: Sat Jan 29, 2022 10:54 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
I had a similar thought to Greg’s point: the return spring not being fully or properly seated on the seat (shallow bowl-shaped washer-like mamajama -proper nomenclature). Installed an assembly before without confirming proper seating of the spring at the seat and had a wobbly sensation when bleeding. Couple minutes later, I properly seated the assembly and voila. Basta.
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
cln60ragfk
PostPosted: Mon Jan 31, 2022 10:59 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
That’s what I’m thinking. Just wanted to see if something else might be the issue
FOLKS
cln60ragfk
PostPosted: Mon Jan 31, 2022 11:00 pm    Post subject: Re: Brake pedal moving side to side Reply with quote
Maybe that’s it. It’s probably something simple like that
FOLKS
