Blanco_Bug72 Samba Member
Joined: October 08, 2021 Posts: 19 Location: South Dakota
Posted: Sun Jan 30, 2022 3:23 pm Post subject: Side view mirror |
Hello,
I'm about halfway done with a 1972 super beetle restoration/build. I want to register it so I can drive as needed so will need to add a sideview mirror. A previous owner deleted the mirrors, including the mounting holes. Does anyone know of a kit that would allow me to add a mirror and just drill smaller holes? Or similar? |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Mon Jan 31, 2022 11:54 am Post subject: Re: Side view mirror |
If the door is apart, you might identify where the old hole was and just drill a new hole there. Chances are, they didn't remove the female threads welded inside the door. Otherwise, you can probably find something you like and just bolt it on. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Tue Feb 01, 2022 1:17 pm Post subject: Re: Side view mirror |
They sell female "nut plates" to slide or glue up in the doors for factory mirror mounts.
My passenger triangular nut plate is loose up in my passenger door, but has the stock passenger mirror attached to it. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
bomberbob Samba Member
Posted: Thu Feb 03, 2022 1:33 pm Post subject: Re: Side view mirror |
My bug was missing the internal nut inside the passenger door. I bought a nut with the right size and pitch, and JB-welded it inside. Its not easy, you slop the glue on there and then with long needle nosed pliers you reach it in there and hold it while the 5 minute epoxy cures. I think I remember also running a piece of string thru the hole and the nut to help guide it in to its intended position. After it cured I let it go a day before I screwed the mirror in. Worked fine. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
candyflame73 Samba Member
Joined: September 03, 2005 Posts: 430 Location: Texas
Posted: Thu May 11, 2023 12:24 pm Post subject: Re: Side view mirror |
Hinge pin mounted mirror is another option, unless you don’t like the look. Hinge mounted mirrors on my 73 Super.
