kintail Samba Member
Posted: Wed Jun 23, 2004 8:50 pm Post subject: Barndoor 16" rims - two types |
Looking at two sets of barndoor rims today..... the 1/53 set has the inner rim welded to the outer.
The 3/53 set has the inner rim riveted to the outer and an indent stamped in the rim for the air valve. Can't find anything in the T2 Spec guide on the rim difference or anywhere else for that matter.
So the question for the Barndoor fanatic is.... was there a supplier change during this time frame or did VW take wheels from two suppliers when building the barndoors?
Scott |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Thu Jun 24, 2004 1:29 am Post subject: |
yes vw used two manufactures for wheels, one used a welded construction and the other a riveted construction, people think the rivited wheels predate the welded, but they were both manufactured at the same time, the barndoor size is 16 3.5, and should have 5.50 16 tyres. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
Posted: Thu Jun 24, 2004 7:31 pm Post subject: |
Thanks for the info....
Here's what it says on the rivetted rims:
4 53 KRONPRINZ 3.50D X 16 DIN with a time expired Goodyear bias ply 6.00 - 16
Scott |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Jun 25, 2004 1:27 pm Post subject: |
I need two riveted 15" bus rims if you guys bump into spares....they need to be in good condition. |
FBIVW Samba Member
Joined: August 13, 2002 Posts: 221 Location: Gower, South Wales. UK
Posted: Wed Aug 22, 2012 1:57 pm Post subject: 16's |
Is it fair to say the 3.5's x 16" with the valve indent and drilled hole opposite are early barndoor or?? |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Thu Aug 23, 2012 12:50 am Post subject: |
I think the indent around the valve makes it an earlier wheel _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
FBIVW Samba Member
Posted: Thu Aug 23, 2012 1:52 am Post subject: 16's |
I thought so too but hearing that they are around with indent and 53 year stamp makes them slightly later than I thought.. I'll poke around for a date on them.. |
bubba Samba Member
Posted: Thu Aug 23, 2012 5:35 am Post subject: |
Scotty wrote: |
I think the indent around the valve makes it an earlier wheel |
Scotty , I don't know about that??? My 50 (dated 3/50) didn't have indents... I think it was the different makers maybe? Not 100% sure... _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
FBIVW Samba Member
Posted: Thu Aug 23, 2012 5:55 am Post subject: |
Just found a jan 51 date stamp on one of mine. They are all Kronprinz riveted ones. Date stamps are faint on these early ones. |
Tonny_Larsen Samba Member
Posted: Thu Aug 23, 2012 9:04 am Post subject: |
bubba wrote: |
Scotty wrote: |
Scotty , I don't know about that??? My 50 (dated 3/50) didn't have indents... I think it was the different makers maybe? Not 100% sure... |
And mine are dated 2-50, and have not the indents
http://www.thesamba.com/vw/forum/viewtopic.php?t=272114
Tonny |
thenastyfasty Samba Member
Posted: Fri Aug 24, 2012 10:19 am Post subject: |
Just to add more confusion to this i have 3! types of barndoor 16s in my garage, i have the welded type and the riveted type as mentioned already but i also have one thats like the welded type without the indent for the valve hole but its riveted in 4 places were the welds should be, the date is unreadable as is the make _________________ 67 fastback rhd
54 barndoor singlecab M88 lhd lh locker
92 polo coupe
89 polo fox
77 polo ls
90 honda 125 caferacer |
FBIVW Samba Member
Posted: Fri Aug 24, 2012 11:47 am Post subject: |
We know the non valve indented wheels come riveted or welded it depends which manufacturer produced them. (Kronprinz riveted / Lemmertz welded)
As far as I have observed the valve indented wheels are all riveted. |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sat Aug 25, 2012 3:11 pm Post subject: |
Don't forget about Fudrad made wheels which have a slight difference inthe offset of the centers from the barrel. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Scotty Samba Member
Posted: Tue Aug 28, 2012 5:31 am Post subject: |
Looks like I'm wrong then. It was a long time ago when I heard that rumour _________________
EverettB wrote: |
peter schepens Samba Member
Joined: April 17, 2003 Posts: 1014 Location: belgium Caesars camp
Posted: Tue Aug 28, 2012 9:41 am Post subject: |
gatorwyatt wrote: |
Don't forget about Fudrad made wheels which have a slight difference inthe offset of the centers from the barrel. |
Actualy it is Südrad. Cheers. _________________ Zelensis, glassfibre body made in Belgium , disigned and built on a VW platform About 25 body's built.
Hebmuller info wanted for http://www.hebmueller-registry.com/home.html |
