Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 202 Location: Varberg - Sweden
Posted: Wed Feb 02, 2022 12:52 am Post subject: Lug nuts for Erco wheels |
Hi, the normal lug nuts are 60 degree taper, or R14 ball radius. My Erco wheels have a 90 degree taper machined into them, and i am having no luck finding nice, black open end M14x1.5 lug nuts for them. Has anyone else had the same problem?
I have some porsche open end lug nuts with a radius (ball) seat, i chucked one in the lathe and ground a 90 degree taper with the tool post grinder, but since they are hardened it takes forever... but i guess if i cant find something suitable to buy i just may have to go that route, but i would like to avoid it if possible. So if anyone has any ideas or sources of 90 degree taper lug nuts, throw them out here please |
Typ3nut Samba Member
Joined: October 08, 2002 Posts: 1192 Location: MI, MotorCity ManCave
Posted: Thu Feb 03, 2022 11:45 pm Post subject: Re: Lug nuts for Erco wheels |
Thanks for the tip, the first link did not have any 90deg nuts, not in m14x1.5 atleast, i have not gone through the entire dorman calatolgue yet though |
Posted: Mon Aug 01, 2022 12:43 am Post subject: Re: Lug nuts for Erco wheels |
Figured i’d post an update/resolution to this; could not find any nuts that had the right taper, so i ended up machining all the lug nut seats in the wheels to R14 ball seat so that i could use standard lug nuts. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Mon Aug 01, 2022 7:35 am Post subject: Re: Lug nuts for Erco wheels |
I used these washers when I had Douglas spun aluminum wheels. Their flat on the backside. Not sure if Eric is the same.
_________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
