txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Jan 02, 2023 7:20 am Post subject: Re: Jay's 2275 build |
Do you have a welder? Could also weld a nut to the stud…just cover the case when doing so |
55rag Samba Member
Posted: Mon Jan 02, 2023 10:18 am Post subject: Re: Jay's 2275 build |
A welder has been on my wish list for years. I first have to pull electrical to my garage which is will not be an easy task. Maybe this year I'll get to it. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
Some beat up British bikes |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Wed Jan 04, 2023 2:09 pm Post subject: Re: Jay's 2275 build |
Take a nut and slice it across to make two thinner nuts, then use those, or keep filing down two nuts on one face until you can get at least three turns of thread from the second nut on top of the first.
Clean the thread and use green loctite on a nut threaded on the end -the stuff that doesnt come undone.
File two flats opposite each on the stud, then use an adjustable spanner.
Then get angry with a set of vise grips and simply wind out the old one _________________ Ancient vehicles and vessels
55rag Samba Member
Posted: Wed Jan 04, 2023 2:55 pm Post subject: Re: Jay's 2275 build |
Thanks for that suggestion Mikesjames, I'd probably cut my thumb off trying to cut a nut in two. haha Then I'd get angry at it for taking my thumb.
I did get that stud puller tool that TXoval suggested and it worked great. Did even mess up the threads. It will be handy to have in my tool box. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
55rag Samba Member
Posted: Tue Apr 18, 2023 8:38 pm Post subject: Re: Jay's 2275 build |
I'm back at it trying to get this motor together. I have some progress pictures along with some questions.
Yes, I'm using the cool tins. The sleds don't fit with the exhaust.
added the missing tabs to my heads.
I'm hoping this is my last mock up.
Test fitting a pushrod tube.
Cleaned and painted Cylinders. I scrubbed with brake cleaner about 3 time to get a clean cylinder and then coated with Total Seal dry lube. It turns green when the cylinder is clean. So I'm going to run these dry except put some assembly lube on the piston skirts.
All assembled and ready to go.....I think. What is the preferred method of clocking the rings? I didn't really pay attention other than putting them at 90 degrees apart. I've seen some people are putting the oil control at 12 o'clock and the two top rings at 10 and 2 o'clock.
I splurged and invested in these. Thanks Tabari
Too late but is this oil pickup a bad choice? Tabari mentioned most people swap them out because of the tight bend. I'm really just ready to assemble it at this point.
This plug is sticking out a bit but I didn't want to risk cracking the case. Does this look like a potential issue?
Wasn't paying attention when I was figuring out crank end play and caused this with a screwdriver while pulling the flywheel out. I should be able to clean it up no problem.
Thanks All, I'm hoping to have the short block buttoned up this week. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
txoval Samba Member
Posted: Wed Apr 19, 2023 5:34 am Post subject: Re: Jay's 2275 build |
The CB pickup tube is $20…you have spent a lot time on the engine and this is a smart upgrade to the POS that comes with the case.
Fix the damage to the cam plug now and don’t use screwdrivers or pry bars to remove the flywheel
If you need a flywheel puller make one or ask for one. I’ll send you mine just so you don’t do that again! |
55rag Samba Member
Posted: Wed Apr 19, 2023 9:13 am Post subject: Re: Jay's 2275 build |
Thanks txoval, I actually have a CB pickup but the tube diameter is larger than the one in the case.
No more screwdrivers for me. Do you have a link to a flywheel puller? I've didn't know there was one for the flywheel.
Thanks,
Jason _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
txoval Samba Member
Posted: Wed Apr 19, 2023 10:28 am Post subject: Re: Jay's 2275 build |
Need to make one…
https://youtu.be/fy_nLdiXWAw
Ron Lummus sells one but it’s $$$
I will seriously send you mine unless you’re done setting end play
The diameter should be the same |
55rag Samba Member
Posted: Wed Apr 19, 2023 11:42 am Post subject: Re: Jay's 2275 build |
Thanks for that. I've got my end play set so I shouldn't need it. I will do a last check before I put the seal in but I have it set for .004 now.
Any suggestions for piston ring gap orientation? And does that gallery plug look like it's not seated enough? It was pretty snug when I put it in.
Thanks,
67 Ghia vert
85 911
18 GTI
txoval Samba Member
Posted: Wed Apr 19, 2023 3:33 pm Post subject: Re: Jay's 2275 build |
That plug is on the oil pickup? Looks right if so |
55rag Samba Member
Posted: Wed Apr 19, 2023 5:07 pm Post subject: Re: Jay's 2275 build |
Yes, that's the large plug at the oil pump pickup. I have my rings oriented pretty close to the above diagram but I'm not sure I put the compression ring at the top so I'll pull them back out and check. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
55rag Samba Member
Posted: Sun May 14, 2023 7:36 pm Post subject: Re: Jay's 2275 build |
FINALLY!!!!! I got the motor glued up mostly.
Got all my parts lined up.
Working the 3/4 side first.
On to the 1/2 side.
Both sides done.
Everything went pretty smooth but if any of you use the Jaycee pushrod tubes on your builds I suggest having an extra set of hands to help push the head down while you get a few nuts on.
Next up I will have to pull my old motor out of the car so I can swap engine tin and head to powdercoating and getting some parts polished. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
Rafo67PE Samba Member
Posted: Mon May 15, 2023 7:49 am Post subject: Re: Jay's 2275 build |
good engine!!!
I have a similar one with 10.3:1 CR and web 86C |
55rag Samba Member
Posted: Mon May 15, 2023 9:00 am Post subject: Re: Jay's 2275 build |
Yes, I saw your post and hope mine sounds as good as yours. You have a great looking car. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Mon May 15, 2023 9:39 am Post subject: Re: Jay's 2275 build |
Why not use stock pushrod tubes on a fresh build? _________________ 74 Super
84 Westy |
55rag Samba Member
Posted: Mon May 15, 2023 11:56 am Post subject: Re: Jay's 2275 build |
I was going to use the CB wide mouth tubes but at the time they were out of stock. The JayCee's got good reviews from what I read so I went with them. Hoping I don't get any leaks. _________________ 55 ragtop bug
67 Ghia vert
85 911
18 GTI
Posted: Mon May 15, 2023 12:33 pm Post subject: Re: Jay's 2275 build |
I have a spendy set of CSP tubes (same idea as Jaycee). Have had them on for a year and no leaks. Need to pull the heads and re-seal cylinder bases, so I could put some stock tubes in, but these CSP tubes have proven to work well and it's nice not fumbling with the tubes when you're torquing the heads on, especially when I'm trying to get a good cylinder base seal. _________________ 74 Super
84 Westy |
txoval Samba Member
Posted: Mon May 15, 2023 4:14 pm Post subject: Re: Jay's 2275 build |
With those tubes you install them after the head is torqued…one at a time, intake tubes first, then exhaust |
Posted: Tue May 16, 2023 2:01 pm Post subject: Re: Jay's 2275 build |
55rag wrote: |
Yes, I saw your post and hope mine sounds as good as yours. You have a great looking car. |
I am sure that you will have a great engine, it will sound very good and it will have very good performance.
Tims heads are top |
55rag Samba Member
Posted: Wed May 24, 2023 6:06 pm Post subject: Re: Jay's 2275 build |
Hello All, I got a little more work done on this motor. I have a question about installing a new oil cooler. Do you guys clean them out and if so how? Use a hose to shoot water through it and follow up with air?
Thank you
67 Ghia vert
85 911
18 GTI
