matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Saul Koll Samba Member
Joined: September 28, 2008 Posts: 191 Location: Portland
Posted: Tue Jun 14, 2022 12:28 am Post subject: Re: 23 DoubleDoor Deluxe in the making |
I love this build! _________________ "I wish you could smell the smell that's coming from the bus"... |
Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Tue Jun 14, 2022 1:08 am Post subject: Re: 23 DoubleDoor Deluxe in the making |
ronjonlasvegas wrote: |
Beautiful work so far. Are you going to add the heater log under the rear seat? |
Nope, will not be adding that one... never use the heat anyway:-) _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
TRS63 Samba Member
Joined: December 17, 2017 Posts: 1000 Location: Stuttgart - Germany
Posted: Fri Aug 05, 2022 4:42 am Post subject: Re: 23 DoubleDoor Deluxe in the making |
Making sure the splashpans are a perfect fit
creating the corners since these were missing.
making teh channel for the seal
And wanted the barndoor style reflectors in as well:-)
Last edited by Peter - Belgium on Fri Aug 05, 2022 6:03 am; edited 1 time in total |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Mon Aug 08, 2022 8:06 pm Post subject: Re: 23 DoubleDoor Deluxe in the making |
matthew henricks wrote: |
Very nice. Why do you want a removeable middle belly pan? |
Yes, an odd choice. Welding the pan perimeter is stronger, and drilling all those holes in the cross members and frame rails weakens them. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Tue Aug 09, 2022 1:26 am Post subject: Re: 23 DoubleDoor Deluxe in the making |
Cause the intent was to still be able to reach in in case needed. Also my oillines for an external cooler up front would run in there.
And I did not drill holes there, since the center bellypan is actually sandwiches in between and then welded on the top of teh flanges. You can not push it against something there (unlike the side belly pans).
so i welded a strip of metal on the inside which is drilled and nuts welded on the inside. _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
TRS63 Samba Member
TRS63 Samba Member
unclebug Samba Member
Joined: June 18, 2005 Posts: 50 Location: cape coral fl
Posted: Thu Jan 26, 2023 4:04 pm Post subject: Re: 23 DoubleDoor Deluxe in the making |
WOW you make metal work look easy! Good job on this. |
