71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 715 Location: Louisiana
Posted: Mon Feb 21, 2022 10:44 am Post subject: Going to look at a pan buggy, what to look for upon inspection? |
Fellas,
Been without a vw for some time and someone finally listed something within a reasonable drive.
Looks like an OK made pan / tunnel buggy even though it doesn't have top or front cage work... can add those though.
Wondering what everyone else checks when they go look at one, he's at what I would consider max value so don't want to miss anything!
It is a swing and king/link with 4 lugs, possible 68 model?
Anyone found a way that might reveal if it has alot of endplay in the engine?
Owner doesn't know much about it, or what size it is. _________________ One thing I ask from the Lord, This only do I seek:
That I may dwell in the House of The Lord all the days of my Life, to gaze on the beauty of The Lord and to seek Him in His Temple~Psalms 27:4
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
https://www.thesamba.com/vw/forum/viewtopic.php?t=779597&highlight=
https://youtube.com/@SCOFabwerx?feature=shared |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Feb 21, 2022 7:19 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
To check end play you can grab fan pulley and do a push/pull.... Spec is .003 to .005, very tiny amount.. Anything more than about 1/32 inch means it needs attention... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Mon Feb 21, 2022 7:26 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
'66, '67, '68 were all balljoint front, swingaxle rear. '67 and '68 both had longer torsion bars (the ones with the caps that limit how tall the tire can be), so if its link pin and swingaxle, and short torsions, its '65 or older. I also think it looks like it has adapters for 5 lug wheels. I would look the pan over for rust, cracks around the horns, make sure nothing is bent. Other than that, I would drive it, check that the trans downshifts fine, doesnt pop out of gear, no grinding. Does the motor start and idle good, is there much blowby? Grab the crank pulley, push it in, pull it out, big clunk, and loose, or? Looks like its dual port, so probably a 1600 or 1641?
Looks reasonably clean, and fun. |
Posted: Mon Feb 21, 2022 7:42 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
Good eye on the 5 lug wheels, I was thinking (obviously) it had 4 lug vw pattern lol
Owner said it was a 1970 model beetle donor but I know it can't be.
So yeah being it's probably 5x205 with adapters, definitely could be an earlier model than what I assumed, which is good for wheel selection.
I hope I can get to the little inspection cover in the front and maybe look through the shifter for tunnel rust later on.
I just want to be able to check the engine out best I can.
Nearest vw shop still in business is somewhere around 5 to 6 hours away.... that I can find so having to have machine work done will either cost me a day or alot in shipping.
I don't plan on doing much for now, will just be a woods buggy.
Mainly making sure the engine and passengers will be safe and some simple upgrades. _________________ One thing I ask from the Lord, This only do I seek:
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Feb 23, 2022 12:27 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
Are the roll bar and rear 90°s welded in pipe bends? it looks like it is a little tight in the bends. It would probably be fine for putting around at moderate speeds.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Wed Feb 23, 2022 3:58 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
Got out and gave it a decent look over today, not too bad from what I can see.
It was once street legal apparently, has tx inspection stickers.
Had an air cleaner that was obviously not doing it's job because it doesn't fit.
A loose transmission cradle bolt.
There is no master cylinder on it, it's just missing, I figure there was just a factory unit installed as the nap hat area is still intact.
Throttle cable is outside the tunnel lol.
It did come with an extra engine and an irs transmission.
But anywho I'm going to work on brakes and tune up stuff.
Also the right side king/link is worn considerably, I have no knowledge on those so some input on rebuilding would be appreciated! _________________ One thing I ask from the Lord, This only do I seek:
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
stevebaz Samba Member
Joined: March 14, 2008 Posts: 189 Location: El Monte CA
Posted: Thu Feb 24, 2022 11:18 am Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
dont buy anything without a title and not just a bill of sale. then worry about rust everywhere. I would buy one as complete as I could. You will save allot of money that way. buying everything piecemeal you get over your head real quick. |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Thu Feb 24, 2022 12:17 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
bit if trivia for you: those fiberglass seats were designed by Steve McQueen, and sized to fit his scrawny anatomy. if your hips are wider than his, late 90s Ford Mustang seats have a flat mount on the bottom and fit more substantial people _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Posted: Thu Feb 24, 2022 3:28 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
Mal evolent wrote: |
bit if trivia for you: those fiberglass seats were designed by Steve McQueen, and sized to fit his scrawny anatomy. if your hips are wider than his, late 90s Ford Mustang seats have a flat mount on the bottom and fit more substantial people |
Cool info.
He had a decent set of poly seats with covers as some extras that I took home as well.
Mounts will have to be redone but I do plan on swapping them and adding some restraints of some sort.... as long as the buggy frame will be wide enough to fit them. _________________ One thing I ask from the Lord, This only do I seek:
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
Posted: Thu Feb 24, 2022 3:33 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
Also I watched some videos on king and kink pin replacement, I can def handle that... plan to buy them from aircooled.net and rent their reamer tool.
Any advice on Brazil vs German pin sets? Get what you pay for apply here?
Looking at the chassis number information I can find, it is a Nov 1964 model and both engines are AB code which appears to be 1300cc Dual Port for non US models.... which who knows if or how many times either of them has been rebuilt. _________________ One thing I ask from the Lord, This only do I seek:
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
dustymojave Samba Member
Posted: Thu Feb 24, 2022 11:46 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
bit if trivia for you: those fiberglass seats were designed by Steve McQueen, |
Correction...The bucket seats that Steve McQueen was involved in were "Solar Seats". Steve's movie production company was named "Solar Productions". His partner in Soar Seats was Road race Shelby team driver Ed Leslie. Solar Seats are widely imitated as Poly seats. Not fiberglass seats. My buddy Jeff Clark has a pair of Solar Seats in one of his tube frame buggies.
I used to occasionally Tech Inspect Steve McQueen's Porsche 910 road racer in the early 1970s in SCCA Cal Club events. That was only some 50 years ago _________________ Richard
SoCalBajas Member
Posted: Sat Feb 26, 2022 2:38 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
I don't like wheel spacers so been on the hunt for some 15x7 wide 5 steelies. Plus one of the rear adapters has a stripped out stud.
Came up short everywhere, out of stock or super marked up price because of low availability... typical in this day and age unfortunately.
Best I could do was some 15x8 I found... on ebay....
Anywho... this is what they advertised
This is the reality
I've never seen any like these but I guess they will work, don't like the flat faces, prefer the dished look like older wheel sets I've had in the past.
The front has 14" wheels with brand new tires so going to wait until they need replaced before replacing the wheels so I don't have to buy new tires at the moment. _________________ One thing I ask from the Lord, This only do I seek:
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
Ruby Red 1966
liquidrush Samba Member
Posted: Sun Feb 27, 2022 4:42 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
I've got a pair of brand new 15x5s I bought new but were not the right size for my tires. I'll make you a great deal on them if they'll work for you. |
Posted: Mon Feb 28, 2022 2:10 pm Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
I'm in the st Louis area, the wheels are still in the box they were shipped to me in. |
Posted: Tue Mar 01, 2022 12:19 am Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
15 x 6 is also a good size for rear wheels on a Baja or buggy. 15 x 5 will work fine for most tires other than sand dune or deep mud tires. Louisiana just might lean towards lots of deep mud. If this is your case, you might be better off with 15 x 8 rears. Maybe 31 x 10.50 tires.
Oh, and Joemama said,
"'67 and '68 both had longer torsion bars (the ones with the caps that limit how tall the tire can be),"
I want to correct that as they did not have longer torsions except in '68 AutoStick which was IRS. '67 Bugs had short torsions. I'll have to refresh my memory whether swingaxle '68s had shorts or longs.
'67 and '68 Bugs were swingaxle and had long AXLE SHAFTS, '67 long axle - short spline, '68 long axle - long spline. _________________ Richard
SoCalBajas Member
Posted: Tue Mar 01, 2022 6:40 am Post subject: Re: Going to look at a pan buggy, what to look for upon inspection? |
Richard is right. its the axles that are longer. My '67 pan has short torsions, my '71 has long torsions. Sorry for confusing things. |
