pacifcoflyr Samba Member
Joined: August 10, 2021 Posts: 56 Location: Honolulu, HI
Posted: Tue Mar 08, 2022 6:59 pm Post subject: Another Red Emergency Flasher Thread |
I have read the threads I could find on the red light above the wiper switch. Mine isn't hooked up and according to the previous owner,
"The red light on the dash is for the emergency flashers but the Wolfsburg West flasher relay doesn't permit connection of this for some reason. It could be done but would require either a 2 pole emergency switch which I don't think exists or a 2 pole relay energised by the emergency switch. One pole would then be used to supply the flasher relay and the other pole used to supply the red light."
Has anyone used the WW flasher relay and gotten this to wire up? Its just sitting there and I figure get it working! Thanks all.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Mar 09, 2022 9:18 am Post subject: Re: Another Red Emergency Flasher Thread |
Have you tried wiring it up using this diagram?
_________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Wed Mar 09, 2022 9:50 am Post subject: Re: Another Red Emergency Flasher Thread |
Use this key with the above diagram.
https://www.thesamba.com/vw/archives/info/wiring/bus_63_USA_with_emergency_key.jpg
The WW relay replaces just the signal flasher. J in the diagram. Follow their directions for that. There is a separate hazard relay J1 activated by switch J6. It also controls the red hazard light K9. _________________ Tim |
