Tom K. Samba Member
Joined: March 10, 2005 Posts: 1605 Location: Central Pennsylvania
Posted: Fri Apr 15, 2022 6:40 am Post subject: *TWO* Bent Push Rods on Recent Rebuild |
Hey Everyone,
A few months ago, the #1 intake pushrod bended on a recent engine rebuild - total stock. After checking my valve adjustment, the head, the valve springs (all fine), I replaced that bent pushrod with a new one thinking my troubles were behind me - that the bent pushrod was some sort of fluke.
Then when timing the engine and tuning the carb yesterday, a *second* pushrod bended - this time the #2 intake.
So something strange is happening. Any ideas?
I added this latest information to my original thread ("Found an Oil Leak"). But since my issue is no longer an oil leak, I've started this thread with an appropriate title to my problem hoping to get feedback
Thanks, if you can, for brainstorming this issue with me. _________________ '91 Vanagon Westfalia
'70 Beetle Convertible
'71 Super Beetle Semi-Automatic: https://www.thesamba.com/vw/forum/viewtopic.php?t=714131&highlight=
'65 Ghia: https://www.thesamba.com/vw/forum/viewtopic.php?t=762478&highlight= |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Fri Apr 15, 2022 8:23 am Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Something sticking, lifter? Rocker? Valve? Or maybe binding? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Starbucket Samba Member
Posted: Fri Apr 15, 2022 12:20 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
List what was rebuilt to give us a better picture. Did you hear anything before you found the bent push rod? |
Tom K. Samba Member
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Apr 15, 2022 1:53 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Are these OG pushrods? Or some aftermarket brand? |
Tom K. Samba Member
Posted: Fri Apr 15, 2022 4:01 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Use a flashlight and look closely at the valve stems for scoring which could have cause the valve to stick if the clearance of stem and guide are too close. Look at the valve springs for binding when fully open. Is the valve/rocker arm area look nice and oily? if not maybe the rocker arms/shaft might be plugged if not disassembled and oil passages cleaned during rebuild. |
vwoldbug Samba Member
Posted: Wed Apr 20, 2022 7:14 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Did you get new valve guides and who put the cylinder heads together . Are you seer any dust or shavings the same color as the valve guides . Sounds good switching the rocker assemblies around . Let us know. |
Posted: Wed Apr 20, 2022 10:06 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
vwoldbug wrote: |
Agree. Any brass shavings or glitter in the valve area? _________________ Jimbo
TDCTDI wrote: |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Apr 21, 2022 8:45 am Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Lingwendil wrote: |
Turn the engine over by hand 90 degrees at a time, and shake/wiggle the pushrod in each 90 position to make sure it isn't getting loose at any position. I had this happen on a junkyard motor and it turned out the pulley was marked wrong and we had been trying to set the valves 180 degrees out- causing the pushrods to become unseated and jamming sideways. |
Been there a few times! LMAO right now! Thanks for the memory! _________________ Jimbo
TDCTDI wrote: |
Tom K. Samba Member
Posted: Sat Dec 03, 2022 7:19 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Update: I reversed the rockers and inserted cheap expandable push rod tubes to save having to drop the engine. I fired it up and it ran perfectly for about 10 minutes.
Then the gushing oil appeared *again* on the floor. The #1 intake push rod was bent and severed its tube. This is the third time now (first was also #1 intake, second was #2 intake).
So the rocker does not appear to be the problem.
I then measured the valve lash and found that *all* of the valves were alarmingly loose - especially the #1 intake but loose everywhere else too. The looseness, I'm guessing now, is causing the push rod to fall out of its little cup and then get crushed (bent) on the next engine stroke.
So maybe I have a new problem, any thoughts on why all 8 valve lashes would increase after just 10 minutes of idling? This is a new build - new cam, new followers, new stems, new exhaust valves. I feel like I'm missing something easy. Thanks if you have any thoughts. _________________ '91 Vanagon Westfalia
Posted: Sat Dec 03, 2022 7:29 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Are you possibly setting the valve lash at the incorrect time? Idk. It sounds like after your setting the lash, and the valvetrain moves, it's opening up the lash way too much, and the pushrods are falling out of the cups and getting smashed. Like your setting the lash when the lifter is on the ramp, not the base circle. |
Tom K. Samba Member
Posted: Sat Dec 03, 2022 7:50 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Pruneman99 wrote: |
I've been adjusting these VW valves since I was 16, but how nice it would be if I simply messed things up *three* times when adjusting the valves. Problem would be solved.
So I'm going to try again. After *carefully* setting the valve lash, I'm going to let it idle for just 3 minutes. Then I'll let the engine cool for a day and measure the valves and adjust if necessary. Repeat, repeat, repeat.
I just have to wait for a few more expandable push rod tubes to arrive from jbugs. _________________ '91 Vanagon Westfalia
Posted: Sat Dec 03, 2022 8:14 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
I've made silly mistakes in the past.
The only other thing I can think of are the valves have too little clearance to the guides, and are sticking. Unfortunately that's a teardown to fix. |
Tom K. Samba Member
Posted: Sat Dec 03, 2022 9:18 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
What makes me think it's not the heads or valves or stems is that *both* sides exhibit excessive valve lash even though the two heads - both stock - were sourced from different places (one original to the engine is on the passenger side).
Egads. This is a weird one. I'm really hoping I have just been stupid when adjusting valves on this car. I'll be dialed in for this next attempt.
Thanks for giving it some thought. _________________ '91 Vanagon Westfalia
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sun Dec 04, 2022 8:03 am Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Tom K. wrote: |
So maybe I have a new problem, any thoughts on why all 8 valve lashes would increase after just 10 minutes of idling? This is a new build - new cam, new followers, new stems, new exhaust valves. I feel like I'm missing something easy. Thanks if you have any thoughts. |
Have you bothered to check the oil yet? Sounds like you have a cam going flat and/or lifter faces getting chewed up. Drain the oil, remove sump plate and take a pic of what you see. You shouldn't be prolonging the idle on a fresh build. _________________ Come on, It's not rocket science. KISS |
Tom K. Samba Member
Posted: Sun Dec 04, 2022 10:50 am Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
Thinking you need to double check TDC. Get a pencil. Pull the number all 4 plugs, rotate till the pencil pushes out, all the way. You may need to rotate the crank back and forth to get it 100%. Once you get it, compare it to the pulley. Is it on the case seam?
I have seen several pulleies modified with an incorrectly placed notch!
Also, the lifters stick very quickly when the oil galley between them get plugged with debri. That debri, also works into the space between the case and the lifter, causing it to bind and eventually causing the case to need new sleeves. Really think you need to pull the motor and check those lifters!
Did you clean out the oil galleys really good when you rebuilt the engine? _________________ Jimbo
TDCTDI wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sun Dec 04, 2022 12:06 pm Post subject: Re: *TWO* Bent Push Rods on Recent Rebuild |
VW_Jimbo wrote: |
Thinking you need to double check TDC. Get a Plastic drinking straw pencil. Pull the number all 4 plugs, rotate till the Straw pencil pushes out, all the way. You may need to rotate the crank back and forth to get it 100%. Once you get it, compare it to the pulley. Is it on the case seam?
Did you clean out the oil galleys really good when you rebuilt the engine? |
Fixed it for ya Jimbo! _________________ I have learned over the years.
Buy Once, Cry Once!
