michaeltag Samba Member
Joined: August 22, 2015 Posts: 70 Location: SF East Bay, Northern California
Posted: Fri Apr 15, 2022 4:42 pm Post subject: Advice on adhesive for attaching badge on Vanagon |
One of the last details I have to solve as my Vanagon comes back from being painted is the replacement or re-use of my "syncro" badge. I purchased a replacement, but as you can see it is grossly undersized.
Fortunately, my original syncro badge survived removal surprisingly and relatively unscathed, but my paint shop says that the adhesive backing they have is pretty thick—thicker than original and thicker than comes pre-attached to the other replacement emblems that I have purchased. If I re-use the older larger syncro badge I'll need to provide new, but thinner adhesive backing. Does anyone know a good source for this?
Thanks in advance! _________________ '87 Vanagon GL Westfalia Syncro w/ rear locker
• 1.8T engine conversion from Stephan's AutoHaus
• Schwenk Springs, OME shocks, BFG All Terrains on South African 15-inch steel wheels
• GoWesty Plate Steel Bumpers w/ front skid plate & rear swing-away spare carrier
• Big Shot Shifter
• Transaxle rebuilt with taller heavy-duty 4th gear, GoWesty decoupler and oiler plates by Ken at Porter's Precision
* TruckFridge
• Propex Heater
• Vintage Air in-dash A/C |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Sat Apr 16, 2022 4:18 pm Post subject: Re: Advice on adhesive for attaching badge on Vanagon |
look up 3M automotive badge tape and adhesive. They make the tape in different thickness, and also have a glue. |
