MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Sat Apr 16, 2022 7:17 pm Post subject: 44HPMX carburators |
I have a set of EMPI 44HPMX carburetors that I would like to use on my 1776 engine. Has anyone used this combination that could help with proper jet sizes?
Also I have not been able to determine what the differences are between the 40HPMX and the 44HPMX. I believe the carburetors share the same size body but the throttle plates are different sizes, beyond that I am unsure.
Anyway If anyone could shed some light on this it would be appreciated.
Bruce |
plywoodkid Samba Member
Joined: April 17, 2018 Posts: 217 Location: Ventura County, CA
Posted: Sat Apr 16, 2022 7:59 pm Post subject: Re: 44HPMX carburators |
Meefer,
I think the 44’s are too big.
However…..
The Weber Tech Manual states the following as a starting point for Duals:
1. 1600-1835
2. 28mm Venturi
3. 210 Air Correction
4. 140 Main Jet
5. F11 Emulsion Tubes
6. 55 idles.
I believe this is no matter whether own a 40 or 44 IDF. I think the challenge is getting a larger flowing carb to breath like a 40. Your 44’s are probably set up larger than this.
I would give Jeff at Kaddie Shack a call in Pasadena, CA as he sells HPMXs. My comments are strictly based on Webers since HPMXs are supposedly clones.
Good Luck |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Sun Apr 17, 2022 6:08 am Post subject: Re: 44HPMX carburators |
Depends on your heads and exhaust. Big valve ported heads and exhaust, go big on the carbs. Small heads go small carbs. |
Posted: Sun Apr 17, 2022 6:11 am Post subject: Re: 44HPMX carburators |
I am using big valve heads and 1 1/2" header pipes
Bruce |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Sun Apr 17, 2022 1:40 pm Post subject: Re: 44HPMX carburators |
I ran 44s on a 1776. It wasn't dialed in and ran rich. But ran it did.
My uncle revving it in his garage
