Slip356 Samba Member
Posted: Thu Apr 28, 2022 4:52 am Post subject: Tuning dual Weber carbs |
Looking for a quality video on how to tune just rebuilt Weber carbs on my 62 B Cab with big bore kit.
Thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Thu Apr 28, 2022 2:32 pm Post subject: Re: Tuning dual Weber carbs |
Thanks for the quick reply Glenn.
I’ve viewed some of those but will view the rest shortly.
Slip |
Posted: Mon Jul 11, 2022 6:57 am Post subject: Re: Tuning dual Weber carbs |
Well after viewing the above mentioned videos, I got the carbs pretty close. Ended up retarding the timing about two degrees and the car is almost perfect.
Likely some more fiddling will get it there. Sometimes still has erratic idle but I can live with that. Will recheck the linkage for slop. |
Posted: Mon Jul 18, 2022 5:10 am Post subject: Re: Tuning dual Weber carbs |
Did some more very minor adjustments and took car for a 10 mile drive. Believe I’m there, Yea! |
golfguymn Samba Member
Joined: November 21, 2009 Posts: 1 Location: Mpls, MN
Posted: Sat Aug 27, 2022 8:04 pm Post subject: Re: Tuning dual Weber carbs |
Once their in sync, they are a glorious outcome. Got mine to give me close to 30 mpg |
Posted: Tue Sep 13, 2022 1:34 pm Post subject: Re: Tuning dual Weber carbs |
Well, I’ll find out how well I’ve done this week as I just arrived at Riedlbauers Resort in the Catskills Mts of NY for week of road trips with 35+ other 356’s.
Daily trips are from 50 to 125 miles in the mountains.
Will report back. One guy already cancelled as he was driving his car from IN and it broke. |
Posted: Thu Oct 06, 2022 1:01 pm Post subject: Re: Tuning dual Weber carbs |
Finally!!
Enriched each of the four idle screws 1/2 turn made a nice improvement in the idle.
Then 1/4 turn more and that’s it.
Took a 125 mile lunch ride yesterday, 60F temp, car idled at 950-1000 rpm all day in town driving, great smooth transition between idle & main jets.
Only took me two years fiddling
Can you tell I’m happy?
Slip |
Bugged Again Samba Member
Joined: July 09, 2022 Posts: 162 Location: Virginia -Hampton Roads
Posted: Thu Oct 06, 2022 2:02 pm Post subject: Re: Tuning dual Weber carbs |
Slip356 wrote: |
Finally!!
Slip |
Have you ever heard of Harry Pellow “The Porsche Maestro”. He produced some great videos and books when he was alive. He helped me with parts to cobble together a true basket case 912. His tuning video was simply perfect, for me anyway. My old basket case turned out to be a big bore screamer. Too much fun. It would make folks mad since I ran it in my bug. Sleeper. |
Posted: Thu Oct 06, 2022 3:17 pm Post subject: Re: Tuning dual Weber carbs |
Many people have said, once Webers are set up properly, they are bulletproof.
As I had mine rebuilt two years ago and a new in line fuel filter I should be ‘golden’.
Slip |
Posted: Thu Oct 06, 2022 3:24 pm Post subject: Re: Tuning dual Weber carbs |
Slip356 wrote: |
Slip |
I ran 44 Webers and couldn’t say enough how nice they were. Some folks said they had a flat spot off line if the revs weren’t just right. I didn’t have that once I set mine up. I bought the air flow meter tool. It made adjustments so easy. I’m sorry I sold that engine. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Thu Oct 06, 2022 5:55 pm Post subject: Re: Tuning dual Weber carbs |
Slip356 wrote: |
Slip |
Please don't tell me that your "in line" fuel filter is in the engine compartment but instead that it is underneath the car... |
Posted: Fri Oct 07, 2022 5:05 am Post subject: Re: Tuning dual Weber carbs |
Yes it’s under the car, glass with metal ends for easy viewing. Tucked well up so not likely to be hit with road debris.
Thanks for asking.
Slip |
