AH64Doc Samba Member
Joined: August 04, 2007 Posts: 5 Location: Central Coast, California
Posted: Thu May 05, 2022 4:45 pm Post subject: Should I purchase a very rough 1968 Beetle |
Hi everyone,
My name is David, and I am a new guy here. Recently came across a 1968 Beetle in my area that is for sale for $600. I'm considering going for it, but it is in ROUGH shape.
My question to all of you is: Is it worth it? It would probably be a full ground up restoration.
Thoughts?
Thanks for your time.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76898 Location: Sneaking up behind you
Posted: Thu May 05, 2022 5:38 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
Do.you have the skill to do it yourself? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu May 05, 2022 5:39 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
Good point on worth.
Guess I should ask, would this be a bottomless pit of $$$ for a restoration?
Yes it does have a title. |
Posted: Thu May 05, 2022 5:50 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
Glenn,
Some things I'll be able to do myself, others with assistance, and others still through professionals. |
hobthebob Samba Member
Joined: December 08, 2021 Posts: 375 Location: Austin, TX
Posted: Thu May 05, 2022 6:08 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
I have no experience doing serious restoration work, so take my opinion with a grain of salt:
If I were you I'd find a moderately priced Beetle less than 10k that needs little to no work. For less than 10k you can have a fully driving, reliable, and good looking automobile from the mid-late 60's.
For $600, you're most likely going to spend 15k to make it driveable, but not good looking. Paint jobs alone can be thousands upon thousands for a decent job. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Thu May 05, 2022 7:09 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
Unless somebody has done a frame head swap, that isn't a 1968 chassis shown in the second picture -- note the link pin front end. _________________ 1960 Ragtop w/Semaphores "Inga" |
VWFIXER Banned
Joined: January 21, 2011 Posts: 411 Location: Hawaii- Rarotonga
Posted: Thu May 05, 2022 7:48 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
offer to tow it away for free, thats it. _________________ ( ) Cheap
( ) Fast
( ) Reliable
Choose 2
Over a million air cooled miles driven and 15,000+ cars serviced. |
Joe 20 Samba Member
Floor looks good. Body doesn't look rusted. You'd probably have to remove the body anyway. Does the engine run? If you have the skill and the room, $600 sounds reasonable if you are looking for a VW project. Good Luck!! _________________ "Someday the world is gonna be populated by nothing but Volkswagens'" Corporal Klairvoy |
oprn Samba Member
Joined: November 13, 2016 Posts: 12706 Location: Western Canada
Posted: Thu May 05, 2022 8:07 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
That is a long long term project! Do you have the glue to stick to it to the finish? If not it will be a sinkhole for money that you will never get back. If you can see it through then yes it is worth it. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Fri May 06, 2022 1:21 am Post subject: Re: Should I purchase a very rough 1968 Beetle |
If you want to do a Beetle project , yes.
If you think your time will convert to money down the road , no.
Most are surprised at how much fixed cost there is in restoration. You can burn $100 of gas welding in an evening , for example.
Take the $600’and mulitiply by 10x. If you can part with that money and still not have a driver and are ok with that, go for it. _________________ .ssS! |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri May 06, 2022 6:27 am Post subject: Re: Should I purchase a very rough 1968 Beetle |
most important is to make sure you have a title matching the chassis vin.
that's a pre '66 chassis, link'ing pin axle beam.
previous body probably want to an IRS chassis
$600 is worth the chassis alone if the title matches it. (a titled chassis has more value as it can be used under a car, for a dune buggy, for a kit car, etc..)
the body ('6 if only worth the amount of rust repairs you DON't have to do...
example- if its going to cost you $1000 to do heater channel, It's worth $1000 LESS than the seller thinks it is...
If you don't have to do any rust repairs, it's worth maybe $1000/1500 |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13846 Location: White Mountains Arizona
Posted: Sat May 07, 2022 7:58 am Post subject: Re: Should I purchase a very rough 1968 Beetle |
Keep looking around as you will have a boat load of cash into it when completed. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
ebenasky Samba Member
Joined: March 16, 2011 Posts: 211 Location: Helena, MT
Posted: Sat May 07, 2022 9:09 am Post subject: Re: Should I purchase a very rough 1968 Beetle |
Check the tunnel on the chassis for the VIN and also check the VIN plate under the hood on the body. You can do a look up on The Samba to determine what years you have there.
I bought a $500 car and spent $8k before I sold it. I also put 10K miles on it and learned a LOT about bugs. I can rebuild a carb in my sleep now and even know how to rebuild distributors. Learned to weld and paint as well. I have more tools now too! Had it for almost 10 years,
Don't look at this as a quick way to make money - look at it as a learning experience that is a LOT of fun to drive. If that is not your reason to buy, then skip it.
I have two more projects waiting for me as well as my '78 Chevy truck. Working on my cars is my way to relax.
Oh ya, if you don't have a garage, then it's going to be a LOT harder to do. _________________ "I don't fix 'em to look at 'em, I fix them to drive."
- '60 Beetle "Ruby"
- '70 Beetle "Peace" |
wheel607 Samba Member
Posted: Sat May 07, 2022 1:42 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
NO! |
Posted: Sun May 08, 2022 11:55 am Post subject: Re: Should I purchase a very rough 1968 Beetle |
Thanks everybody. Great advice all the way around.
Ultimately, I offered the guy $400 and he accepted.
What I am going to do is use this particular car as a way to learn about bugs, and what it takes to repair them and keep them operational.
I see that this one has rust everywhere, so it would probably be cheaper as most of you have posted to buy a runner and fix it up rather than trying to take this beater and turn it into something amazing. |
Posted: Sun May 08, 2022 12:49 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
Quote: |
What I am going to do is use this particular car as a way to learn about bugs, |
Watch out! Incoming shovel! _________________ .ssS! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun May 08, 2022 2:30 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
So was there a title with that pan? |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sun May 08, 2022 3:06 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
AH64Doc wrote: |
Good luck to you. This looks really rough. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun May 08, 2022 3:40 pm Post subject: Re: Should I purchase a very rough 1968 Beetle |
I see 400 bucks worth of entertainment value there even if you never get the car put back together. |
