Posted: Mon May 16, 2022 10:22 am Post subject: Re: Can you hear a vacuum leak? |
The lower priced line of Continental belts aren't worth squat. |
creative native Samba Member
Posted: Mon May 16, 2022 12:03 pm Post subject: Re: Can you hear a vacuum leak? |
Wildthings wrote: |
I've used these ContiTech for years without a problem. What are you using? _________________ "The holy land is everywhere." ~ Black Elk
1979 Westfalia P27, California FI emissions spec. 100% VW fleet: '79 Westfalia, 2013 Touareg Lux (Toffee Brown/Cornsilk Beige), 2005 Passat GLX. |
Posted: Mon May 16, 2022 2:30 pm Post subject: Re: Can you hear a vacuum leak? |
creative native wrote: |
Wildthings wrote: |
I've used these ContiTech for years without a problem. What are you using? |
I didn't know that there were two different grades of Conti belts and bought what my local supplier had in stock. It stretched like a rubber band and was impossible to keep tight. This was at least 5 years ago, so maybe by now things have change? |
tunnvar Samba Member
Joined: October 24, 2011 Posts: 261 Location: Austin, Texas
Posted: Fri May 20, 2022 1:59 pm Post subject: Re: Can you hear a vacuum leak? |
UPDATE: Ok, as per usual it was something really simple. I found the Idle Jet on the right side of the carb. Took it out and it had a tiny bit of crap in there. Blew it out and hey presto I have idle again.
My main concern now is that after taking it out for a 5-minute spin, the engine bay was way hotter than I have ever experienced. Could hardly touch the tin.
SGKent alluded to my fan belt causing issues with the cooling if it is failing and could also be part of the rubbing noise coming from the pulleys. Could this be confirmation?
Next up, new belt and sharpish before any trips.
Thanks as always for the feedback. _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
[url=http://www.vw-mplate.com/mplate2-35638.png]Click to view image[/URL] |
SGKent Samba Member
Posted: Fri May 20, 2022 2:24 pm Post subject: Re: Can you hear a vacuum leak? |
use another car to go buy the new belt so you don't cook the engine, which it sounds like you are doing. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu May 26, 2022 6:56 pm Post subject: Re: Can you hear a vacuum leak? |
Evening all. So I got the new belt on and I decided to get a new pulley too. First time I have done this and I have a few concerns.
The hissing/rubbing sound is still there, though it does seem quieter. The old belt definitely needed replacing. Here is a video of the new one running a lot better than before:
https://www.youtube.com/shorts/QNY5coSa3nk
Am I worrying about nothing with that rubbing/hissing sound?
Another thing, the pulley has oil splattered on it after running it for a few minutes as you can see here. Is this normal? I wouldn't have noticed on the old one since it was old black and grimy.
Lastly, I drove it down the street and I could hear a vibration noise when I took my foot off the gas. Have I got it on there well enbough? I used 3 new shims when putting the new pulley on, since there were 3 on the old one. I saw that in a video.
Any ideas what the vibration noise is? I don't have a video but could get one tomorrow maybe.
Thanks. _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
Abscate Samba Member
Posted: Thu May 26, 2022 10:36 pm Post subject: Re: Can you hear a vacuum leak? |
The shims adjust the belt tension, so you need to back and set that right.
Too loose, cooked engine
Too tight, cooked generator _________________ .ssS! |
SGKent Samba Member
Posted: Thu May 26, 2022 10:43 pm Post subject: Re: Can you hear a vacuum leak? |
did you reach around with the ENGINE OFF and check to see if anything is in the fan or it feels loose in any way? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri May 27, 2022 3:29 am Post subject: Re: Can you hear a vacuum leak? |
Abscate wrote: |
Too tight, cooked generator |
Once I got the belt on I checked the tension based on pinching it in no more than 1/2 inch and it wouldn't twist easily past 90 degrees. _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri May 27, 2022 9:01 am Post subject: Re: Can you hear a vacuum leak? |
Were you pinching both sides of the belt in a half inch? (Total of one inch...) or were you just pushing it in a half inch on the left side of the belt? Second one is more correct.
I suppose a way too loose belt could cause the generator light to come on, but likely really only if you had a lot of electrical load (headlights on, etc) if the generator is spinning along with the engine.
The main "hissing" sound I hear sounds to me like intake noise from the carburetor. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri May 27, 2022 2:41 pm Post subject: Re: Can you hear a vacuum leak? |
I think it needs to be tighter based on what you are saying here. It definitely feels slacker than when I first put it on last night. Think I will take out a shim or two.
Is intake noise something to be concerned about?
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Sat May 28, 2022 9:26 am Post subject: Re: Can you hear a vacuum leak? |
Intake noise is a symptom of the crude chrome air filter. VW original works quieter.
If the light comes on at idle, you have a generator which may do that
While your fan belt is slapping around its also helping to destroy the pulley, the Woodruff key that locks it to the generator shaft, and the key slot in the generator shaft.
The black crud spinning out on your new pulley is dirty oil on your generator shaft.. maybe carbon from wearing of the brushes mixed in.
. _________________ Ancient vehicles and vessels
Posted: Sat May 28, 2022 9:32 am Post subject: Re: Can you hear a vacuum leak? |
Appreciate the feedback, good points thank you.
Update: Got it running and idling nicely. Reverted to the old generator pulley with a new belt and got it on there with the right tension.
Engine tin seems a lot cooler now too. Lots learned.
Onwards and thanks again! _________________ 1970, Deluxe, 1600cc, Type 1 Dual Port
