mouse action Samba Member
Posted: Sun May 15, 2022 7:29 am Post subject: New ghia guy |
Hi all, new to vw not to cars,been a hot rodder forever,now trying to slow down.
Got a deposit on a 71 convertible,
any comments or advice would be greatly appreciated.
Thank you. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Sun May 15, 2022 7:41 am Post subject: Re: New ghia guy |
Is that a rendering or the actual car?
Where in New York are you... it's a big state. _________________ Glenn
Member #1009
#BlueSquare |
Starbucket Samba Member
Posted: Sun May 15, 2022 8:01 am Post subject: Re: New ghia guy |
Check it for rust with a refrigerator magnet all around the bottom areas and look at the pans for rust or replacement. A freshly painted car can hide thousands of dollars in rust repair. |
RUNKLE Samba Member
Posted: Sun May 15, 2022 8:32 am Post subject: Re: New ghia guy |
First impression was a rendering as well, but no, It’s real. Good photography and some digital manipulation and voila.
https://www.motorcarclassics.com/1971-volkswagen-karmann-ghia-c-815.htm _________________ Type 1
Type 3
1968 Squareback |
Marcdeb Samba Member
Posted: Sun May 15, 2022 9:15 am Post subject: Re: New ghia guy |
Welcome to TheSamba,
Nice looking car that looks mostly stock on the exterior other than the color, and mostly stock in the engine bay.
Karmann Ghias are great little cars. Being all hand assembled with welded together bodies, they can present special considerations when trying to evaluate condition. For starters, there should be 2 rocker seams present just below each end of the doors. These are missing on the car you are looking at it. It certainly points to some major rocker panel work. That can be good or bad depending on if it's been done properly. There's more to the rocker panels since the heater channels run the length of the chassis behind the rocker panels. Then in the case of the convertibles, there is a body stiffener that runs the length of the chassis as well. Usually if the rockers are rusted, you can bet for sure there will be some serious rust in the heater channels and the stiffeners. So it's important to know what sort of work was done to those rockers. On the passenger lower front fender there is supposed to be a recessed area for the "Karmann Ghia" emblem. That is missing on your as well. I would be suspicious of a lot of rust or damage repair in that area. Floor pans in these cars are almost identical to the VW Beetle and are very prone to major rust so they should be checked out. The back outer corners of the engine deck also show obvious signs of damage. Can't tell if it's bad rust repair or if it's been crunched in those 2 areas? Hopefully you or someone you trust will be able to really carefully inspect this car before buying. By the way, it's missing the sun visors?? _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Sun May 15, 2022 9:40 am Post subject: Re: New ghia guy |
mouse action wrote: |
any comments ... |
At first glance three aspects of the top caught my eye: the bead along the front should align with the leading edge of the header bow, the padding, if installed, appears to be lacking in bulk, i.e., the outlines of the intermediate and rear bows seem too pronounced, and I can't quite put my finger on something that seems odd about the headliner. Given the asking price as well as the extensive effort to make it presentable, one might reasonably ask why the owner failed to install the sun visors |
Posted: Sun May 15, 2022 11:09 am Post subject: Re: New ghia guy |
Thanks all, I went over the car and it’s very clean ,minimal bondo work,everything seems to be operating properly,drives nice.a few little fixes to be had.
kingkarmann Samba Member
Posted: Sun May 15, 2022 11:44 am Post subject: Re: New ghia guy |
crocteau wrote: |
any comments ... |
Agreed.
Welcome to the world of coach built old world craftsmanship!
As everyone else has mentioned, the restoration seem nice with minimal shortcuts. One being the missing visors. The second is the window trim delete.
Cal look seals belong on Cal Lookers
Otherwise, congrats on a very nice looking KG _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
Glenn Mr. 010
Posted: Sun May 15, 2022 11:48 am Post subject: Re: New ghia guy |
The generator was installed incorrectly. It should be rotated 90* clockwise.
For $40k, all the details should be correct.
Look for other things. _________________ Glenn
Member #1009
#BlueSquare |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1678 Location: Raleigh, NC
Posted: Sun May 15, 2022 12:42 pm Post subject: Re: New ghia guy |
There's bondo in the rockers. There should be a pair of seams in the rockers under each door. There also appears to be accident damage, or some kind of damage, in the sheet metal in the engine bay.
The color change doesn't seem to be complete, as the front trunk looks to have been painted black (should be body color), and some small amount of the original green is visible next to the VIN plate.
Washer bottle is missing. Front trunk hood stops are missing. The clutch pedal should be in roughly the same position as the brake pedal. As it is, the clutch cable might be too tight, too short, or the wrong bowden tube in place.
It's a nice looking car, but for the asking price it shouldn't have any of those issues...especially the sheet metal issues in the rockers and engine bay. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Posted: Sun May 15, 2022 2:02 pm Post subject: Re: New ghia guy |
All great words of wisdom .thank you |
Glenn Mr. 010
Posted: Sun May 15, 2022 2:09 pm Post subject: Re: New ghia guy |
I'm a 10 minute drive from the place in Farmingdale. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun May 15, 2022 4:44 pm Post subject: Re: New ghia guy |
Era Vulgaris wrote: |
It's a nice looking car, but for the asking price it shouldn't have any of those issues...especially the sheet metal issues in the rockers and engine bay. |
I’m an utter failure at speed skimming 🤪
So many great eyes!
$40k!?!?
Run!! _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Braukuche Samba Member
Posted: Mon May 16, 2022 6:46 am Post subject: Re: New ghia guy |
Looks like it was done by a shop that doesn’t know Ghias and that’s as bad as buying an expensive restored Porsche from a shop that doesn’t know Porsches.
The Ghia body is expensive to repair correctly, it requires a lot of time and these guys took major shortcuts, for example who bondos over the Karmann lower fender indent other than a hack shop.
Not a single guy on here is going to recommend you to go through with that purchase at that price. And believe me, no one knows these cars better. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Mon May 16, 2022 8:43 am Post subject: Re: New ghia guy |
Thank you. |
I don't know if you're stuck on a convertible.
Randy Carlson at Oldbug has been brokering VW's for a long time. Has a decent reputation and is known for representing some nice cars.
This 69 Ghia is across the country but is a very nice representation of a stock Coupe at less than $25k. Shipping would still get you way below $40K.
https://www.oldbug.com/805712ghia.htm _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
Posted: Mon May 16, 2022 12:53 pm Post subject: Re: New ghia guy |
Appreciate all the words,Im hoping not to pay the asking price. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Mon May 16, 2022 8:08 pm Post subject: Re: New ghia guy |
Did that convertible top boot stay on the car during your test drive? Looks like it's just placed loosely on the body for the photos, and therefore would've blown off at very low speeds already. It's supposed to have about 10-12 snaps total to hold it to the body.
I agree that this '71 is cosmetically very appealing, also the top color; but the body-painted wheels are irritating. Factory color would've been a satin silver which was used on all factory body colors. Here's a press photo of a '70 Coupe which would have most details of this '71 you've inspected. Unfortunately the photo is a black & white so that you can't see the wheel color, but it's clearly a light color compared to the body color paint of this '71. Easy to correct with 1-2 cans of spray paint.
You can also clearly see the two seams in the rocker below the doors; the seams run vertically and are the intended separation between the rocker panel metal to the front fender and the rear quarter panel. Common "mistake" for a general body shop to fill in those seams with filler.
The vacuum hose routing to the distributor and carburetor does not look correct/incomplete... could cause the distributor to not advance as intended as engine rpms increase, so that the engine would feel sluggish. |
Posted: Tue May 17, 2022 4:19 am Post subject: Re: New ghia guy |
Funny you noticed that,it’s was taking off like a kite.
I do realize that it’s not perfect,but it must have a value? |
Posted: Tue May 17, 2022 2:35 pm Post subject: Re: New ghia guy |
Not one that you're going to get a classic car dealer to sell the car for. Maybe $10k-15k max, IMO, with all the issues it has. The interior seat covers and door panels are the least expensive interiors you can buy from TMI. The carpet is not the correct square weave, but cheap loop. Maybe if it had a better quality interior, I could see it going for half the dealer's $40k asking price. It's just everywhere you look on this car it's clear shortcuts were taken to save money, or work was just done incorrectly.
There's much better cars out there for less money. I'd walk away. _________________ Currently own:
Previously owned:
