mj2k Samba Member
Posted: Sun May 21, 2023 2:40 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Bit more Bondo in the rear wings to cover the joints, with careful work it's close to looking smooth now, without resorting to 1/2 inch thick nastiness.
Also I finished my wheel well modifications - it's strong enough for me to stand in now without bending, so should be fine with 70kg of EV batteries in it when it's sitting on the frame head
_________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
mj2k Samba Member
Posted: Thu May 25, 2023 7:46 am Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Quick pic of my modified spare wheel well balanced on the frame head - should line up nicely once I've welded it in place:
Also, in my quest to fit blade bumpers, I got hold of a cheap standard sized rear wing - shows just how oversized my current wings are
Do the holes in the wing look like they're for the earlier round tail lights or the Tombstones? Think they're for tombstones, but not 100% sure. _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
mj2k Samba Member
Posted: Fri May 26, 2023 12:37 am Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
I've got another rear wing coming today, and got some white primer / L90D white paint to experiment with the 2 tone look once I've finally got those much-welded side panels looking straight.
Does mean my rear wheels look rather ridiculous though, so need to experiment with the small pile of alternative styles I've acquired. And then fit the disk brake adaptors / disks to the 1302 (early Super) struts at the front, and see what will fit over them. Might be able to get away from the super-wide wings at the front with a bit of luck, but I'm not holding my breath on that - having the tyres sticking out beyond the fenders like they were originally with later type struts is an MOT fail in the UK. _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
mj2k Samba Member
Posted: Fri May 26, 2023 5:33 am Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Other wing arrived today so did a quick mockup - looks good from the rear at least:
mj2k Samba Member
Posted: Mon May 29, 2023 2:48 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Did some checking of my alternate wheels against the new back wing...
Existing Empi alloys without the spacers - look good, but even without the spacers they stick out beyond the edge of the wheelarch:
Chromed Baja steels - don't look so great and still stick out beyond the arches, even without tyres:
Chromed version of standard steel wheels - not as good looking as the Empis, but look OK. Perfect fit behind the wheelarch:
Then temporarily fitted the front discs plus 1302 strut adaptors and checked against the standard steels - clearance is tight, but still seems fine:
So looks like we have a winner... _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
mj2k Samba Member
Posted: Tue May 30, 2023 5:00 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Feeling a bit the worse for wear today (hopefully food poisoning and not another bout of Covid) so couldn't do much, but I got the 1302 front wings today, and loosely fitted them.
Empis still fit under them fine, though I haven't tried them with the disc brakes / 1302 adaptors yet, which could be the big challenge.
I'm sticking to my Karmann Ghia headlight mounts - it'll allow me to have a huge range of cheap sealed / semi-sealed headlights from all sorts of sources (including these LEDs if I want them), rather than the shoddy-but-expensive RHD Super headlights. Only thing is I'll either have to find headlight surrounds which suit the adjusters, or drill my current surrounds:
And as for the blade bumper - still not got the mounts, but balanced on a box it looks like a perfect fit to me:
mj2k Samba Member
Posted: Wed May 31, 2023 8:16 am Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
I'm in the middle of touching up some paintwork damage caused by removing the thick Bondo from the rear 1/4 panels, but couldn't resist test-fitting one of my new tombstone lights - looks good to me
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
mj2k Samba Member
Posted: Wed May 31, 2023 5:10 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Buggeee wrote: |
"I'm in the middle of touching up some paintwork"
OMG am I the only one. This just struck me so funny because half the car has been replaced with welding.
I bet you are! Hahahahaha.
The car is looking great. What a good feeling to be where it is now. |
Thanks, probably nearer 75% replaced by now
Yes, it's a good feeling finally getting round to plain old cosmetics again, much as I hate doing them.
Though I am cheating a bit - I still need to clean up around the frame head and weld the spare wheel well / front panel on, but wanted to sort out the suspension, brakes and wheels first, not to mention have a little 'holiday' from welding for a week or so _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
mj2k Samba Member
Posted: Fri Jun 02, 2023 2:12 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Got the disc brakes fitted - they actually fit better under the Empis than the standard wheels, which makes me want to keep the Empis even more...
Also found out where the errant blade bumper mounts are - they were stuck in UK customs like I expected, and were just released today...
And got yet another load of parts from the Netherlands (paruzzi.com) which were sent 6 days after my French bumper mounts, but arrived a day before the parts from France (you can see France from some parts of the UK on a clear day) had even cleared customs.
So fitted them to the car - standard semi-sealed beams, suitable rims to fit over the Karmann Ghia headlight adaptors, and my 1962-style indicators. Between that and the tombstone rear lights, I think it looks rather nice in the white primer, so I'm now very tempted to make the blue and white colour scheme permanent:
I've run out of white primer, but just one more fender to spray and I'll be able to get the full effect. It'd definitely look better with the Empis (well, fake Empis, as I noticed) though. I'll have to mess around with tyre sizes and see if I can get them to fit under the arches with the narrower profile tyre they're supposed to wear. _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Fri Jun 02, 2023 5:18 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Man! You are ripping through this! And doing a stellar job!
Looks great! When do we get to see full body shots? Really interested to see the two tone interaction, on all its glory! Sounds so cool! And I agree with you, the scheme looks great right now! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
mj2k Samba Member
Posted: Fri Jun 02, 2023 5:26 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
VW_Jimbo wrote: |
Looks great! When do we get to see full body shots? Really interested to see the two tone interaction, on all its glory! Sounds so cool! And I agree with you, the scheme looks great right now! |
Not enough room in the garage for me to get a full body shot, but as soon as the bug's able to be wheeled out of the garage and (preferably) as soon as I've removed the bondo from the doors, thrown up my hands in horror and replaced the skins plus bottoms (I'm expecting the worst so I've already got the panels sitting in another part of my crowded garage), it'll be ready for it's grand debut in night blue / white primer
And then soon afterwards I'll be putting on the topcoat of pastel white, which I now have on order. _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
Posted: Fri Jun 02, 2023 10:28 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Sounds like a plan! _________________ Jimbo
TDCTDI wrote: |
mj2k Samba Member
Posted: Sat Jun 03, 2023 1:14 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
So, I started doing the left hand door. Shame to cut the whole skin off because it was perfect, but the door was kindof bulging in a weird way (still no idea why, except it came from a much later bug) and the bottom had rotted out (of course) so off it came, and I replaced the door bottom. Still some work to do on the lips, but looking good so far:
And since I've now got some more white primer, finished off the right hand front fender, and de-rusted / primered the front valence (top half is staying night blue), so quite a busy day. _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
Posted: Sun Jun 04, 2023 9:09 am Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
That is a shame! That is a hard weld right there. Getting that panel to end up looking like a properly shaped door will take ALOT of patience! Just remember to cool the entire door down in between a few welds. _________________ Jimbo
TDCTDI wrote: |
mj2k Samba Member
Posted: Sun Jun 04, 2023 11:26 am Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
VW_Jimbo wrote: |
That is a shame! That is a hard weld right there. Getting that panel to end up looking like a properly shaped door will take ALOT of patience! Just remember to cool the entire door down in between a few welds. |
Yeah, it is a real shame, I just don't 'get' why it sat so proud of the rest of the car in the middle. Can't have been from Brazil / Mexico since it still had quarter lights, but it was in waaay too good condition to have been from a 1973 UK car, and was white underneath all the paint layers. Mystifying.
I'll be really annoyed with myself if it does end up mis-shapen or is still too bulbous at the end, I'd have been better off selling this nice-but-odd door and buying a ratty one from the same year. Edges will be spot welded so that's one less place for distortion, but I am going to have to go very carefully on the join line with the top half of the door.
The right hand door is original (i.e. 75% bondo at the bottom), the correct shape and was originally red, so that one definitely came off the donor car. No doubt that one's going to need a lot of work to put right... _________________ "I looked for silver linings, But you're rotten to the core" - Devo: Gut Feeling (they must have seen my Super) |
mj2k Samba Member
Posted: Tue Jun 06, 2023 12:15 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
That worked better than expected
I flattened the lips the door skin attaches to (which hold the door seal in place too of course), repaired them, and spot welded down each side. Then I beat the lips back to their proper shape, checked the door frame / skin fit in the car, then carefully welded the top area, the hardest part to get right. Then once everything was nice and flat and undistorted, I spot welded the bottom lip and hammered flat.
Still needs finishing but I've got a good result - the door skin is nice and flat, and fits in nicely with the shape of the other panels (please ignore the grubby handprints on the white primer):
The one thing which didn't go quite so well was right in the centre at the bottom, where the window winder attaches. On the right hand door there's a simple welded on nut which the winder attaches to, on this left hand door there's a hefty bracket. Aside from meaning I need different winders for each side, it also means the left hand bracket sticks out from the door frame a bit on the outside, which has left me with a couple of inverse dimples, where the bracket's pressing against the outer skin. Wish I'd noticed that before I fitted the door skin - I'd have dumped the bracket, welded in a nut like the other side, and bought a new winder
Still, at least that explains why the door skin seemed more rounded and bulbous - it was, to fit over the bracket
BTW, what year of bug had this type of bracket for the window winder?
mj2k Samba Member
Posted: Tue Jun 06, 2023 12:18 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
VW_Jimbo wrote: |
Here's a starter, the door still needs finishing though:
mj2k Samba Member
Posted: Wed Jun 07, 2023 5:43 pm Post subject: Re: New user, and new project - 'Throwitbacktogether' ! |
Got the 'special' 1303 blade bumper brackets from France at last - they're just the plain old Empi ones which aren't for a Super, which I could have picked up for $100 less in the UK, so feel well and truly ripped off
Still, the front looks good, but the brackets will need modification, which I was hoping not to do:
Also the rears look wrong to me whichever way up they're mounted, either too high or too low. Think standard blade mounts might have looked better, but I'll have to see once I can roll the car out of the garage and see it in profile:
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
