flyinglow94 Samba Member
Joined: January 17, 2005 Posts: 1164 Location: Las Vegas, Nevada
Posted: Thu Sep 22, 2022 12:15 am Post subject: Re: 92 Jetta brake upgrade |
For what its worth, if you run the MK3 2.0 spindles on your MK2, you can use the MK5 312mm vented rotors but you will need to have the rotors drilled for 4x100 if needed. This is what I have on my 90 GLI jetta but im running Porsche boxter brakes. My Son is running on his 91 GTI and on his 93 Corrado the MK3 VR6 spindles (the Corrado is equipped with these from factory) with the fabless MK2 to MK3 control arms or you can run the MK3 wide track control arms on the mk2, (the wide control armes space the track out, i think 13mm a side) with this he was able to run the MK4 337/Audi TT 312mm rotors, you will also have to drill the rotors and hubs for 4x100 if needed. You Use the 337/20th, or Audi TT calipers and caliper brackets. In the rear of the MK2, the MK3 rear spindles and rotors are a direct bolt up to a MK2 beam. I am currently running a custom setup on the rear of my GLI, a MK4 stub and hub with a 337/TT vented rotor and caliper. This all fits under a 16" rim. We are running 17" wheels on our cars. I can take some pictues and try and post them.
( some of these applications might take spacers behind the caliper brackets for proper fitment). _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
"Socialism is a philosophy of failure,the creed of ignorance, and the gospel of envy,its inherent virtue is the equal sharing of misery.." |
oprn Samba Member
Joined: November 13, 2016 Posts: 12701 Location: Western Canada
Posted: Sat Sep 24, 2022 4:54 am Post subject: Re: 92 Jetta brake upgrade |
Interesting, thanks! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sat Sep 24, 2022 8:01 pm Post subject: Re: 92 Jetta brake upgrade |
I loaded some pictures to the gallory of the brake swaps we were able to do with stock VW parts, we found rockauto has the best prices on rotors and pads
Sorry, my sons Corrado doesn't show the brake upgrade, but it has the same brakes as the GTI. my jetta we went with the MK5 rotters ( the rotor hat sets back alittle further than the mk4) i am also running a boxter calliper in the front of the red gli. In the rear i made two types of hub mods. One was machine down the old rotors drill them for both 4 and 5 lug and the other was to make a mk4 style hub and stub fit, so we can run whatever rotors we want in the back. _________________ "What we obtain too cheap, we esteem too lightly: 'tis dearness only that gives everything its value. Heaven knows how to put a proper price upon its goods; and it would be strange indeed if so celestial an article as FREEDOM should not be highly rated."
