murray7010 Samba Member
Joined: September 26, 2008 Posts: 150 Location: Salado, TX
Posted: Tue Nov 21, 2023 1:32 pm Post subject: Re: Murray’s 1951 Split Restoration |
Well, what do you know….we done got some welding done! Sorry for the delays! Ima do better about keeping this thread alive. The front end is all together thanks to the tedious job of the Pro Spot Welder we have on-hand. Back to factory specs.
_________________ 1951 Deluxe Sunroof Beetle (11C Model)
Follow the resto up to date on Instagram @SplittyMcFiddyJuan
10/2013----->http://www.youtube.com/watch?v=B2dHtL-_80g |
Posted: Tue Nov 21, 2023 2:19 pm Post subject: Re: Murray’s 1951 Split Restoration |
With the metalwork on the body out of the way, it was time to look at the pan. Like any other early car, this pan had its share of repairs and lack thereof. Floor pans were incorrect and normal rot was found and addressed. More on the fun side though, I wanted to open the tunnel up! Not as dirty as I thought it would be, at all. Added two fuel lines while the tunnel was open (EFI in the future maybe). For delivery and return.
Posted: Tue Nov 21, 2023 2:40 pm Post subject: Re: Murray’s 1951 Split Restoration |
Seat rails installed and seats installed just to double check the fitment! Deleted the later front trans mount and added a solid gene berg mid mount (weld in). Fitted a beam to make sure everything looked good and we were set. Was gonna paint the pan pink, but made a last minute change to paint it black…you’re welcome. 😂😂😂
Two Glove Boxes Samba Member
cyberdyne systems 101 Sambanator
Joined: September 03, 2004 Posts: 434 Location: in my own little world
Posted: Wed Nov 22, 2023 4:03 am Post subject: Re: Murray’s 1951 Split Restoration |
Looks amazing, super smooth. _________________ When I think of something to say - I'll be the first to know
56' Oval
71' Westy |
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10791 Location: San Diego, CA
Posted: Sat Dec 09, 2023 8:23 pm Post subject: Re: Murray’s 1951 Split Restoration |
I seen this in paint and it’s so clean and fresh! |
Bendango Samba Member
Posted: Sat Dec 09, 2023 9:28 pm Post subject: Re: Murray’s 1951 Split Restoration |
Great thread - your son’s reaction will be a memory of a life time for both of you! Great motivation! _________________ I want a real garage.
WANTED - [WTB] 55-62 Bus Thin Lip Package Tray SWR
Getting Used - SWR 60 westy copy built by vw ( apparently )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320866
Braukuche wrote: |
Where did you find the elephant dick? |
Posted: Mon Nov 25, 2024 9:33 pm Post subject: Re: Murray’s 1951 Split Restoration |
So what’s up with this project? _________________ I want a real garage.
Braukuche wrote: |
Posted: Mon Dec 02, 2024 11:07 am Post subject: Re: Murray’s 1951 Split Restoration |
Bendango wrote: |
So what’s up with this project? |
So much has changed….i’ll update today…lol _________________ 1951 Deluxe Sunroof Beetle (11C Model)
Posted: Mon Dec 02, 2024 10:13 pm Post subject: Re: Murray’s 1951 Split Restoration |
Brought the pan back home for the assembly. First time assembling a pan and I can say it was definitely humbling. A lot of work goes into this. List of duties included:
- cleaning out all threads
-I installing ARP stainless hardware
-Front Beam install
-Rear suspension setup
-various pan parts powdercoated
-Transaxle assembly and install
-brake component install
-pedal assembly and shifter install
Posted: Mon Dec 02, 2024 10:38 pm Post subject: Re: Murray’s 1951 Split Restoration |
With the assembly done, it wasn’t without hiccups! But it’s all good. Definitely all easy fixes.
When we welded in the berg mount, we did so with a non-early bus Nosecone trans…which led to the mount being welded in the wrong place. This didn’t allow my actual trans and correct nose cone to line up correctly. So I cut it out!
Other notables:
- pedal assembly mounting holes not aligned
- shorten e-brake handle
- fab a cover for front tunnel access
- re-weld new berg mount in correct orientation
- repaint/refinish repaired areas
Posted: Sun Dec 08, 2024 7:22 pm Post subject: Re: Murray’s 1951 Split Restoration |
Looks like so much fun day, one day I'll hunt down an 11C (probably a graft like yours) and go through this fun.
Thanks for the update. _________________ I want a real garage.
Braukuche wrote: |
Posted: Thu Jan 09, 2025 5:50 pm Post subject: Re: Murray’s 1951 Split Restoration |
Looking really good bro. |
