kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Sat Jul 09, 2022 5:09 am Post subject: Subaru 2.2 FI |
In my '86 Syncro - I've got a 1994 Subaru Legacy 2.2 motor.
I've been dealing with some fuel injection and idling issues. When replacing some electrical connectors for the Fuel injectors - I realized there appears to be one very common one, and then another one. I have the uncommon one. Looks are very similar, but the shape is different enough that the electrical connector would not attach properly.
Anyway - I was able to replace 2 electrical connectors, but still have some issues. I'm thinking of replacing the Fuel Injectors themselves, and want to make sure they match the electrical connector - but then was thinking, maybe I should get the Fuel Injector that is more common, and get electrical connectors that match.
Hope that makes sense.
Here are 2 connectors that are supposedly for my engine -
So I'm wondering if there are interchangeable - ie do they all act the same - as long as they are designed for a '94 subaru legacy?
https://tinyurl.com/2j5j4txa
https://tinyurl.com/ft8ncbjz
The ebay one is the one that fits my injectors. _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Sat Jul 09, 2022 10:16 am Post subject: Re: Subaru 2.2 FI |
you should have the side feed injectors (they have the aluminum cap on them and screw to the fuel rail)
if so, you're kinda stuck with that setup _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Jul 10, 2022 7:53 am Post subject: Re: Subaru 2.2 FI |
Dumping a bottle of FI cleaner into your tank every 10K miles or as needed will typically keep you injectors working well. If more is needed you can pull them and send them off to a cleaning service. There may be aftermarket injectors that fit your engine, but they may well not be an improvement, no matter the hype. |
Posted: Fri Jul 15, 2022 12:51 pm Post subject: Re: Subaru 2.2 FI |
If I take FI's out, will I need new seals when I install them again?
If I buy new ones - do they come with seals, or is this something I need to buy separately? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Fri Jul 15, 2022 1:37 pm Post subject: Re: Subaru 2.2 FI |
kguarnotta wrote: |
yes
kguarnotta wrote: |
If I buy new ones - do they come with seals, or is this something I need to buy separately? |
no idea. depends on the vendor
honestly, i'd get the original ones cleaned and flow matched _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Jul 15, 2022 2:44 pm Post subject: Re: Subaru 2.2 FI |
Initially I was planning on getting original ones cleaned, but I also need the van to get around. So I figured a swap with new ones, and get old ones cleaned.
I found brand new injectors - https://www.ebay.com/itm/254836295788
To get what I have cleaned and flow matched is more than brand new ones. I will probably still get the original ones cleaned, but then keep them as backup, and use the new ones. I'm just trying to predict what I'm going to run into when I take the old ones out. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Fri Jul 15, 2022 2:52 pm Post subject: Re: Subaru 2.2 FI |
i would seriously reconsider your plan
at the very least i'd be looking for OEM and get them done. I have yet to find ANYONE that has had any luck with cheap injectors _________________
Jake Raby wrote: |
Brian wrote: |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Fri Jul 15, 2022 3:04 pm Post subject: Re: Subaru 2.2 FI |
skills@eurocarsplus wrote: |
at the very least i'd be looking for OEM and get them done. I have yet to find ANYONE that has had any luck with cheap injectors |
X2, Skills. OEM injectors are very well-made and I can't understand why anyone using a stock engine would not use properly-serviced serviced stock injectors.
It's like the CV joint issue - - the factory VW axles and CV's are way better quality than any aftermarket replacement except for the genuine Porsche 930 units.
Most injector service companies have a very fast turnaround. _________________ '86 Syncro Westy SVX |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3101 Location: ABQ NM USA.... Except when not
Posted: Fri Jul 15, 2022 3:29 pm Post subject: Re: Subaru 2.2 FI |
re" skills' comment above
Maybe if it has Seller paid return shipping and you could get your OEM ones redone under 30days, you could have them in place while yours are redone and if they are crap, you would have them as a bandage/trial while yours are getting fixed....and if they are OK, you won the Ebay quality lottery _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Sun Jul 17, 2022 7:36 pm Post subject: Re: Subaru 2.2 FI |
Well - I got the replacement fuel injectors, and they are not a match, guess I'll keep looking for something to replace these.
At this point I need a vehicle every day - maybe if I get one of my other buses going reliably, then I can take these FI out, and send them in to get refurbished somewhere. Anyone have a clue how to get the right fuel injector? Or have a recommendation on a company that refurbishes them?
thanks.
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Sun Jul 17, 2022 9:04 pm Post subject: Re: Subaru 2.2 FI |
You should be able to pick up an OEM Subaru a set at a wrecking yard |
Posted: Sun Jul 17, 2022 9:07 pm Post subject: Re: Subaru 2.2 FI |
you sure you don't have pieces stuck in your intake? never seen an injector like that. it's looks like it's missing the entire pintle cap assy
any VIN# for your engine? i can't easily help without one _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Jul 17, 2022 9:34 pm Post subject: Re: Subaru 2.2 FI |
alright
my curiosity got the best of me
90-91 legacy turbo only injectors
16611 AA120 is the subaru number
good luck finding one of those in a junk yard _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Jul 18, 2022 6:01 am Post subject: Re: Subaru 2.2 FI |
thanks skills.
I don't have a vin# for the engine - as far as I know this era of subaru engines don't have a vin #. If there is one there - please give me some tips on how to find it.
As far as a wrecking yard - I don't think that is really an option.
I can imagine that a cheap injector may not last long or work as well as reconditioned original ones, but I'm just trying to find something that can work while I get the original ones reconditioned/cleaned.
When I bought this van, I was told it was a '94 subaru legacy, but maybe it is a different year, may explain why I have so much trouble finding parts/connectors etc. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1089 Location: Atlanta, GA
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Mon Jul 18, 2022 7:33 am Post subject: Re: Subaru 2.2 FI |
What ECU are you running? Maybe the system was just pieced together, best to start at the top. |
Posted: Mon Jul 18, 2022 8:48 am Post subject: Re: Subaru 2.2 FI |
syncrodoka wrote: |
every time i've tried to help him i think the same thing. it's either a mixed bag of parts tossed together or whoever built it/had it built just didn't remember
when i have tried to look up parts by the info he's given nothing makes sense. i went down the rabbit hole trying to find the injectors because i don't ever remember seeing that style.
this is why i stress to swappers to record the VIN and build date of the donor. if not, you run into an ass ache like this for the simplest things _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Jul 18, 2022 9:18 am Post subject: Re: Subaru 2.2 FI |
syncrodoka wrote: |
this is why i stress to swappers to record the VIN and build date of the donor. if not, you run into an ass ache like this for the simplest things |
I have the VIN of my Subaru donor car written inside the cover of my Bentley.
Subi's have some weird differentiation by VIN that I normally wouldn't think of. Just found out that for a 1990 2.2 the coil pack is different between an automatic and a manual transmission car. |
Posted: Mon Jul 18, 2022 9:19 am Post subject: Re: Subaru 2.2 FI |
Hey guys - thanks for the help. I did not do the conversion - I believe it was done 2 owners ago, and have been running with info that was given to me. YEs - it is a pain that most times when I look for parts for a '94 they don't seem right.
As far as the ECU - is there something on the ECU itself I should be looking for to determine which ECU has been installed?
Everything was working fairly well - aside from poor idle that got really bad the last two months - which was fixed by swapping in a new IACV. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Posted: Mon Jul 18, 2022 9:31 am Post subject: Re: Subaru 2.2 FI |
the ECU would give you a year range, but if someone swapped all the bits beyond that it would be hard to tell.
really you best bet is to make note of all the parts you've replaced by keeping tabs on the part numbers.
those injectors according to the info i have were turbo only, so who knows if the rail/intake was swapped out or it was a bunch of random stuff tossed together.
i've been involved in 3 "re-do's" at this point and all 3 sucked because in those cases it was a engine from here, harness from there, intake from that guy...
really made it a huge pain in the ass to track down parts.
i'm going to guess someone tossed in the injectors because "they flow more" or some such nonsense, but looking up your year range under NA lead to the injectors you bought. it was only when i went to the turbo the injectors you have were even an option, and were a few years off _________________
Jake Raby wrote: |
Brian wrote: |
