orange914 Samba Member
Posted: Wed Jul 20, 2022 6:40 pm Post subject: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
What is the best turbo intake manifold for my turbo conversion. and why do you recommend it for my application.
I'm starting with a fresh /balanced n/a 1.6 diesel. My end goal is low/mid rpm power band. I'm after the fun factor/street able and focus on drive ability. No crazy high rpm application. using a fresh exhaust side ported and ceramic coated k14. Probably 12-14 p.s.i. max.
input appriciated |
Posted: Sat Jul 23, 2022 7:04 am Post subject: Re: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
Picked up a good k14. Sent it straight to JPop in Arkansas for rebuild with upgraded bearings, exhaust port and polish and ceramic exhaust side coat.
Just building up miscellaneous support parts now. Got the exhaust manifold, dual oil tap filter housing, oil pressure line, and aftermarket BAE intake. I may use a pd150 intake instead? |
Posted: Sun Aug 21, 2022 12:15 pm Post subject: Re: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
Update
Rebuilt with upgraded thrust bearing, port & polish, ceramic coated
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1467 Location: Westfield, MA.
Posted: Fri Dec 23, 2022 7:42 am Post subject: Re: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
That's awesome! Any idea what they'd charge for a basic rebuild? I've been thinking of sending my K14 from my Vanagon out this winter. I may do it myself, but have SO many other projects |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Wed Mar 08, 2023 8:02 pm Post subject: Re: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
Have you measured the outlet of that stock downpipe? It’s pretty restrictive. I made my own downpipe with 2.25” mandrel bends.
_________________ foam cowboy hats aren't good helmets. |
Posted: Wed Mar 08, 2023 8:21 pm Post subject: Re: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
Interested in selling that? P.M. me |
Posted: Thu Mar 09, 2023 9:12 am Post subject: Re: best O.E. turbo intake for up grading a n/a 1.6d to turbo? |
It’s in my daily driver. I knew I should have made several... _________________ foam cowboy hats aren't good helmets. |
