GASBNR Samba Member
Joined: April 30, 2003 Posts: 73 Location: Melbourne, Australia
Posted: Wed Jul 20, 2022 7:36 pm Post subject: Aug51 split Gemini |
So I bought a August51 from a friend who got it from South America
It’s now in Melbourne Australia
It’s my first pre 55 beetle so learning these are so very different to post 55 cars.
I have loads of questions and a bit of guidance
It looks like I need a steel fuel cap not the Ali one I have.
Not sure what colour the speedo face should be.
On Instagram as gasbnr
Just got to post some pics |
GASBNR Samba Member
Posted: Sat Jul 23, 2022 12:11 am Post subject: Re: Aug51 split Gemini |
GASBNR Samba Member
Posted: Sat Jul 23, 2022 12:16 am Post subject: Re: Aug51 split Gemini |
Found the correct air filter here in Australia.
Surprisingly as these cars were never imported here. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Sat Jul 23, 2022 1:35 am Post subject: Re: Aug51 split Gemini |
nice project! but when you have gemini in the title are you meaning zwitter? a '51 split is too early to be a zwitter, what you have is a crotch cooler split.
the speedo looks to be the correct colour to me - brownish grey
the number plate light is from an oval, your car should have a proper 'popes nose'
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
GASBNR Samba Member
Posted: Sat Jul 23, 2022 1:44 am Post subject: Re: Aug51 split Gemini |
Thanks.
Gemini is just a Nick name.
Gemini is the astrology charts. Aka has a split personality lol
Thanks for the heads up on anything you see. |
D-train Samba Member
Posted: Sat Jul 23, 2022 2:30 am Post subject: Re: Aug51 split Gemini |
Good pics Oliver! Is the oil filler screwed into the case? _________________ shiny paint doesnt make it worth any more |
GASBNR Samba Member
Posted: Sat Aug 27, 2022 5:29 am Post subject: Re: Aug51 split Gemini |
Does anyone have a original Oct 51 pastel green Deluxe I can use to work a few things.
Thanks in advance |
splitjunkie Samba Member
Posted: Sat Aug 27, 2022 6:06 am Post subject: Re: Aug51 split Gemini |
It has 36hp cylinder tins so the engine is probably a 36hp with a few 25hp external parts, such as the distributor and air cleaner. The fuel pump and carb appear to be zwitter/ '53 25hp parts.
What is the engine number? _________________ Chris
GASBNR Samba Member
Posted: Sun Aug 28, 2022 6:46 am Post subject: Re: Aug51 split Gemini |
splitjunkie wrote: |
What is the engine number? |
It has 25hp dates.
Not to stressed about the engine at this. |
Two Glove Boxes Samba Member
GASBNR Samba Member
Posted: Mon Sep 05, 2022 7:13 am Post subject: Re: Aug51 split Gemini |
Ok.
Got the birth certificate
Oct 51.
Was delivered to a dealership in Argentina
Anyone else have a Argentina delivered split? |
GASBNR Samba Member
Posted: Thu Nov 30, 2023 12:06 am Post subject: Re: Aug51 split Gemini |
Started soaking all the bolts and checking to see if there is damage to the frame head.
Lots of work to do.
I have been sourcing all the missing bits and still loads to find and replace.
The car does have its original 25hp motor and does trim over.
The K manifold is partly there in pics above.
