tdoman Samba Member
Posted: Fri Jul 22, 2022 11:50 am Post subject: Volksrod - Power Window, Power Door Lock, Power Door Open |
I'm converting a '66 bug into a volksrod. I chopped the top and pulled out all the windows. I'm planning on converting the windows on the doors to powered, converting locks to remote powered, and shaving the door handles and popping the doors open when unlocking a door. I would also like to add a push button start that requires a key fob present and an option to pop open the front hood.
Ideally, I would like everything to integrate so I control it all with one key fob. I've never done this before so I don't know what products work best. Can anyone that has done this recommend a key fob system, universal power windows, power door lock, power hood lock, and door popper system that works well in a bug? |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Sun Jul 24, 2022 10:13 am Post subject: Re: Volksrod - Power Window, Power Door Lock, Power Door Open |
Check with the Hot Rod websites. They like all the same toys & ideas. You will not find VW specific parts, they and the car will need have adjustments made. _________________ I think he meant "rare", as in "not well-done" |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Wed Jul 27, 2022 1:05 pm Post subject: Re: Volksrod - Power Window, Power Door Lock, Power Door Open |
Look into an Arduino controller. Basically it’s a PLC that you can hang virtually anything off of. Short of that, look into aftermarket car alarm gear. Those can handle a lot of add on modules to do what you want.
Way back in the day, a guy I worked with did a lot of what you’re talking about.
I specifically remember him using door lock solenoids from a Coupe de Ville to pull the door handle and along with some shims to preload the hinges, the doors would pop open. For the power windows, there used to be a kit available but I don’t think so anymore.
He got most of his stuff from the Pull-a-Part junk yards. Those are getting hard to come by as well. _________________ Volkswagen!
(Compression 8.7:1) |
