aviator8 Samba Member
Posted: Thu Aug 04, 2022 12:50 pm Post subject: accelerator cable as it leave the tunnel- 1967 beetle |
I'm getting things put back together and since things were not right originally I am trying to determine the correct parts to protect and route the accelerator cable. I have this part:
https://www2.cip1.com/vwc-131-721-551/
as well as this part
https://www.mtmfg.com/part/view/accelerator-cables...p;src=1879
but they don't seem to fit well together.
What I am trying to determine is as the cable leaves the tube is my flex line suppose to go into the boot shielding the clutch boden tube and slide over the metal tube? Its a tight fit and doesn't seem right. If it does not do that it seems I have a wear point for the cable and the flexible sheath would just flop around loose in there. If it is supposed to slid over the tube then the other side is narrow and will not interface with the hard line that goes through the doghouse. I am wondering if I got the wrong parts, or I am missing a part that makes all this fit. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Thu Aug 04, 2022 1:05 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
I don't remember any Bowden tube on the throttle cable.
I thought it just exited the tunnel and went open to the metal tube in your first link. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Thu Aug 04, 2022 2:19 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
My 1970 sedan definitely had a bowden for the accelerator cable, from factory.
About 2018 I ordered a new bowden, but it didn't fit and I ended up returning it and re-using my old worn one.
Remember to secure that steel tube with a hose clamp on the forward/hidden side of the fan shroud. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Thu Aug 04, 2022 5:01 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
The "bell" end of the 66/67 accelerator cable bowden tube, should point toward the engine.
The fan shroud metal cable guide tube slides into the bowden tube bell.
And the throttle cable slides through the entire tube system. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Thu Aug 04, 2022 7:12 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
67rustavenger wrote: |
And the throttle cable slides through the entire tube system. |
Ok that makes sense, but then the narrow end of the bowden tube going back toward the chassis, do I just push it through the rubber seal and it just kind of floats in front of the steel tunnel exit tube? |
Posted: Thu Aug 04, 2022 7:13 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
Cusser wrote: |
Remember to secure that steel tube with a hose clamp on the forward/hidden side of the fan shroud. |
Thanks, did not know that. |
Posted: Thu Aug 04, 2022 9:52 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
Great video explaining your dilemma.
To be honest, I have never had a car off the pan.
You should finish the rubber bowden tubes seal installation.
It maybe that the seal makes up the difference between the throttle tube through the pan tunnel, and the bowden tube between the tunnel and the engine.
Maybe ream out the bell end of the bowden tube, to fit the engine throttle cable tube better.
Aftermarket parts take a bit to get fit correctly. _________________ I have learned over the years.
Buy Once, Cry Once!
NachoCar Samba Member
Posted: Fri Aug 05, 2022 6:45 am Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
Read your question yesterday and it lead me to REMOVE my bowden tube last night. The operation of my accelerator cable was sticking. Taking the tube off soved it. Probably not the best solution but......
My question is why didn't the metal tube going thru the fan shround come from the factory with some means of securing it? Everything seems to me to be so well engineered on these cars. If something isn't working well, I ALWAYS am doing/installing/ whatever wrong. |
KTPhil Samba Member
Posted: Fri Aug 05, 2022 12:40 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
NachoCar wrote: |
My question is why didn't the metal tube going thru the fan shroud come from the factory with some means of securing it? Everything seems to me to be so well engineered on these cars. If something isn't working well, I ALWAYS am doing/installing/ whatever wrong. |
The slant means gravity keeps it there. If gravity fails, we have deeper problems than our old VWs working! |
slayer61 Samba Member
Posted: Fri Aug 05, 2022 1:57 pm Post subject: Re: accelerator cable as it leave the tunnel- 1967 beetle |
KTPhil wrote: |
NachoCar wrote: |
QFT! Fer reals! _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
