titan3c Samba Member
Joined: February 16, 2012 Posts: 568 Location: Coweta, Oklahoma
Posted: Wed Aug 10, 2022 8:39 am Post subject: transmission fluid in engine oil |
Question: I'm totally ignorant on this matter. But is it possible for some reason: can transmission fluid get into the engine oil? I'm having trouble getting an indication on the transmission dipstick of adding fluid to bring the level up to where it should be.
If it is possibly happening: Is there a way to check for sure? Bob |
raygreenwood Samba Member
Posted: Wed Aug 10, 2022 9:07 am Post subject: Re: transmission fluid in engine oil |
titan3c wrote: |
Bob, there are a couple of issues to check that can cause transmission fluid to disappear.
1. If the diaphram inside of the transmission modulator valve may be damaged (that round thing on the right rear side of the oil pan on the transmission with a vacuum hose attached ued to it)......it can either leak fluid outside to the ground or more commonly the transmission fluid gets sucked into the vacuum hose and into the engine.
If you pull that hose loose and there is any red transmission fluid at all inside or it drips out....this is what is happening.
2. Lift up the car and let it sit level as possible. Get a hex socket tool and remove the fill plug from the side of the differential. Put a pan under it. If a bunch of fluid runs out.....it's over filled. But if the fluid is too high and it also has a reddish tint....it's because the seal between the automatic section and the differential has failed and is leaking into the differential section.
If this is the prohlem.....and its very common.....you can't drive it this way as it dilutes the 90 weight gear oil in the differential and can destroy it. It's not hard or expensive to replace the seals and gaskets between the auto and diff section.....but the transmission has to come out to do so.
Ray |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Wed Aug 10, 2022 10:40 am Post subject: Re: transmission fluid in engine oil |
Yep, Ray is totally correct. Hope it is the easy fix.
Bill |
Posted: Wed Aug 10, 2022 12:43 pm Post subject: Re: transmission fluid in engine oil |
OK, one more question: If I remember correctly, that hose in in two sections on my car, and they connect back near the rear spring. Is checking the hose that far from the differential practical, or not. Bob |
Posted: Wed Aug 10, 2022 1:37 pm Post subject: Re: transmission fluid in engine oil |
titan3c wrote: |
You noted you have transmission oil in the engine. I had to re-read your post. So you HAVE transmission ATF in your engine oil right?
Only say that can happen is from that modulator valve. Easy fix but may be hard to find. List the part # on yours. Ray |
KTPhil Samba Member
Posted: Wed Aug 10, 2022 2:55 pm Post subject: Re: transmission fluid in engine oil |
And check for any paint parks or bands on the modulator. At some point, I think VW color-coded parts with the same part number! |
Posted: Wed Aug 10, 2022 4:46 pm Post subject: Re: transmission fluid in engine oil |
Bob,
Usually when the modulator valve ruptures that causes the engine to smoke out the tailpipe a whole lot. Does your engine smoke? Just gotta ask…did you by mistake pour ATF into your crankcase?
Bill |
Posted: Fri Aug 12, 2022 1:34 pm Post subject: Re: transmission fluid in engine oil |
I'm just having trouble getting the transmission fluid up to level. That's what made me start wondering where it's going. No there is no smoke, and I haven't mistakingly poured transmission fluid in the engine.
I haven't done the checks yet Ray said to do. I'll let you know what happens after I do that. Bob |
Posted: Fri Aug 12, 2022 4:44 pm Post subject: Re: transmission fluid in engine oil |
titan3c wrote: |
Ok...just check to make sure your engine oil is not too high and also make sure you are checking transmission fluid with the engine running and warmed up, the brake on, the wheels blocked and the transmission in Drive. Ray |
Posted: Fri Aug 12, 2022 6:58 pm Post subject: Re: transmission fluid in engine oil |
Worst case scenario could be what Ray has already mentioned. Better then go ahead and check the final drive. Could be going there. Hopefully not.
Bill |
Posted: Sat Aug 13, 2022 7:23 am Post subject: Re: transmission fluid in engine oil |
OH!!!, I wasn't checking the transmission fluid with it in drive. So I'll do some rechecking. Bob |
Posted: Sat Oct 22, 2022 5:05 am Post subject: Re: transmission fluid in engine oil |
OK, to answer your question about smoke. Just noticed lately when starting the engine I get smoke briefly. not every time, but has happened a couple of times. I haven't got the car lifted yet so I can do the checks Ray suggested. Bob |
