1984 Jetta Water Pump Pulley source
Forum Index -> Water-cooled VW Share: Facebook Twitter
Wolfsburgy
Wolfsburgy is offline
PostPosted: Fri Aug 12, 2022 9:02 am    Post subject: 1984 Jetta Water Pump Pulley source Reply with quote
Engine overheating recently, found the water pump pulley outer ring completely rusted away from the pulley hub!
I have searched high and low for a replacement, PN055121031C (I believe the "C" designates A/C car).
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Sun Aug 14, 2022 4:33 pm    Post subject: Re: 1984 Jetta Water Pump Pulley source Reply with quote
I tried looking it up, can’t find anything by that #.
Since it’s a ‘84 with AC, it should be a 30mm hub, but there could be a 40mm hub on it.
Do you need the inner or outer pulley?
If you need the inner, is it the “clutched”/floating pulley, or a solid one?
I have a fuckton of these damned things in a box somewhere.
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
