Back brakes are locked on 1960 356
aa390392
aa390392 is offline
PostPosted: Sun Aug 21, 2022 8:32 am    Post subject: Back brakes are locked on 1960 356 Reply with quote
Just purchased this car, it’s been sitting 10 plus years, back wheels are locked tight. We cut the soft lines,
Any suggestions Aluminum drums.
Thanks
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
Starbucket
Starbucket is offline
PostPosted: Sun Aug 21, 2022 2:56 pm    Post subject: Re: Back brakes are locked on 1960 356 Reply with quote
Use a rubber mallet and (with wheel removed) smack hard the outer part of the drum (where the shoes contact on the inside) and make sure you have backed off the shoe adjusters and let off the parking brake.
aa390392
aa390392 is offline
PostPosted: Sun Aug 21, 2022 4:42 pm    Post subject: Re: Back brakes are locked on 1960 356 Reply with quote
It has aluminum drums…don’t want to destroy the fins..
55 ragtop
56 delux sedan
56 Kabriolet
Starbucket
PostPosted: Sun Aug 21, 2022 6:14 pm    Post subject: Re: Back brakes are locked on 1960 356 Reply with quote
I said RUBBER Mallet, won't hurt the fins but it will break the rusted shoes to steel liners loose.
RolandD
RolandD is offline
PostPosted: Sun Aug 21, 2022 7:23 pm    Post subject: Re: Back brakes are locked on 1960 356 Reply with quote
Hit the part where the wheel mounts, between the studs.
Roland
finster
finster is offline
PostPosted: Mon Aug 22, 2022 3:40 am    Post subject: Re: Back brakes are locked on 1960 356 Reply with quote
Roland
I've done this but holding a block of wood against the drum between the studs and then hit the wood with a hammer
