My new to me 1967 Kombi/Day Van
Murt
Murt is offline
PostPosted: Tue May 23, 2023 5:08 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Spotlights getting wired in, well preparation Very Happy
1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi
Murt
Murt is offline
PostPosted: Tue May 23, 2023 5:11 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Trying to Sort out the usual PO's wiring modifications Rolling Eyes
BulliBill
BulliBill is offline
PostPosted: Tue May 23, 2023 9:10 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Cool Bus, looks like it is in better hands now with you. I don't think I have ever seen anyone remove the transaxle drain plug and "goop" it closed like that. Horrible idea!
I hope your mechanic can successfully remove the "goop" to see if it can be put back together as stock (with a functioning drain plug). Are the drain plugs at the bottom of each reduction box still there? How about the three "fill" plugs?
X2 on dumping that cheesy paper element air cleaner! Buy and install an original stock Transporter air cleaner assembly for the best function on your Bus.
Have fun with your Transporter!
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Murt
Murt is offline
PostPosted: Tue May 23, 2023 11:13 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Thanks Bill
This is going to be a bit of a labour of love over the next 2 or 3 weeks. As interior is currently the priority
RGB's and fillers are thankfully all present and good, what on earth the PO was doing by Masticking the drain plug, heaven only knows, were going to pull it all out and have a look what went on, and will maybe have to try a heli-coil. Just got some new boots as well, they are FEBI, so not sure how well they will work, as there's been a few negative comments about quality/longevity on these ?
Regarding Engine, I've got some parts put aside, to include a CSP quiet pack Stainless exhaust, a pair of NOS Weber IDF36's, struggled to get Velocity Stacks, but again CSP in Germany came good, 55A Alternator, new fuel pump Carb Linkage etc. etc. so maybe something for over the winter ?
Eric&Barb
Eric&Barb is offline
PostPosted: Wed May 24, 2023 6:56 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
The drain plugs are a tapered device, so pretty sure a Heli-Coil will not work. Even if HC did have such, would use a Time-Sert instead since they can be locked in place unlike a HC.
In Stereo, Where Available!
Murt
Murt is offline
PostPosted: Thu May 25, 2023 2:19 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Thank you Eric&Barb I must admit that I did not know that. Embarassed
Strip out of the Bus continues, in the cab Very Happy
I think I may have hit Paydirt !!!! found a coin Very Happy date is 1990, wonder if the PO in the States is still looking for it ?? Laughing Laughing
Yannvanh
Yannvanh is offline
PostPosted: Thu May 25, 2023 3:55 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Nice bus! Keep upgrades posted! Very Happy
'66 vw splitbus project:
Instagram page:
yannicks_splitbus_project
Always there to help!
Murt
Murt is offline
PostPosted: Mon Jun 05, 2023 9:12 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Just bought an electric fuel pump ⛽️ for running with the dual IDF36’s. Bit disappointed to be honest, as didn’t want Chinese and decided on Carter Pump from the USA. It’s here ☹️
Oh well, will be fine I’m sure 🙄 looking at Pierburg now as well 😂
c21darrel
c21darrel is offline
PostPosted: Mon Jun 05, 2023 7:29 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
stock fuel pump should be fine, I have one on a 2 liter.
GhiaBuild
1967 DC build
Murt
Murt is offline
PostPosted: Wed Jun 07, 2023 11:08 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
More progress, there were lots of holes drilled into the cargo area, so needed welding up, knocking back and treating.
After prep and treating, soundproofed
Some other shots
Murt
Murt is offline
PostPosted: Fri Jun 09, 2023 8:10 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Marine Ply floor being fitted
Murt
Murt is offline
PostPosted: Tue Jun 13, 2023 6:27 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Fridge Pod, being unboxed and assembled. As usual some bits weren't in the Box !! Crying or Very sad
Murt
Murt is offline
PostPosted: Tue Jun 13, 2023 10:32 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Rest of the new panels, flooring and adhesive arrived today, fitted one of the Kuhltek side scoops, they’re very well made, not sure whether to paint them later on ?
Murt
Murt is offline
PostPosted: Thu Jun 15, 2023 5:03 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Managed to get Ply wood kit at last, and test fitting. And Doh !! Cargo doors turn out to be for RHD, whereas I'm a LHD USA spec Kombi, so the Upholstery shop will need to make sure they upholster the rough side Laughing Laughing
Murt
Murt is offline
PostPosted: Thu Jun 15, 2023 9:15 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
More fit out inside and out
Murt
Murt is offline
PostPosted: Wed Jun 21, 2023 10:59 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Bit more progress this week, new Oil tempered panels test fitted, and dropped off for re-upholstery, Rock and Roll Bed being fitted in, and Vinyl flooring been laid out ready to trim and glue down
Murt
Murt is offline
PostPosted: Thu Jun 22, 2023 5:26 am    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Lining up bed, and test fitting the Bulkhead cover
Murt
Murt is offline
PostPosted: Sun Jun 25, 2023 10:59 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Not much done this weekend.
Some new deluxe trim fitted in Sea Blue, and prepping to fit the new rear bulkhead cupboard. Main problem is that the Fridge Pod I've got doesn't fit, so probably going to have to 'shorten' it. Embarassed
Murt
Murt is offline
PostPosted: Tue Jul 18, 2023 10:06 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Progress on the Bus has been a bit slow, lots of other stuff going on, but have added progress shots as of yesterday, think I can see light at the end of the Tunnel
Murt
Murt is offline
PostPosted: Tue Jul 18, 2023 10:07 pm    Post subject: Re: My new to me 1967 Kombi/Day Van Reply with quote
Just some more pictures, as i like to log progress Very Happy
Page 3 of 4
