nthang Sambassador
Joined: February 05, 2003 Posts: 158 Location: Up Stream
Posted: Thu Jul 01, 2004 8:45 am Post subject: High Beams |
My high beams are not working on my kubel looking head lights. Low beams work fine. Actually, the right one works occationally.
I bought a replacement bulb. That's not it. I checked all the wiring and wire brushed all the terminals and leads at the relay. I looked at the switch in the column and it seems to work fine. I bought a new "replacement" relay from a bug shop and installed it. The lights don't work at all with it. It looks the same as the original thing relay, with one exception: one extra brass terminal than the old one.
Anyway, I'm officially w/o a clue of the fix for this problem. Maybe I need to get an original thing relay. Any ideas here? _________________ NTHANG, LLC |
LeeE Samba Member
Posted: Thu Jul 01, 2004 1:24 pm Post subject: |
Hi
Sorry if this is a stupid question, but did you check your fuses? I'm fairly sure that high beams are fused, and sometimes the fuses will be bad and still look OK, or even just need to be moved a little for better contact.
LeeE _________________ 1978 Westfalia stock 2.0 FI
Welcome to the Okeedokee Swamp |
nthang Sambassador
Posted: Fri Jul 02, 2004 5:31 am Post subject: |
I did check, twist/turn all the fuses on the advise of the vw shop. It must be the relay??? I'm thinging of getting an original relay from Mike Basso. _________________ NTHANG, LLC |
Big Luni Samba Member
Joined: December 29, 2003 Posts: 427 Location: Hartford, CT
Posted: Fri Jul 02, 2004 6:04 am Post subject: |
Mine does the same friggin thing! Lo beams work fine, but only my right high beam works. I thought it was my old headlight, but I replaced my sealed beams w/ halogen H4's, and it still happens. The guys on another forum told me to clean all my contacts- but still no luck. Maybe I need a new relay too. |
Andromeda451 Samba Member
Joined: July 18, 2004 Posts: 4 Location: Queen Creek, AZ
Posted: Sun Jul 18, 2004 1:11 pm Post subject: High Beam relay |
N,
Does the HB relay click when you attempt to raise the headlights? If not pull the panel and reposition/clean the relay mount as 70% of the time the relay loses ground and fails to operate. If the relay is clicking and only one headlight goes high and you've cleaned the connections then it's time to work on the harness. The spade connectors on the fuse panel get weak and corrode. The spade lugs need to be cut off and replaced with new. Not a big job, takes me about 1/2 an hour to re-do the entire panel. Make sure you get a good crimper, avoid the el-cheapo's as they aren't worth the metal they're fabricated from. If you're good with a soldering pencil you can also carefull re-solder each spade lug where the wire and lug connect, this will clear up any electrical gremlins but takes more time. _________________ Regards,
Andromeda451
73 Type 181
74 Type 181 |
z-volks Samba Member
Joined: March 11, 2003 Posts: 33 Location: Westport, CT
Posted: Fri Jul 23, 2004 7:15 pm Post subject: |
same thing happened to me.. I replaced the switch after i bought new bulbs , Well at least have some spare bulbs now. Thanks for the tip |
nthang Sambassador
Posted: Tue Jul 27, 2004 8:27 am Post subject: |
Update: My high beam will light or shine when I depress the high beam lever (on the column) and hold it. As long as I hold the lever back, they stay bright or high. Anybody got ideas? Sounds like the lever switch is malfunctioning....the one in the column. Thanks. Richard _________________ NTHANG, LLC |
mattt Samba Member
Posted: Tue Jul 27, 2004 11:17 pm Post subject: |
been a while since youve been heard from. Its probably a broken piece in the turn signal stalk. There is a little plastic piece that protrudes where the high beam switch is. If that plastic tang is broken off(its common for it to be), the high beams will do exactly what you mention. Ive got a good turn signal switch with a broken tang for sale.......anyone need one? |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Wed Jul 28, 2004 7:18 am Post subject: |
Sounds like a bad headlight relay to me. |
